Page 3 of 4 1 2 3 4
Re: Why didnt Mopar offer the 440 with dual quads? [Re: 2boltmain] #3104973
12/23/22 06:08 PM
12/23/22 06:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
After model year 1971 what manufactures still offered multi carburetor engines?
Re: Why didnt Mopar offer the 440 with dual quads? [Re: HotRodDave] #3105219
12/24/22 01:28 PM
12/24/22 01:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think your 5.7 pulls that off because it doesn't have to deal with a 2.45 first gear and a 3.23 or 2.76 diff and only 3 gears. Hi tech engine management certainly doesn't hurt either but put a 727 and a 2.76 behind it in a 5500 lb Ram pickup and I think the experience will come up somewhat short of sporty. Peak torque on a Gen 3 is 4000 rpm +/-. On a 440 it was 2800.
Kevin [/quote]
How many hemis or 6 packs came with a 2.76 gear? [/quote]
lLots of them with 3.23.
Kevin
Re: Why didnt Mopar offer the 440 with dual quads? [Re: A12] #3105270
12/24/22 04:01 PM
12/24/22 04:01 PM
V.W. did whistling
Re: Why didnt Mopar offer the 440 with dual quads? [Re: Cab_Burge] #3105284
12/24/22 05:00 PM
12/24/22 05:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
V.W. did whistling
laugh2 laugh2 I should have qualified that with American Cars subject to EPA and CARB for emissions and EVAP reasons. I know from my Dodge engineer ('62 - 2005) friend EVAP is what killed the 3X2 because Holley would not do the EVAP modification to all three carbs even though they (Chrysler engineers) had already done it. Bet it was too late and to close with all of the EPA/CARB emissions regulations already all most to the end of the two year phase in to even consider dual quads for any model. As I said they could even get the 3X2 carbs into production at that point.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: A12] #3105362
12/25/22 01:57 AM
12/25/22 01:57 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I think the reason Mopar didn't offer dual quads on a 440 it's that there was no market for it. They already had their flagship performance motor with the dual quads. Most guys who bought 440's were looking to save money over paying up for a Hemi. Not many would have paid up for the 2x4.
All this hogwash about the dual quad Hemi not being a good street motor will never die. I know from thousands of miles, they are the best street motor. Huge torque AND high rpm power. Very smooth, reliable and easy to drive and maintain in stock form.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Why didnt Mopar offer the 440 with dual quads? [Re: Cab_Burge] #3105422
12/25/22 12:27 PM
12/25/22 12:27 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
Well Edelbrock sure made a nice setup whenever their CH-28 came out. Rather than copy early Chrysler and Offenhauser with a big open single plane plenum they made a true dual plane good to 6000RPM.
Keep old mopars alive.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: ZIPPY] #3105437
12/25/22 01:16 PM
12/25/22 01:16 PM
AndyF Offline
AndyF  Offline
Originally Posted by ZIPPY
Probably the same reason there was no large port version, and no solid lifter version.
Yeah I agree. They didn't do it because they didn't need to and/or they didn't want to. Mopar could've turned the wick way up in the horsepower wars but they didn't. Most likely because that wasn't the business they were in. It would've been very easy for them to put a 4.250 stroke crank in the 440 and make it a 505. They could've added the MW heads and a dual quad intake and buried the competition. Those parts all existed in the early 70's and hot rodders had built similiar combinations so they knew it was possible. They didn't need to do it and nobody really wanted to do it so it didn't happen.
I suppose they might have regretted killing the big block since GM was able to keep their big block around in the truck division. Mopar probably could've done a truck version of the big block and kept it around a bit longer. GM is still selling big block crate engines but Mopar exited the business. I just got a new 632 from GM last week. GM is selling these 632 inch big block complete with EFI and coil near plug ignition. Makes 1000 hp on pump gas with a hyd roller cam so it will work great in a street car. Mopar could make something similar if they wanted but obviously they don't since they haven't.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: AndyF] #3105459
12/25/22 02:26 PM
12/25/22 02:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The biggest mistake is Chrysler and the after market STILL use that small bore spacing. IF they can make a Hemi head in standard form they can make one longer, make a longer block, longer crank (Chevy) Bilet cam, now there’s potential for really big cubes
Re: Why didnt Mopar offer the 440 with dual quads? [Re: cudaman1969] #3105500
12/25/22 04:46 PM
12/25/22 04:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Remember, Japan was invading the market with mpg 4 bangers, gas and insurance were getting expensive, and the government was talking emissions. The market was changing fast.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: Pacnorthcuda] #3105525
12/25/22 07:27 PM
12/25/22 07:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i ran 6paks for many years. had several sets. tried every carb combo i could my hands on. they will make power, but i've moved on. i run a ch28 with two 600's on one of my 440's and am very pleased with the low maintenance and excellent drivability i think the 6pak may have a small power advantage due to a little better flowing intake, but the 6pak doesn't make power as smooth as the quads, and i think the quads might have a torque advantage or at least a smoother torque curve.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: lewtot184] #3105535
12/25/22 09:04 PM
12/25/22 09:04 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I ran a dual 4 Edelbrock intake on my 383 for years with twin Carter 500's, loved the torque! up
JB Rhinehart, Realist
A-Body's RULE!
Re: Why didnt Mopar offer the 440 with dual quads? [Re: Rhinodart] #3105600
12/26/22 08:50 AM
12/26/22 08:50 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
not sure if it's been mentioned or not but Chrysler did offer an over the counter dual quad set-up for rb engines. it was the 385hp 413 set-up with a cast iron single plane intake and two small afb's. chrysler never had the money to r&d and market a lot of combos for production the way gm and ford did. in the '60's most enthusiast were leaning toward single carb technology that was developing. this was basically born out of nascars ban on multi-carbs, and let's face it; most people can't work on one least wise two or three. i have far more problems with the single four on my stock '69 r/t than the dual quads on my '65 coronet.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: lewtot184] #3105602
12/26/22 09:06 AM
12/26/22 09:06 AM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
Dodge's truck share market wasn't big enough to keep making big blocks, the bailout forbade them and the engine was ancient compared to the competition. The block hadn't done well when they put hemi heads on it originally just as issue's resurfaced when Indy brought out the 440-1 years later, Why Chrysler never made a dual quad 440? Why would they.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: lewtot184] #3105603
12/26/22 09:14 AM
12/26/22 09:14 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I think Chrysler just had a ridiculous number of engines as it was and needed another like a hole in the head.
OFF THE TOP OF MY HEAD for 1970
Slant Six (170, 198, 225) The 170 was available on exports out to 1971
318
340 (different cams for manual and auto? can't recall)
340 6-pack
361 (Industrial out to 1974)
383 2 bbl
383 4bbl
383 HP
413 (Trucks and RV out to 1979)
440 4bbl
440 HP
440 6 pack
426 hemi
I'm sure I missed a few variants but that is a lot of different engines to churn out and certify compared to today.
"I think its got a hemi"
Re: Why didnt Mopar offer the 440 with dual quads? [Re: gdonovan] #3105622
12/26/22 10:09 AM
12/26/22 10:09 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
318
340 6-pack
383 2 bbl
383 4bbl
383 HP
440 4bbl
440 HP
440 6 pack
426 hemi
that is a lot to keep up with when you consider chryslers percentage of market share. when it came to performance they didn't r&d, and couldn't, like others. they just put a part number on aftermarket parts.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: lewtot184] #3105627
12/26/22 10:40 AM
12/26/22 10:40 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
And I'm positive I missed a few. I think the 426 Hemi had two cams as well but just can't recall.
Accountants hate part numbers, I bet they were positively bezerk back then based on my time working for Mopar in the 80's.
Reduction in part numbers to increase the profit margins and save money was a constant mantra.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: lewtot184] #3105633
12/26/22 10:49 AM
12/26/22 10:49 AM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
As small was Chrysler is to the other 2 they had a DQ intake for all 3 early Hemi's, the Poly, both low deck and tall deck B, Crossrams long,short and 1 pc and 426H intakes I would think they would have had it figured out as good as anyone and better than most.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: gdonovan] #3105921
12/27/22 02:38 PM
12/27/22 02:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
318
340 6-pack
383 2 bbl
383 4bbl
383 HP
440 4bbl
440 HP
440 6 pack
426 hemi
You think that is bad how about ford? They had twice as many different engines, often 2 or 3 of the same size that were totally different engines with nothing interchangeable between them... talk about a cluster! GM wasn't much better with different engines for buick olds pontiac cadilac chevrolet... all getting their own engines and sharing engines sometimes. Chrysler had like 3.5 engine families in total thru the 60s and 70s
Re: Why didnt Mopar offer the 440 with dual quads? [Re: HotRodDave] #3105968
12/27/22 05:19 PM
12/27/22 05:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I love multi-carb anything. I have always wanted a 440 dual quad intake. I currently have a sixpack car, a tunnel ram with two 1050's Hemi car, a 383/400 sixpack, a 340 sixpack, two dual four street Hemi intakes and carbs, a cross ram max Wedge and a magnesium cross ram Hemi also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Why didnt Mopar offer the 440 with dual quads? [Re: AndyF] #3105971
12/27/22 06:01 PM
12/27/22 06:01 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
FCA has no interest in "heritage" engine platforms anymore. When they do have something like an intake for them, all they do is rebrand someone else's product and mark it up 30%. mad
I refuse to put anything with the Mopar Performance or Direct Connection logo on my car!
'63 Dodge 330
11.19 @ 121 mph
Page 3 of 4 1 2 3 4
