440 Six Pack 3 pin Emblems ID
#3105703
12/26/22 02:39 PM
12/26/22 02:39 PM
Posts: 961 MN
Droop69
MN
I got these in a parts buy years ago and wasn't sure if they were real or reproductions. The 440 part is brushed not chrome and they do have part numbers on them, How can you tell originals from reproductions?
Re: 440 Six Pack 3 pin Emblems IDI
[Re: Droop69]
#3105704
12/26/22 02:39 PM
12/26/22 02:39 PM
Posts: 961 MN
Droop69
MN
more pics
[Re: Droop69]
#3105714
12/26/22 02:55 PM
12/26/22 02:55 PM
CrazyD
[Re: Droop69]
#3105731
12/26/22 04:09 PM
12/26/22 04:09 PM
Posts: 961 MN
Droop69
MN
Were the standard ralleye hood 2 scoops emblems also 3 pins?
[Re: Droop69]
#3105765
12/26/22 06:46 PM
12/26/22 06:46 PM
Posts: 4,115 MD
floyd
MD
I think the standard hood emblems did have 3 pins. The pins are shorter and are smaller diameter than Shaker emblems and one of the pins is in different location. It’s been awhile since I’ve held the two types next to each other so I could be wrong. I bought an emblem from a dealership in the mid 90s that is just like the one posted above . The red coating on the “sixpack” had the same weird translucent finish. I’ll see if I can find it and post a pic.
[Re: floyd]
#3105785
12/26/22 08:58 PM
12/26/22 08:58 PM
Posts: 28,599 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I think the standard hood emblems did have 3 pins. The pins are shorter and are smaller diameter than Shaker emblems and one of the pins is in different location. It’s been awhile since I’ve held the two types next to each other so I could be wrong. I bought an emblem from a dealership in the mid 90s that is just like the one posted above . The red coating o70-80sn the “sixpack” had the same weird translucent finish. I’ll see if I can find it and post a pic. I have a stack of about 10 and 4 I cut up to get the Six-Pack
[Re: 340SIX]
#3105790
12/26/22 09:12 PM
12/26/22 09:12 PM
340SIX
These I cut up for the Six-pack have the translucent looking red, like the OP posted. The paint is a clear red and you see thr chorme plate thought it. Kinda an anodized looking. Kinda like shooting red candy top coat over silver base. All the NOS 340 4 barrel I have are solid color red.
All the mid 90s dated packs 3 pins just like the one's in post number 1 the OP has have the translucent red. Not sure if it came out in the pics
[Re: Kilrbee]
#3109542
01/06/23 08:42 PM
01/06/23 08:42 PM
Posts: 961 MN
Droop69
MN
You can usually tell a repop from an original chrysler part by the supplier code not being cast in the repop emblems. Does anyone have good pics of originals they can share?
[Re: floyd]
#3110203
01/08/23 10:15 PM
01/08/23 10:15 PM
Posts: 21,513 N.E. OHIO, USA
A12
N.E. OHIO, USA
440 SIXPACK and 426 HEMI shaker emblems are the only ones with a RH and LH part number as far as I know. Thanks. Where do the OP's emblems go? Are these left or right side 440 SIX PACK emblems?
