Page 1 of 4 1 2 3 4
Recommendations on clutches #3103998
12/20/22 04:14 PM
12/20/22 04:14 PM
High Plains of South Dakota
O
olwhite64 Offline OP
O
I took apart my 71 RR clone as it has a severe rear main seal leak; no surprise the clutch is also soaked and in my opinion, now useless.
Looking for recommendations on a replacement. It is currently a 10.5" B&B with a McLeod disc. Engine is a bone stock '71 440, 23 spline 833, 8 3/4" rear w/ 3.55 gears. I run radial T/A's on the car, size 275/60/15 - this really is a street car that will never see slicks.
I do want something that will bite though as I do pound on it - recommendations Gents?
Re: Recommendations on clutches [Re: olwhite64] #3104044
12/20/22 06:55 PM
12/20/22 06:55 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
I would go Centerforce.
Re: Recommendations on clutches [Re: olwhite64] #3104059
12/20/22 07:46 PM
12/20/22 07:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If U want to replace it with a Borg Beck pressure plate, there are only (2) suppliers Hays and Ram clutches..
Just my $0.02... wink
Re: Recommendations on clutches [Re: Ramrod39] #3104063
12/20/22 07:57 PM
12/20/22 07:57 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
. X 2. Dual friction.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Recommendations on clutches [Re: 68LAR] #3104099
12/20/22 09:35 PM
12/20/22 09:35 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
X3. I've had one behind a low deck stroker in my street toy for years....zero issues.
Re: Recommendations on clutches [Re: Dcuda69] #3104176
12/21/22 07:26 AM
12/21/22 07:26 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve installed one McLeod diaphragm type in a 70 RR. The release rate was terrible. It was light sure enough. That’s what the lady wanted. It was too fast and you could not slowly release it so the car was not smooth. I’ve talked to McLeod about is and there is nothing they can do about that. I had another customer with a 69 Bee. It already had a Centerforce diaphragm. It was better but not by much. Another friend bought a brand new Centerforce and hated it so bad, he install a parts store Borg and Beck style. It’s much better he says. My last build had a Centerforce in the car when it got to the shop. It was fair but same issue. The release rate is off from stock Mopar. A diaphragm clutch is a Chevy design. It’s just a different release rate. So this last customer bought a Ram Borg and Beck. He loves it. I drove it. It works like a Mopar clutch should. Now the absolute best clutch I’ve ever driven is a McLeod twin disc that was the Long style fingers. It is as smooth as butter, not hard to push down, the release point is perfect and best of all, it holds a 680 HP hemi! It is a little pricey. So my vote is for the Mopar style Borg and Beck from Ram.
Re: Recommendations on clutches [Re: olwhite64] #3104184
12/21/22 09:22 AM
12/21/22 09:22 AM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
We use the Ram Powergrip HD's and they take some abuse. I saw a brand new Centerforce have the pedal go to the floor on the fourth pass of a mid-13 second car on polyglas tires this fall...
Re: Recommendations on clutches [Re: 83hurstguy] #3104193
12/21/22 10:09 AM
12/21/22 10:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ran Mc Cleod for years.Then went center force.Will never go back to another.Mines been in for years now and still like new.Only time Ive seen people have problems is not setup or broke in correct.That and many are still used to having a ton of leg pressure
Chrysler Firepower
Re: Recommendations on clutches [Re: 83hurstguy] #3104205
12/21/22 10:57 AM
12/21/22 10:57 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
They do that with the over center spring still in place. Funny action until you get that out of there. Can’t adjust it to work right, goes to floor. All of that.
I want my fair share
Re: Recommendations on clutches [Re: fastmark] #3104263
12/21/22 02:54 PM
12/21/22 02:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Over the years we have run different brand clutches in our RoadRunner...
Hays, CenterForce, McLeod..
The best one for endurance was the McLeod, worst was the CenterForce.
Then last year we changed out the 4-speed to an manual w/overdrive, and since we had the drive train apart we decided to install a new clutch pressure plate, disk and flywheel. But found out that McLeod no longer supplied a Borg Beck pressure plate so we talked with Ram and they put together a mixed kit and install went fine. All is well, clutch grabs good, reasonable pedal pressure.
Re: Recommendations on clutches [Re: Sinitro] #3104284
12/21/22 04:29 PM
12/21/22 04:29 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I would call Rochester Clutch and Brake, Rochester NY and get a custom 10.95 with a 6 puck disk
Re: Recommendations on clutches [Re: olwhite64] #3104375
12/21/22 10:45 PM
12/21/22 10:45 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
have installed MNAY C/F Dual frictions in customers car in 25 or so years, One problem. A mis sized disc to PP.
So I say CF beer
Re: Recommendations on clutches [Re: olwhite64] #3104543
12/22/22 12:57 PM
12/22/22 12:57 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just one thing, dual friction clutch dics hate stop and go driving.
Re: Recommendations on clutches [Re: fastmark] #3104550
12/22/22 01:09 PM
12/22/22 01:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
X2 on the McLeod Twin Disc. Icing on the cake is the American Powertrain Hydraulic throw-out bearing set-up. Never had much luck with anything else, and the sintered puck clutches I tried chattered very bad on release.
Re: Recommendations on clutches [Re: olwhite64] #3104589
12/22/22 03:29 PM
12/22/22 03:29 PM
If you do switch to a diaphragm type pressure plate, make sure and remove the over center spring on the clutch pedal under the dash scope wrench up
Re: Recommendations on clutches [Re: Cab_Burge] #3104621
12/22/22 05:06 PM
12/22/22 05:06 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I will NEVER again use a diaphram Chivvy type clutch, borg and beck or give me death... tsk
JB Rhinehart, Realist
A-Body's RULE!
Re: Recommendations on clutches [Re: Rhinodart] #3104642
12/22/22 06:20 PM
12/22/22 06:20 PM
How about Long (Ford) style?
Re: Recommendations on clutches [Re: Cab_Burge] #3104645
12/22/22 06:26 PM
12/22/22 06:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Never had a problem with diaphragm clutches, they were factory on a lot of Mopars BTW, nor have I ever had to remove the over center spring. But then again, I do not use the pedal free play method of setting up the clutch either. I use plate departure and go for .060" of a gap with the pedal to the floor.
Re: Recommendations on clutches [Re: Cab_Burge] #3104655
12/22/22 06:58 PM
12/22/22 06:58 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Long is still a three finger style, no issue with it! Don't know why people want a weak diaphram style, I am just old school I guess, never had an issue with a B&B...
A-Body's RULE!
Re: Recommendations on clutches [Re: Rhinodart] #3104747
12/22/22 11:51 PM
12/22/22 11:51 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
At 68 I too am Old school but after my first C/F install I started asking myself why i needed my L leg to be so much bigger LOL. Then there was repairing reinforcing the frame pivots etc. I finally caved and the customers have been very happy with them beer
Page 1 of 4 1 2 3 4
