Page 4 of 4 1 2 3 4
Re: Quest for 1000 hp, slow going! [Re: 440Jim] #3104572
12/22/22 02:08 PM
12/22/22 02:08 PM
NC
440Jim Offline
440Jim  Offline
NC
Those 572-13 exhaust ports look much bigger than 440-1.
What size are yours ?
Re: Quest for 1000 hp, slow going! [Re: 440Jim] #3104728
12/22/22 10:25 PM
12/22/22 10:25 PM
gregsdart Offline OP
Thanks Dwayne! I sure hope it does!
Jim, my header flanges are for the 572-13 heads, and gaskets will be fit to the ports if need be.
Re: Quest for 1000 hp, slow going! [Re: 440Jim] #3104815
12/23/22 09:43 AM
12/23/22 09:43 AM
Good to hear. up
I look forward to the dyno numbers.
As you said, don't forget that rear cam plug...
From your other thread/topic you decided to build the 550 CID not the 580, right?
Quote
4.504 bore, 550 CID
4.315 stroke crank from Crower, with center counter weights.
Block is an aluminum BMP 4.5ā€ bore, new block.
The heads are 572-13 385cc, with additional work by Larry Smith. Intake is a 3X, reworked by Wilson manifolds. Compression will be 14.6 with 550 cubes. Cam will be the 0.868 lift roller, 285/296/113 @ 50
Yes Jim i decided to go with the center weighted crank and less stroke. My main thought was the weight of the 580 rotating assembly. I hope the CW crank will produce less bore distortion and provide better ring seal as a result. The thought just crossed my mind, how many new v8 performance motors have center weighted cranks? I bet almost all.
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3104885
12/23/22 01:24 PM
12/23/22 01:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Greg glad to see you are back at it and getting close..
As for CCW cranks look at any professional race engine in any racing series From F1 to WOO to Trophy Truck and you will find them in every engine. You main bearings and caps will thank you...
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3104907
12/23/22 02:20 PM
12/23/22 02:20 PM
NC
440Jim Offline
440Jim  Offline
NC
I have notes on several intake port sizes, but not much on exhaust ports. Some port jobs will be a little different, too. I was going to compare your finished exhaust port dimensions (572-13 CNC 385) to what the guy put on my B1 heads.
Originally Posted by "various"
Intake port openings:
1.260 x 2.300 Indy SR (gasket 440-212) Indy website
1.340 x 2.630 Max Wedge (Felpro gasket)
1.340 x 2.650 Indy 440-1 (gasket 440-216) Indy website, for their intake manifold gaskets 3.55sqin
1.375 x 2.650 Indy 440-1 (CNC 345), 3.64sqin-0.335 corners 3.31
1.475 x 2.700 Indy 572-13 (gasket 440-218) Indy website, for their intake manifold gaskets 3.98sqin
1.600 x 2.660 B1 original (from gaskets bought from Koffel's Place) 4.25sqin
1.750 x 2.730 Jim's B1 originals CNC ported (previous owner, unknown shop) 4.78sqin-0.335 corners 4.44sqin
1.835 x 2.050 Indy Hemi (gasket 426-258) 3.76sqin
Exhaust ports:
1.550 x 1.960 Indy 440-1 (CNC 345), 3.04sqin-0.335 corners 2.70
1.xx x X.xx Indy 572-13 (CNC 385), sqin
X. xx X.xx B1 original (from ) sqin
1.710 x 2.070 Jim's B1 originals CNC ported 3.54 sqin, 3.206 sqin (curved sides)
Re: Quest for 1000 hp, slow going! [Re: Al_Alguire] #3104916
12/23/22 02:56 PM
12/23/22 02:56 PM
Thanks Al. Once i quit overthinking it, the cw crank was the only choice. Your comments carried a lot of weight. On top of it being easier on bearings and crank, i assume it is much better for an aluminum motor.
Re: Quest for 1000 hp, slow going! [Re: 440Jim] #3104965
12/23/22 05:41 PM
12/23/22 05:41 PM
Exhaust ports:
Jim, 572-13, 1.90 wide, 1.60 tall.
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3105053
12/23/22 09:35 PM
12/23/22 09:35 PM
The rest is easy, right? Well. Not quite. The Jesel belt drive spaced out the crank trigger pickup bracket. No oroblem. Make a spacer, done. BUT the injection pump is now interfering with the extra oil line for the dual pickup system. And i have no idea why the 255 mm belt that drives it is now too tight.
That port in the block right by the 2nd line i believe is for use with that line? Anyone know what fitting goes with that port? It isn't pipe thread. Uses an O ring and straight threads. I ordered a fitting to extend out farther from the pump so maybe the 2nd oil line can then fit in front of the fuel pump to tank line .
Trouble is, that fitting won't get hear till January. So , i plan on capping the 2nd line if i have to to get this thing on the dyno.
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3105107
12/24/22 03:08 AM
12/24/22 03:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW Ihave never run a dual line just singles for me. Current engines are both -16 singles except the blue car which is a single -12
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3105142
12/24/22 10:02 AM
12/24/22 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
It is AN-12 straight thread O-ring. This is my labeled block hardware for the BMP aluminum block.
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3105161
12/24/22 11:16 AM
12/24/22 11:16 AM
Mooresburg, Tn
'72CudaRacer Online content
Happy Birthday '72CudaRacer  Online Content
Mooresburg, Tn
[quote=gregsdart]The rest is easy, right? Well. Not quite. The Jesel belt drive spaced out the crank trigger pickup bracket. No problem. Make a spacer, done. BUT the injection pump is now interfering with the extra oil line for the dual pickup system. And i have no idea why the 255 mm belt that drives it is now too tight [quote]
This year while working at a race engine shop I have installed 5 Blower Shop "baby blowers" on big BBC engines, all over 600 ci. Some were iron blocks, some alum, all were after market. Each one was just a little different. The blowers and related parts (pulleys, brackets, ect.) were mostly bolt on, but when it came to vacuum pumps, fuel pumps, water pumps, crank triggers and plumbing for each, that was a different song. And, with most of them going into dragster chassis, I had to be mindful of the radiator clearance up front.
Easy, bolt on. Yeah, right!
Brian
Re: Quest for 1000 hp, slow going! [Re: '72CudaRacer] #3105244
12/24/22 02:55 PM
12/24/22 02:55 PM
moparx Offline
moparx  Offline
i didn't think there was such a thing as a "bolt on part". laugh2
beer
Re: Quest for 1000 hp, slow going! [Re: moparx] #3105248
12/24/22 03:13 PM
12/24/22 03:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
beer
Only on the assembly line, most of the time whistling
Re: Quest for 1000 hp, slow going! [Re: Cab_Burge] #3105367
12/25/22 04:27 AM
12/25/22 04:27 AM
https://photos.app.goo.gl/4tCuwodqqSj7joLbA
A little massaging on the fuelpump bracket got me what i needed for clearance for belt tension. I was able to run the second line under the oil pump body, allowing room for my injection pump. Luckily i didn't tear much hair out in frustrationšŸ˜Š i don't want to lose any more! So now i am very close. Bolt the waterpump and hoses on, put a lifting plate on the intake manifold, install the rear cam plug. Wait for R&R to open monday to get a dyno time!
Re: Quest for 1000 hp, slow going! [Re: gregsdart] #3105386
12/25/22 09:55 AM
12/25/22 09:55 AM
NC
440Jim Offline
440Jim  Offline
NC
Good work. Saved from using more AN-12 hose.
Re: Quest for 1000 hp, slow going! [Re: 440Jim] #3106170
12/28/22 05:46 PM
12/28/22 05:46 PM
Dyno day is jan4, 8am to? I am starting a thread on what hp will it make?
Page 4 of 4 1 2 3 4
