Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: Fat_Mike] #3108340
01/04/23 04:28 AM
01/04/23 04:28 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I bought mine from the dealer.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: mopars4ever] #3108478
01/04/23 03:28 PM
01/04/23 03:28 PM
moparx Offline
moparx  Offline
i had a belt squeal on my caravan that drove me nutz,,,,,,,,,,
replaced all the pulleys and the tensioner. also used the gates belt.
checked pulley alignment, bearings in the water pump, alternator, and power steering pump. all were good.
as a last resort, i spritzed the belt while running with one of those belt quiet sprays, and to my amazement, it has been quiet for over a year and a half.
i have no clue why those spritzes worked, as the belt was not glazed, nor were any of the pulleys. so who knows ? shruggy
beer
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3108575
01/04/23 07:34 PM
01/04/23 07:34 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Originally Posted by WarEagle1
I can't isolate this squeaking/chirping, bird-like noise at idle on an '08 Aspen, 5.7L. Only hear it after it warms up and it gets worse with some load (a/c on or sawing the wheel back and forth). It goes away at anything above idle.
I thought I had it isolated to the tensioner pulley. Changed it; didn't help. Have since changed both idler pulleys and the belt; no change. Everything felt smooth, 'normal' with the belt off.
I can't seem to isolate it with a stethoscope. Any ideas on which bearing/accessory would be most likely?
Thanks!
Put some comet kitchen cleaner dust on the belt. If the noise is gone its the belt.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: MoonshineMattK] #3115776
01/23/23 06:46 PM
01/23/23 06:46 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
Thanks for all of the replies. Wanted to close this out. Dug back into it and found some play in the water pump bearing. Replaced pump and all is well. Never would have guessed it from the sound. Live and learn. Thanks again to all.
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: WarEagle1] #3116029
01/24/23 02:04 PM
01/24/23 02:04 PM
moparx Offline
moparx  Offline
glad to hear it was a relatively simple fix. up
beer
Re: Squeaking/chirping in belt drive area - 5.7 Hemi [Re: moparx] #3116423
01/25/23 02:24 PM
01/25/23 02:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Good to know. Thanks for getting back to us on it.
