PerTronix wiring
#3104008
12/20/22 04:40 PM
12/20/22 04:40 PM
Posts: 727 Falcon, CO
71pettyblue
Falcon, CO
The owner of a 1967 RT that I have been working on, asked me to install a PerTronix conversion kit in the stock distributor. The instructions call for bypassing the ballast resistor. I'm sure some members have done this before. What is the best way to wire the red wire to 12 volts?
Several years ago I had suggested to using a MOPAR electronic ignition setup, but he wanted to keep his car/engine stock. Thanks, Tony
Tony Retired Mopar Enthusiast
Re: PerTronix wiring
[Re: 71pettyblue]
#3104130
12/20/22 10:28 PM
12/20/22 10:28 PM
71pettyblue
Falcon, CO
I modified a new ballast and replaced the resistor with a solid 14g wire. I sealed the wire and tested the continuity. Thanks guys, that was an easy modification. Tony
[Re: 71pettyblue]
#3104229
12/21/22 12:24 PM
12/21/22 12:24 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
I modified a new ballast and replaced the resistor with a solid 14g wire. I sealed the wire and tested the continuity. Thanks guys, that was an easy modification. Tony Also what I did on my RR Dang she runs a lot better.....which shows I suck at setting points.... lol
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
