MSD cam sync
#3109955
01/08/23 12:09 AM
01/08/23 12:09 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Currently rewiring my car to a new EFI system. Curious if anyone had modified a msd 85231 to work in a low deck?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: MSD cam sync
[Re: HOTMOPR]
#3109957
01/08/23 12:43 AM
01/08/23 12:43 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Have you considered AR engineering's cam sync ? AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: MSD cam sync
[Re: turbobitt]
#3109961
01/08/23 12:57 AM
01/08/23 12:57 AM
HOTMOPR
Oakville, Wa
Have you considered AR engineering's cam sync ? AG. Ill check it out. Thanks
Re: MSD cam sync
[Re: HOTMOPR]
#3110021
01/08/23 11:50 AM
01/08/23 11:50 AM
Posts: 296 Ontario Canada
Hutch
Ontario Canada
Currently rewiring my car to a new EFI system. Curious if anyone had modified a msd 85231 to work in a low deck? In the midst of doing exactly that right now. I made a set of holding blocks for the mill so I could cut off the drive tip and remachine it as I didn't want to use a distributor spacer. Just finishing the blocks now so I will post pics after it's cut. Hutch
Re: MSD cam sync
[Re: AndyF]
#3110164
01/08/23 07:53 PM
01/08/23 07:53 PM
HOTMOPR
Oakville, Wa
I am currently running the SD concepts Crank trigger and cam sync. The sensors have been working great. I am just looking for options other than the ugly jeep sensor. lol
Re: MSD cam sync
[Re: Hutch]
#3110169
01/08/23 08:09 PM
01/08/23 08:09 PM
HOTMOPR
Oakville, Wa
