5.7 hemi into a 67 dart. ??? #3104134
12/20/22 10:49 PM
12/20/22 10:49 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I've been searching for info on throwing a 2007 hemi in my dart. The hemi was meant for my 55 dodge pickup, but moving the firewall back 6 inches is gonna kill legroom. So i'm thinking about finding a v-6 for the truck and using the hemi and trans in the dart. Any info on what i'm gonna run into in the swap?
Thanks in advance. Kevin
Re: 5.7 hemi into a 67 dart. ??? [Re: dart67] #3104384
12/21/22 11:05 PM
12/21/22 11:05 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
We did one in 2007 and used an Alter-K-Tion K-frame, Imagine injection, and a Rocky Mountain dash with all the factory wiring. I have seen others with a completely stock 5.7, most people I know that did it used a truck engine...
JB Rhinehart, Realist
A-Body's RULE!
Re: 5.7 hemi into a 67 dart. ??? [Re: Rhinodart] #3104399
12/22/22 12:02 AM
12/22/22 12:02 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mopar Action is doing a series on that starting with the current issue.
2014 5.7 & 727 (?) into a '69 Dart.
Re: 5.7 hemi into a 67 dart. ??? [Re: topside] #3104619
12/22/22 05:01 PM
12/22/22 05:01 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Thank you!
Re: 5.7 hemi into a 67 dart. ??? [Re: dart67] #3104696
12/22/22 08:51 PM
12/22/22 08:51 PM
GA
roadrunninMark Offline
GA
Yes, they are using Holley mounts and such. Moves the engine forward 1.5" I think and there is a new front timing cover so the alt doesn't hit the frame rail. I wish they would keep the modern auto in the 1 instead of using a 727 though. I realize it would cost quite a bit more but the modern trans is much better for cruising. If only racing, then I can see saving the bucks.
