Re: Ever put an NP435 in a car?
[Re: 73DAD]
#3102646
12/15/22 06:54 PM
12/15/22 06:54 PM
Posts: 10,183 A Red State
SNK-EYZ
A Red State
If you were simply using the drivetrain because you already have it, it would be great for an old truck or a 50's era car (full frame) that has lots of floor pan/trans tunnel room.
Anything else, the trans is a poor choice.
[Re: SNK-EYZ]
#3102649
12/15/22 07:04 PM
12/15/22 07:04 PM
Posts: 6,355 nowhere
Sniper
nowhere
Anything else, the trans is a poor choice. It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton.
[Re: Sniper]
#3102665
12/15/22 07:35 PM
12/15/22 07:35 PM
SNK-EYZ
A Red State
Anything else, the trans is a poor choice. It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton. It worked in a truck before so exactly why wouldn't it still work in a an older truck now????? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) No one said it was the best choice, it's a case of using what they already have and putting it to use. Why is that so hard to comprehend?????
[Re: SNK-EYZ]
#3102679
12/15/22 08:38 PM
12/15/22 08:38 PM
Sniper
nowhere
Anything else, the trans is a poor choice. It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton. It worked in a truck before so exactly why wouldn't it still work in a an older truck now????? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) No one said it was the best choice, it's a case of using what they already have and putting it to use. Why is that so hard to comprehend????? What's hard to comprehend, for you, is that I specified a CAR.
[Re: Sniper]
#3102767
12/16/22 06:28 AM
12/16/22 06:28 AM
SNK-EYZ
A Red State
Anything else, the trans is a poor choice. It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton. It worked in a truck before so exactly why wouldn't it still work in a an older truck now????? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) No one said it was the best choice, it's a case of using what they already have and putting it to use. Why is that so hard to comprehend????? What's hard to comprehend, for you, is that I specified a CAR. What's hard for you to comprehend is that it would work fine in a 50's or older car just fine. Is it ideal, no and that has been stated but you're so busy trying to be a d*ck that you can't comprehend that people don't always do things the way that YOU think they should. It's just like most of your other posts, there's your way of doing things and no others should be considered or allowed. What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Someone is trying to use what they already have, why is that so bad????????????? Not everyone builds high dollar perfect cars. Last thing I knew, that's what hot rodding was all about, build something and have fun doing it. I think that the fun went out of it for you a long time ago.
[Re: SNK-EYZ]
#3102951
12/16/22 06:35 PM
12/16/22 06:35 PM
Sniper
nowhere
What's hard for you to comprehend is that it would work fine in a 50's or older car just fine. Owning a 51 Plymouth, you are wrong. Is it ideal, no and that has been stated but you're so busy trying to be a d*ck that you can't comprehend that people don't always do things the way that YOU think they should. Right, comprehension issues for you, once again. All I did was lay put why the NP465 is a bad choice. It's just like most of your other posts, there's your way of doing things and no others should be considered or allowed. What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Someone is trying to use what they already have, why is that so bad????????????? Not everyone builds high dollar perfect cars. Last thing I knew, that's what hot rodding was all about, build something and have fun doing it. I think that the fun went out of it for you a long time ago. A bad idea is a bad idea, only a fool encourages it and a friend points out the issues. Take from that what you will.
[Re: Sniper]
#3102985
12/16/22 09:43 PM
12/16/22 09:43 PM
SNK-EYZ
A Red State
What's hard for you to comprehend is that it would work fine in a 50's or older car just fine. Owning a 51 Plymouth, you are wrong. Is it ideal, no and that has been stated but you're so busy trying to be a d*ck that you can't comprehend that people don't always do things the way that YOU think they should. Right, comprehension issues for you, once again. All I did was lay put why the NP465 is a bad choice. It's just like most of your other posts, there's your way of doing things and no others should be considered or allowed. What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Someone is trying to use what they already have, why is that so bad????????????? Not everyone builds high dollar perfect cars. Last thing I knew, that's what hot rodding was all about, build something and have fun doing it. I think that the fun went out of it for you a long time ago. A bad idea is a bad idea, only a fool encourages it and a friend points out the issues. Take from that what you will. A fool is someone who thinks only his way is the right and only way to do things. A friend??? Someone who acts like a d*ck in most of his posts isn't a actually friend to anyone. You just think that your opinion is more important than anyone elses. You're to blinded by yourself and your opinions to see that people can build cars with parts that aren't necessarily the best choice but are doing it because of cost or that they simply already have the parts. The OP was looking for a use for the drivetrain and everyone agrees that it's not the choice for a 60's and newer Mopar but it will work in a truck and could work but not be ideal in older stuff. Just because YOU think that you're right doesn't actually make it so. I ask again, What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) You should actually read and comprehend your posts with the eye and perspective of someone other than yourself. Take from that what you will. Are you sure you're not a BMW driver? They all seem to be d*cks all of the time. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: Hugh Jorgan]
#3103005
12/16/22 11:03 PM
12/16/22 11:03 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Yikes
So... per the original question, I guess that's a 'no'. Nobody has seen or put one in a car. No. The 435 has a yoke on the tail end requiring a carrier bearing between the 2 driveshafts. Might be a trick in a car. He could use a 4wd truck driveshaft that has a slip yoke.
[Re: SNK-EYZ]
#3103053
12/17/22 10:38 AM
12/17/22 10:38 AM
Sniper
nowhere
What's hard for you to comprehend is that it would work fine in a 50's or older car just fine. Owning a 51 Plymouth, you are wrong. Is it ideal, no and that has been stated but you're so busy trying to be a d*ck that you can't comprehend that people don't always do things the way that YOU think they should. Right, comprehension issues for you, once again. All I did was lay put why the NP465 is a bad choice. It's just like most of your other posts, there's your way of doing things and no others should be considered or allowed. What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Someone is trying to use what they already have, why is that so bad????????????? Not everyone builds high dollar perfect cars. Last thing I knew, that's what hot rodding was all about, build something and have fun doing it. I think that the fun went out of it for you a long time ago. A bad idea is a bad idea, only a fool encourages it and a friend points out the issues. Take from that what you will. A fool is someone who thinks only his way is the right and only way to do things. A friend??? Someone who acts like a d*ck in most of his posts isn't a actually friend to anyone. You just think that your opinion is more important than anyone elses. You're to blinded by yourself and your opinions to see that people can build cars with parts that aren't necessarily the best choice but are doing it because of cost or that they simply already have the parts. The OP was looking for a use for the drivetrain and everyone agrees that it's not the choice for a 60's and newer Mopar but it will work in a truck and could work but not be ideal in older stuff. Just because YOU think that you're right doesn't actually make it so. I ask again, What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) You should actually read and comprehend your posts with the eye and perspective of someone other than yourself. Take from that what you will. Are you sure you're not a BMW driver? They all seem to be d*cks all of the time. You are the only one saying to do it. The fool looks back at you from your mirror and frankly I don't care what a fool thinks.
[Re: Sniper]
#3103142
12/17/22 04:37 PM
12/17/22 04:37 PM
SNK-EYZ
A Red State
You obviously have serious reading comprehension problems. I NEVER said that he should do it. I said it was possible, but you're so much of a self center "I'm always right D*CK" that you see only what you want to see. A d*ck that has problems with reading comprehension describes you perfectly. I ask again, What put that giant chip on your shoulder???? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) I don't expect that you'll answer that, especially since you think that the problem is always with everyone else. Maybe you should do some self reflection, but I don't see that happening either.
