I too would like to swap out the interior of my '12 ram reg cab. Who ever thought black and puke would look good together? Yuck
Well I ended up just swapping the dash plastic and it was a bolt in but I had to use my original grey bezels instead of the chrome ones because the center one is longer at the bottom to work with the console in the donor truck. It is a very dark dash and easier to see without the light puke color in the sun. I also added the second glove box into the cubbie hole, it would be a very easy upgrade without tearing apart the dash.
The wiring harness was different because of the dual zone HVAC and the radio, I hate dual zone HVAC and didn't feel like rewiring the whole truck just to find out "if" I could make it all work. I would have had to add wires to the truck harness for all the speakers and the sub under the rear seat as there is no wires in the rest of the truck for them. The blend air doors were fine but there was a big weird piece of metal holding one from moving very much and the motor gears were stripped out from trying to force that door to move. The evaporator was almost complexly blocking airflow with dirt and dog hair and now the heat will flat roast you out of there in short order where before I could have it on high all day and never get hot.
My only problem is the trailer brake randomly reminds me it is disconnected for no reason where before it would only do that if I had unplugged it with it running.
