Stellantis to build electric airplane with 100 mile range #3108474
01/04/23 03:21 PM
01/04/23 03:21 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
https://www.msn.com/en-us/news/tech...partner-on-electric-aircraft/ar-AA15YaN9
sample quote
The plane, named Midnight, will be able to carry a pilot and four passengers. The aircraft will have a range of of 100 miles (160.9 kilometers), optimally making back-to-back trips of around 20 miles, with a charging time of about 10 minutes in-between.
end quote
give your suggested names to replace “Midnight” which implies scary to me
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108480
01/04/23 03:30 PM
01/04/23 03:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doctor Killer 2.0
Re: Stellantis to build electric airplane with 100 mile range [Re: CMcAllister] #3108481
01/04/23 03:31 PM
01/04/23 03:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Just think. All those dummies sitting in gas stations with dead Teslas would be in a smoking hole in the ground instead.
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108549
01/04/23 06:20 PM
01/04/23 06:20 PM
USA
3
360view Offline OP
360view  Offline OP
3
USA
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108581
01/04/23 08:06 PM
01/04/23 08:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
100 mile range is useless.
20 mile trips? For what? be easier to just jump in the car and drive.
Re: Stellantis to build electric airplane with 100 mile range [Re: Sniper] #3108586
01/04/23 08:33 PM
01/04/23 08:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Most airports are way more than 20 miles apart in the middle of the country unless you count those dirt road airports the crop duster guys use. This may be great on the east coast, where everyone is condensed together, but it won't fly here (pun intended).
They have flights here from Boise to the far east side of the state, but they are not direct so it's easier to rent a car and drive it. Also, when you get off the plane you still need a rental car anyways.
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108595
01/04/23 08:47 PM
01/04/23 08:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hell Crater.
Like a Hell Cat, but with more of an impact. shock
Re: Stellantis to build electric airplane with 100 mile range [Re: Alaskan_TA] #3108613
01/04/23 09:17 PM
01/04/23 09:17 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
All those pregnant women and the children in sandals are definitely gonna stay busy working the mines in the Democratic Republic of the Congo to make all those environment saving batteries.
Keep old mopars alive.
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108716
01/04/23 11:16 PM
01/04/23 11:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
One Way seems appropriate?
Maybe they could advertise to end your fear of flying PERMANENTLY
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108757
01/05/23 02:15 AM
01/05/23 02:15 AM
I owned and flew a 1960 piper Comanche 250 HP 4 seater airplane( it would seat three kids in the back seat and two adults up front) for 15 over years, it would cruise at 185 MPH at or above 6500 ft above sea level, that is a tiny bit over 3 miles per minute. Take off and climb was from 75 MPH up to 120 MPH depending how fast I wanted to get to my cruising altitude, the higher I flew it the better the fuel mileage was, 17 GPH at 6500 Ft and 9.6 GPH at 12,000 ft.. + The higher I flew it the better the ride was also as well as less traffic, go high, always up
My point is 100 miles isn't very far at flying speeds, the little trainer airplanes are around 100 MPH max, great for building flying time and not fast enough to get you hurt in a hurry when training and learning how to fly them up Not so good for getting where you want to go in a decent time whiney
Re: Stellantis to build electric airplane with 100 mile range [Re: Cab_Burge] #3108759
01/05/23 02:42 AM
01/05/23 02:42 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I have a Nissan Leaf with a range of 70 miles. It drops significantly when its really hot or really could outside, or when I drive on the highway. "Range anxiety" is real, but my worst case scenario is I get stuck on the side of the road and ponder how to get to my destination. I can't imagine worrying about falling out of the sky when the battery gets empty because it got cold or you had to wait for a landing spot to open up. A sport bike sounds like a safer option.
Re: Stellantis to build electric airplane with 100 mile range [Re: Tom_440] #3108764
01/05/23 04:58 AM
01/05/23 04:58 AM
Guitar Jones Offline
70 mile range? That wouldn't even get me to the grocery store and back. laugh2
As for the plane, it's a vertical take off and landing aircraft so you could set it down in many places. It's cool in a high tech sort of way, but doesn't really seem too practical, but I guess you have to start somewhere.
Re: Stellantis to build electric airplane with 100 mile range [Re: Guitar Jones] #3108770
01/05/23 05:51 AM
01/05/23 05:51 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
And what happens in flight when the temp drops and the battery pack life is suddenly chopped?
No thanks.
"I think its got a hemi"
Re: Stellantis to build electric airplane with 100 mile range [Re: gdonovan] #3108845
01/05/23 10:37 AM
01/05/23 10:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
"Ladies and gentlemen, we will be beginning our descent. Unfortunately we are a bit short of the airport so if anyone sees a cornfield, please alert the flight crew."
Re: Stellantis to build electric airplane with 100 mile range [Re: 360view] #3108919
01/05/23 01:00 PM
01/05/23 01:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For some people the "fun factor" overrides practicality.
https://www.kitplanes.com/turned-on-we-fly-an-electric-xenos/
Re: Stellantis to build electric airplane with 100 mile range [Re: gdonovan] #3109019
01/05/23 03:49 PM
01/05/23 03:49 PM
O
oldjonny Offline
Don't argue with me.
oldjonny  Offline
O
No thanks.
There is an interesting read in the Feb '23 Motor Trend of their long term test of the Rivian R1T. Guy takes is camping to an area with ZERO chargers. Little did he realize how much the battery capacity drops just sitting still, doing nothing, in a cold environment. He then enters the quasi-panic mode by the third day realizing that he has to get it somewhere to get a charge...somehow these folks seem to think that having to completely plan EVERYTHING makes sense in your life simply because you chose to drive a "green" vehicle that has severe limitations all while paying $100K for the benefit of being able to parade among your friends and tout how "green" you are.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Stellantis to build electric airplane with 100 mile range [Re: CMcAllister] #3109060
01/05/23 05:40 PM
01/05/23 05:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by CMcAllister
Doctor Killer 2.0
Quite true!
It's one thing to be stranded on the side of the road because the battery in your EV dies. It's an entirely different game when you're in the air and it dies.
Re: Stellantis to build electric airplane with 100 mile range [Re: justinp61] #3109082
01/05/23 07:06 PM
01/05/23 07:06 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Doctor Killer 2.0
Quite true!
When the battery dies, you die.
Re: Stellantis to build electric airplane with 100 mile range [Re: gdonovan] #3109108
01/05/23 08:01 PM
01/05/23 08:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I MIGHT have an electric motor in a glider to get around, when the battery dies (ain’t that an appropriate word) I could glide for awhile to find the perfect crash site. Maybe they get electric parachutes too.
Re: Stellantis to build electric airplane with 100 mile range [Re: cudaman1969] #3109200
01/05/23 10:15 PM
01/05/23 10:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Call Acme!
