Re: 65 Valiant wagon project .
[Re: bigdad]
#3109149
01/05/23 08:43 PM
01/05/23 08:43 PM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Here is underside of the power
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3109150
01/05/23 08:44 PM
01/05/23 08:44 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
was going to do this but, changed my mind
[Re: topside]
#3109158
01/05/23 08:52 PM
01/05/23 08:52 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I'm diggin' it. I think you need to vent the radiator shroud, for air movement w/o fans on, no ? Maybe , it has a about a 3/4 gap to vent, its a big experiment
[Re: bigdad]
#3109160
01/05/23 08:54 PM
01/05/23 08:54 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I've been buying and collecting parts for a long time, looks weird to see my shelf almost empty .. down to just few things, it should be able to run and move by end of month (knock on wood )
[Re: John Burdine]
#3109167
01/05/23 09:00 PM
01/05/23 09:00 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I found one of these new , not in original box but, you could tell unused, it fit ok but, like everything it fought a bit
[Re: bigdad]
#3109168
01/05/23 09:01 PM
01/05/23 09:01 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Interior is going to look mostly stockish
[Re: ksj]
#3109285
01/06/23 09:07 AM
01/06/23 09:07 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Rocky Mountain Race Week at the end of June? Not sure this particular set up will be ready for that, bit too much squeeze and my current fuel cell is only 8 gallons, this is more of , let's get it moving and try to update later with some bugs worked out
[Re: 11secdart]
#3109291
01/06/23 10:05 AM
01/06/23 10:05 AM
Posts: 4,680 Wichita
GY3
Wichita
Very cool build!
I was wondering if you still had this car.
