Page 2 of 4 1 2 3 4
Re: If you were buying white-letter radials which one? [Re: Andrewh] #3106651
12/30/22 01:37 PM
12/30/22 01:37 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
When they turn brown just break out the lacquer thinner and a rag and wipe them off. The BFG's with all their shortcomings is still the best looking tire for our cars IMHO.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: If you were buying white-letter radials which one? [Re: mopars4ever] #3106653
12/30/22 01:41 PM
12/30/22 01:41 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
Originally Posted by mopars4ever
I like the look of that tire but they don't offer a 245 60-15
Ron
looks like they have 255, too wide??
I had them (the size 255 60-15 on front of my old Satellite) years back but i feel they look too big in front.
Ron
Re: If you were buying white-letter radials which one? [Re: SomeCarGuy] #3106654
12/30/22 01:42 PM
12/30/22 01:42 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
Originally Posted by SomeCarGuy
I heard of an outfit called tredwear that does decal kits. Maybe add those to black walls?
I have two places bookmarked that sell the letters and a member here did it on his Challenger and they look pretty cool!
Ron
Re: If you were buying white-letter radials which one? [Re: Andrewh] #3106655
12/30/22 01:44 PM
12/30/22 01:44 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
how old are these?
firestone doesn't even show this size on their site for this tire.
Don't know if all the big places are just selling out all the old stock ????????
Re: If you were buying white-letter radials which one? [Re: MOPARMIKE69] #3106657
12/30/22 01:45 PM
12/30/22 01:45 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
Mike I have to agree with you there and yes Lacquer thinner has always been my go to letter cleaner.
Ron
Re: If you were buying white-letter radials which one? [Re: mopars4ever] #3106661
12/30/22 01:55 PM
12/30/22 01:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Would be nice to check the manufacture date on them!
In any case, I paid around $70 for each one as far I recall… true around 10 years ago
Re: If you were buying white-letter radials which one? [Re: RJS] #3106664
12/30/22 01:57 PM
12/30/22 01:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ron
Ron
I have 255/60-15 on 15x7 Rallyes on all 4 corners. For me the best size for B bodies on all corners.
Re: If you were buying white-letter radials which one? [Re: RJS] #3106665
12/30/22 01:58 PM
12/30/22 01:58 PM
OWL
Culvers Offline
Culvers  Offline
OWL
What about Mickey Thompson sportsman S/T tires?
Culvers
Re: If you were buying white-letter radials which one? [Re: Andrewh] #3106675
12/30/22 02:32 PM
12/30/22 02:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I was under the impression firestone no longer made any raised white letter tires anymore
Re: If you were buying white-letter radials which one? [Re: gtx6970] #3106679
12/30/22 02:40 PM
12/30/22 02:40 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
For the street I run Mickey Thompsons S/T’s on the ‘Cuda, Firestone Indy 500’s on the A100, and BFG’s on the Vega and Mega Cab.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: If you were buying white-letter radials which one? [Re: Culvers] #3106738
12/30/22 05:53 PM
12/30/22 05:53 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
Yes I was going to ask about those also, I know someone that put them on a bunch of years back
Ron
Re: If you were buying white-letter radials which one? [Re: BloFish] #3106739
12/30/22 05:54 PM
12/30/22 05:54 PM
JERSEY
RJS Online work OP
RJS  Online Work OP
JERSEY
Could you post up a picture of Cuda with them?
Thanks Ron
Re: If you were buying white-letter radials which one? [Re: RJS] #3106742
12/30/22 06:16 PM
12/30/22 06:16 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I like the looks and the ride/handling of the TA radial
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: If you were buying white-letter radials which one? [Re: MOPARMIKE69] #3106746
12/30/22 06:24 PM
12/30/22 06:24 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Lacquer thinner won't work. The brown is from the rubber leaching through the letters. The brown is not on the surface, it is all the way through. Nothing works to make them white again once they go brown except a paint pen.
Re: If you were buying white-letter radials which one? [Re: 469runner] #3106748
12/30/22 06:37 PM
12/30/22 06:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The letters do clean up and will look whiter after lacquer thinner but it doesn`t last.
Re: If you were buying white-letter radials which one? [Re: 469runner] #3106749
12/30/22 06:38 PM
12/30/22 06:38 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I've been able to get the BFG lettering to clean up even with brown with a can of contact cleaner in one hand and a stiff bristle scrub brush in the other had. Then some Armor All, or tire coat or similar product of choice. They are ten years old at the time of this photo?
Re: If you were buying white-letter radials which one? [Re: RJS] #3106767
12/30/22 07:53 PM
12/30/22 07:53 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Thanks Ron
Not the greatest picture, but it’s all I have at the moment sorry. What I can do is take a picture of the tires mounted on the rims. The car is currently up on stands with no wheels on it.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: If you were buying white-letter radials which one? [Re: 469runner] #3106772
12/30/22 08:06 PM
12/30/22 08:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have BFG, GoodYear, and repro Polyglas RWLT's on my toys that all brown......no paint pen needed, Trichloroethylene, a rag and one's finger, whitens the crap out of the letters, but you need to be careful to do only the letters...the plus side is it last about 2-3 yrs before they brown again....the "browning" is nothing new, I recall doing Wide whites and Standard white walls and RWLT's back in the 60-80's on up to the present to remove "browning"...
As for the OP's request, I'd avoid all the crap RWLT's on the market today, invest in a quality black wall performance tire and contact one of the many white lettered applique type letter/number makers and apply their offerings to the surface of a quality tire....some vendors also custom make letter/number appliques to your specs
Re: If you were buying white-letter radials which one? [Re: RJS] #3106871
12/31/22 06:51 AM
12/31/22 06:51 AM
OWL
Culvers Offline
Culvers  Offline
OWL
My Cuda with Mickey Thompsons
Culvers
Re: If you were buying white-letter radials which one? [Re: Culvers] #3106923
12/31/22 12:00 PM
12/31/22 12:00 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
This or Cooper Cobra (who happens to make the MT ST). Both have small block lettering similar to BFG. Both are made currently and are not old stock and licensed manufactured. Mastercraft Avenger also has small block lettering.
Kinda depends on what you want the side of your tires to say to make a selection as none of these are better performers than the other. Performance for any of these is typical street cruiser. These all fall into the "cosmetic performance" tire category which means they look good and perform like an average street tire.
Page 2 of 4 1 2 3 4
