Page 3 of 3 1 2 3
Re: ARP L19 rod bolt torque [Re: mopar dave] #3112750
01/16/23 10:17 PM
01/16/23 10:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
I made him give me a stretch length and used that up twocents
I tighten and measure them in a rod vice and write down the torque needed for each bolt and use that when I assemble the motors scopeup wrench
Re: ARP L19 rod bolt torque [Re: Cab_Burge] #3112761
01/16/23 10:59 PM
01/16/23 10:59 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I did play with those a little bit and found his arp2000 bolts would give same stretch at 75lbft as with his torque and angle method. Take that for what its worth as i was using my old bolt stretch gauge which is hard to get consistant numbers.
Page 3 of 3 1 2 3
