Re: Summit codes
[Re: rickraw]
#3112144
01/15/23 01:58 PM
01/15/23 01:58 PM
moparpollack
Lil Herman
Lil Herman
85086
Thank you so much I have a big order to put in but checked here first.
Re: Summit codes
[Re: rickraw]
#3112162
01/15/23 03:52 PM
01/15/23 03:52 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There should be some at the world of wheels. I’ll be grabbing a ton of them. Good then I can stay home. 22.00 plus parking is getting expensive.
Re: Summit codes
[Re: BigFish69]
#3112325
01/15/23 11:42 PM
01/15/23 11:42 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Great, I was just about to place a big order
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Summit codes
[Re: 73cuda340]
#3112338
01/16/23 12:02 AM
01/16/23 12:02 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
How much do they save you?
Re: Summit codes
[Re: Forest]
#3114219
01/18/23 04:08 PM
01/18/23 04:08 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I've been holding off on a big order myself hoping they would become available. I sure could use one? Thanks
1970 Duster 340 clone
Re: Summit codes
[Re: BrianT]
#3114227
01/18/23 04:41 PM
01/18/23 04:41 PM
Posts: 16,925 NC
440Jim
NC
I wonder if I could use that code to get a discount on Trick Flow heads? 2 x $1557 = $3114 minus 10% ? They have been on backorder forever. Estimated Ship Date: May 17, 2023
Re: Summit codes
[Re: 440Jim]
#3114262
01/18/23 06:33 PM
01/18/23 06:33 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
rickraw, if you could grab a code for me it would be greatly appreciated. Thanks! I wonder if I could use that code to get a discount on Trick Flow heads? 2 x $1557 = $3114 minus 10% ? They have been on backorder forever. Estimated Ship Date: May 17, 2023 There were 6 of the 270 heads total available last week, but they disappeared in about a day. I almost bought a pair, decided to sleep on it, and by the time I woke up the 2 with the valvespring I needed had already sold.
