i have done the re-hoop process quite a few times, to different styles of wheels using steel hoops and aluminum centers, as well as making different offset or width steel wheels.
it's quite labor intensive, and requires superb welding skills, a large enough lathe to be able to machine a hoop or center to the correct press fit id/od, a way to straighten and true the wheel, plus exact measuring instruments/machinist tools.
i'm not sure what you are trying to do with the wheels shown, but if you are truing to restore them, in my humble opinion, you would be way ahead to find pristine examples and pony up the price for them.
chroming these days is not cheap, nor is restoring those aluminum centers.
i will go out on a limb here by saying you would have twice, at a minimum, the money into those wheels restoring them instead of buying reproductions or excellent condition originals.
so with that said, blasting, straightening [if possible], then painting or powder coating what you have, may be an alternative ? providing the centers are not cracked.
just my opinion and life experience with wheels of all kinds.
your mileage will vary.
