Dumb Question...Electric Water Pump Newbie
#3103334
12/18/22 02:14 PM
12/18/22 02:14 PM
Posts: 161 W. Pa
usp4u
W. Pa
I'm doing a "leak check" on my first R3/W8 build. Using a short deck Arrow timing cover, and a Meziere pump. I am also using external water input through the center freeze plugs. This is my first electric water pump build.
This pump is used although I was told it is a low hour unit when I got it nearly 5 years ago.
I began by pre-filling the engine through the upper hose, and filling a wash-tub. It should be noted that this water reservoir is about 1 foot lower than the water pump itself.
I placed the lower hose into the tub and tied the upper hose in a fashion that would allow it to discharge back into the wash tub.
I connected the pump to a Snap-On large jump pak as a power source. I cannot pick up a prime with the pump. I can hear the pump running, and a few times it sounded like it was "catching a prime" due to a change in tone, though that was only momentary.
Am I wrong thinking the pump should be able to pull the water from the tub, or do these pumps require an elevated/closed loop to allow the weight of water to aide its function?
I have verified block filling by pulling the lower drain plugs in the block.
Re: Dumb Question...Electric Water Pump Newbie
[Re: NITROUSN]
#3103338
12/18/22 02:22 PM
12/18/22 02:22 PM
Posts: 161 W. Pa
usp4u
W. Pa
It needs to be in water to work. The lower hose was submerged. Im assuming you mean that it needs a closed system and that I should rig up a type of circular reservoir/rad to complete the system?
[Re: usp4u]
#3103360
12/18/22 03:23 PM
12/18/22 03:23 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3103367
12/18/22 04:31 PM
12/18/22 04:31 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
I know a guy witha Ford Windsor , he had to drill and tap a small blleeder into his elec waterpump to be able to bleed/prime it . Nothing else would do .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3103392
12/18/22 06:17 PM
12/18/22 06:17 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
Did you try reversing the leads on the jump pack? It may be running the pump backwards.
[Re: usp4u]
#3103427
12/18/22 08:59 PM
12/18/22 08:59 PM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
It needs to be in water to work. The lower hose was submerged. Im assuming you mean that it needs a closed system and that I should rig up a type of circular reservoir/rad to complete the system? you need to have the level up into or over the impeller. Otherwise all you got is an air pump.
