Page 3 of 4 1 2 3 4
Re: Recommendations on clutches [Re: olwhite64] #3105258
12/24/22 03:36 PM
12/24/22 03:36 PM
E
earlymopar Online content
earlymopar  Online Content
E
There are several good clutch manufacturers. I ended up using a "SPEC" clutch behind my supercharged Poly and TKO600 5-speed. Great set-up.
Re: Recommendations on clutches [Re: B1MAXX] #3105267
12/24/22 03:51 PM
12/24/22 03:51 PM
Originally Posted by B1MAXX
I've never been able to power shift a diaphragm like a 3 finger. Zooming around on the street, shifting hard, yes. But full throttle, flick the pedal, puch the the radio out of the dash type driving the just simply up to the task. I have a late 70's Hot Rod mag with an article all about clutches, it even bashes GM for using a diaphragm. And it states that all their heavy duty truck app used B&B.
I do not trust anything written by any of the car magazines, the writers are all English majors in college and some of them do not know anything about cars, trucks, motorcycles or any kind of automotive racing rant
My point is they will take what some "expert in our hobby" say for the truth and print it nervous down They don't know that they have been played puke
I recently bought a core motor for a customer, 1996 351 C.I. Ford Windsor motor out of the 3/4 ton 4x4 truck crew cab 5 speed, and it had a stock diaphragm clutch in it shruggy work
I like and use mostly H.P. aftermarket clutches in most of my stick shift street and strip builds: up:
Re: Recommendations on clutches [Re: B1MAXX] #3105347
12/24/22 10:28 PM
12/24/22 10:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Back in the 70-80's I would have agreed with you 100%. But technology changes over time, and that is exactly how CF became a leader in the field. Even Mcleod has dumped the 3 finger designs. I haven't looked recently to see who might even still be producing them shruggy beer
Re: Recommendations on clutches [Re: TJP] #3105402
12/25/22 10:59 AM
12/25/22 10:59 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have driven several of 4 speed gm products, They aren't the same as my B&B 833. Most guys aren't laying them out. I can tell you on more than one occasion, you go for a ride with them and they think they are being violent with it, they arn't doing chit. Most times I'll try a couple on the floor, 6000+ rpm violent power shifts resulting in an occasional very nasty missed shift resulting in a heavy ,noisy gear grind. When you do catch them with the normal ash try opening crunch, that happens with my B&B, is more of a slip into the full clamp. For you who say they are fine, go out run your car to 6000 in first, DO NOT LIFT THE GAS PEDAL AT ALL, hit the clutch, while pulling second (thats the easy one for you guys), then tell me how good they are. I just wonder how many of these reviews have really pushed this stuff to the absolute limit, to the point of failure without fear. drive
Back in the day, when they wrote articles like that, they didn't care about grenading a Hemi or what ever rare expensive machine into little pieces. no
Now we put-put around and pound our chest(keyboard) laugh2
The diaphragm is a proven street put putter, thanks to years of GM usage.
When an aftermarket mfg, quits using them you can bet its because they are cheaper to mfg, so they can make more money.
Re: Recommendations on clutches [Re: B1MAXX] #3105443
12/25/22 01:27 PM
12/25/22 01:27 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Maybe you need to go back and read what the OP asked.
Re: Recommendations on clutches [Re: Sniper] #3105497
12/25/22 04:32 PM
12/25/22 04:32 PM
moparx Offline
moparx  Offline
a very good friend of mine [R.I.P. Donny] had a 69 camero he built a small block for, out of cast off dirt burner parts.
it was a street car with a 4speed and 4.56 gears, he put one of those vertical gate shifters in.
i don't know what transmission it had, or if he did anything to it, but that thing was a foot to the floor/7000+ rpm terror with no missed shifts ! drive
beer
Re: Recommendations on clutches [Re: moparx] #3105549
12/25/22 10:04 PM
12/25/22 10:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
6500 here with an H pattern super shifter II and R lockout wink Foot never left the radiator LOL until after the lights. 4:30 to 5:13 gears on slicks. beer
Re: Recommendations on clutches [Re: Sniper] #3105559
12/25/22 10:41 PM
12/25/22 10:41 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
ok, another 10.5 B&B. My 2 cents...or a 10.95 (better)
Re: Recommendations on clutches [Re: B1MAXX] #3105582
12/26/22 02:54 AM
12/26/22 02:54 AM
I use to use MCLeods 10.95 Borg and Beck/long pressure plates when the pressures were above 3100Lbs. I remember some SO CA guy trying to race in NHRA Pro Stock with a SB Chevy in a Vega using one of Reds pressure plates with 2300 lbs. of pressure back when Lenco were still being used shruggy
In today world of multiple and much small diameter race clutches who really know what is the best to use without going racing in a class confused work
Al, are you out there? help grin
Re: Recommendations on clutches [Re: B1MAXX] #3106346
12/29/22 12:36 PM
12/29/22 12:36 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If you get YouTube, go to the search engine and type in "11 second 68 roadrunner" . Look for the blue roadrunner with 493 on the windshield. Watch the run. 6200 rpm power shifts with a CF dual friction that has been in the car for several years. If you have a problem power shifting a diaphragm clutch
I don't think it is a clutch problem. Just my 2 cents.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Recommendations on clutches [Re: 68LAR] #3106397
12/29/22 02:47 PM
12/29/22 02:47 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Speaking of clutches.... Any of you Chicago area guys know if Surge Friction is still in business around South Holland?
It's been years but I've gotten a few clutches from them
Also what's out there that is made somewhere better than china or Korea? I need a clutch for my pickup, nothing like you guys are talking about it's only a /6-833OD but I ain't using a china clutch again after my last couple of experiences with them. I see that LuK is now sources there?
Re: Recommendations on clutches [Re: volaredon] #3106426
12/29/22 03:49 PM
12/29/22 03:49 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have a LuK in my 98 Dakota. So far so good but I'm not doing any high rpm launches either.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Recommendations on clutches [Re: olwhite64] #3106743
12/30/22 06:19 PM
12/30/22 06:19 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Diaphram (Chivvy) clutches do not belong in a Mopar. McLeod here.
Re: Recommendations on clutches [Re: Kudakidd] #3106753
12/30/22 07:01 PM
12/30/22 07:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Better get rid of your saginaw power steering pumps then.
Re: Recommendations on clutches [Re: Sniper] #3106776
12/30/22 08:12 PM
12/30/22 08:12 PM
moparmarks Offline
moparmarks  Offline
And the 72-93 Dodge trucks also use the exact same Saginaw 808 p/s box as Chevy..
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Recommendations on clutches [Re: moparmarks] #3106777
12/30/22 08:20 PM
12/30/22 08:20 PM
moparmarks Offline
moparmarks  Offline
Just to clarify that CF and the McLeod twin disc are the only diaphragm clutches that I use on Mopars. They are quite different than a standard Chevy diaphragm clutch. Have a few new B&B setups on the shelf.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Recommendations on clutches [Re: moparmarks] #3106896
12/31/22 10:23 AM
12/31/22 10:23 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Originally Posted by moparmarks
Just to clarify that CF and the McLeod twin disc are the only diaphragm clutches that I use on Mopars. They are quite different than a standard Chevy diaphragm clutch. Have a few new B&D setups on the shelf.
Right I was going to say this a couple days ago, but didn't want to waste my time. Even though they are still a band aid on a cheap design.
Re: Recommendations on clutches [Re: B1MAXX] #3107100
12/31/22 10:27 PM
12/31/22 10:27 PM
moparmarks Offline
moparmarks  Offline
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&B for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Recommendations on clutches [Re: moparmarks] #3107111
12/31/22 10:59 PM
12/31/22 10:59 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&D for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch.
Because some people don't understand the difference between a street and a race application.
OP asked about a street application.
Re: Recommendations on clutches [Re: moparmarks] #3107145
01/01/23 07:01 AM
01/01/23 07:01 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
All of these applications were designed by the factory to work with a diaphragm clutch and all the linkages worked with them. The older muscle cars linkage rates were designed for the Borg and Beck. That’s all I don’t like about them. I’ve driven several with them Centerforce and they work, just not the same as the original design Borg and Beck. Different preferences for different people.
Page 3 of 4 1 2 3 4
