Re: Recommendations on clutches
[Re: fastmark]
#3107147
01/01/23 07:10 AM
01/01/23 07:10 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&D for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch. All of these applications were designed by the factory to work with a diaphragm clutch and all the linkages worked with them. The older muscle cars linkage rates were designed for the Borg and Beck. That’s all I don’t like about them. I’ve driven several with them Centerforce and they work, just not the same as the original design Borg and Beck. Different preferences for different people. I understand all that. Some are saying that the diaphragm clutch is just a poor design but yet most everything made in the last 30 years uses a diaphragm clutch. Why isn't everything using a B&B? I'm not dissing to B&B. I've used a lot of them and will use more of them.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#3107164
01/01/23 10:14 AM
01/01/23 10:14 AM
Posts: 1,996 Apollo, PA.
B1MAXX
Apollo, PA.
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&B for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch. because of cost savings, they are a cheaper product.
[Re: B1MAXX]
#3107173
01/01/23 10:46 AM
01/01/23 10:46 AM
Posts: 6,291 nowhere
Sniper
nowhere
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&B for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch. because of cost savings, they are a cheaper product. They are a better product. Better clamping force for less pedal pressure.
[Re: Sniper]
#3107177
01/01/23 11:03 AM
01/01/23 11:03 AM
B1MAXX
Apollo, PA.
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&B for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch. because of cost savings, they are a cheaper product. They are a better product. Better clamping force for less pedal pressure. ???????? How many parts are in a diaphragm?, what does the clamping? How are diaphragm clutch kits under 100 bucks (some well under, even BB Chevy apps), including pressure plate, disc, throw out bearing, and fork. You cant get a B&B plate alone for under 100. This is ridiculous.
[Re: B1MAXX]
#3107442
01/02/23 09:54 AM
01/02/23 09:54 AM
Posts: 181 Ontario Canada
Bennoel 10
Ontario Canada
So if the diaphragm clutch is such a poor setup why did Chrysler pretty much ditch the B&B for the diaphragm in the 80's? My 87 D150, 91 CTD and 98 Dakota all came with a diaphragm clutch. because of cost savings, they are a cheaper product. They are a better product. Better clamping force for less pedal pressure. ???????? How many parts are in a diaphragm?, what does the clamping? How are diaphragm clutch kits under 100 bucks (some well under, even BB Chevy apps), including pressure plate, disc, throw out bearing, and fork. You cant get a B&B plate alone for under 100. This is ridiculous. Maybe because they produce diaphragm style for the millions of chevy's out there and as we know they get cheaper the more that are produced. Not saying I'm correct just another opinion and we know what they're like.
