Re: 2003 Hemi Cylinder Head Question
[Re: OrangeProwler]
#3106402
12/29/22 02:56 PM
12/29/22 02:56 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have a 07 charger that I bought from auction with two dropped valve seats (over heated, every single one I have seen drop a seat was overheated at some point), I stuck two nice use pistons in those holes and swapped an eagle top end on and now I have 12 to 1 compression and it runs awesome on pump premium. I just bought an 03 truck with the same problem and will do the same fix.
[Re: OrangeProwler]
#3109548
01/06/23 09:00 PM
01/06/23 09:00 PM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
I have a brand new 2003 5.7 crate motor. been setting since new. I was wandering if i should pull the heads and get them pinned, or just run it being its a brand new motor ?
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: HotRodDave]
#3115417
01/22/23 01:51 PM
01/22/23 01:51 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
I have a 07 charger that I bought from auction with two dropped valve seats (over heated, every single one I have seen drop a seat was overheated at some point), I stuck two nice use pistons in those holes and swapped an eagle top end on and now I have 12 to 1 compression and it runs awesome on pump premium. I just bought an 03 truck with the same problem and will do the same fix. Did you have to get a tune. I would prefer not to get a tune especially the PCM takes a dump. Honestly, I'm just looking to make the engine more reliable without spending big money and using parts that I can get cheap. I could careless about power. The 5.7L Hemi in stock form already makes enough power for my purposes.
[Re: OrangeProwler]
#3115743
01/23/23 04:37 PM
01/23/23 04:37 PM
HotRodDave
Kalispell Mt.
Here is my writeup about it, I did the writeup about a car and it is a little different in a truck, I think in a truck you need to get the adapters to keep your intake as the eagle intakes all have a different TB location that interferes with the 03-08 accessories. But either way no, a tune is not absolutely needed. Next time I get one in here I will do that write up also. https://board.moparts.org/ubbthread...eagle-swap-on-early-5-7.html#Post3106431
