Ever put an NP435 in a car? #3102596
12/15/22 04:07 PM
12/15/22 04:07 PM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
My truck has one and as the truck deteriorates I often wonder what it would be like to pluck the drivetrain for a car. There are plenty of unloved rusty b-body rollers in my area, plenty of 50's Mopars too.
Has anyone ever seen or put an NP435 in a car?
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102608
12/15/22 04:48 PM
12/15/22 04:48 PM
moparx Offline
moparx  Offline
if that transmission is the one with the "granny" 1st gear, i think it would require tunnel modifications because it's so big.
the granny gear would only be useful in super slow traffic, and that's a BIG maybe............
beer
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102615
12/15/22 05:03 PM
12/15/22 05:03 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
If you are not making much power a used T5 might be the cheapest easiest way to a 5spd OD
Re: Ever put an NP435 in a car? [Re: MoonshineMattK] #3102636
12/15/22 06:20 PM
12/15/22 06:20 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I am sure you could make fit,but thats a huge trans meant for a truck,would need a lot of fabrication.
Re: Ever put an NP435 in a car? [Re: GarageDodge] #3102643
12/15/22 06:38 PM
12/15/22 06:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If i were to consider the worst possible choice for a 4 speed in a car the NP435 would be in the top 2.
It's a great truck 4 speed and that is where it's virtues end.
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102646
12/15/22 06:54 PM
12/15/22 06:54 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
If you were simply using the drivetrain because you already have it, it would be great for an old truck or a 50's era car (full frame) that has lots of floor pan/trans tunnel room.
Anything else, the trans is a poor choice.
Re: Ever put an NP435 in a car? [Re: SNK-EYZ] #3102649
12/15/22 07:04 PM
12/15/22 07:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It is not a matter of room, it is a matter of poor gear ratios, really wide spreads and clunky shifting. Not to mention is weights a ton.
Re: Ever put an NP435 in a car? [Re: Sniper] #3102665
12/15/22 07:35 PM
12/15/22 07:35 PM
A Red State
A Red State
It worked in a truck before so exactly why wouldn't it still work in a an older truck now????? laugh2
No one said it was the best choice, it's a case of using what they already have and putting it to use.
Why is that so hard to comprehend?????
Re: Ever put an NP435 in a car? [Re: SNK-EYZ] #3102679
12/15/22 08:38 PM
12/15/22 08:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What's hard to comprehend, for you, is that I specified a CAR.
Re: Ever put an NP435 in a car? [Re: Sniper] #3102767
12/16/22 06:28 AM
12/16/22 06:28 AM
A Red State
A Red State
What's hard for you to comprehend is that it would work fine in a 50's or older car just fine.
Is it ideal, no and that has been stated but you're so busy trying to be a d*ck that you can't comprehend that people don't always do things the way that YOU think they should.
It's just like most of your other posts, there's your way of doing things and no others should be considered or allowed.
What put that giant chip on your shoulder???? laugh2
Someone is trying to use what they already have, why is that so bad?????????????
Not everyone builds high dollar perfect cars.
Last thing I knew, that's what hot rodding was all about, build something and have fun doing it.
I think that the fun went out of it for you a long time ago.
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102795
12/16/22 10:34 AM
12/16/22 10:34 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
Yikes
So... per the original question, I guess that's a 'no'. Nobody has seen or put one in a car.
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102931
12/16/22 05:11 PM
12/16/22 05:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Never seen one in a car but you could have some ground clearance issues because that 435 has more hanging down low than an 833. Probably hang lower that your headers twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Ever put an NP435 in a car? [Re: SNK-EYZ] #3102951
12/16/22 06:35 PM
12/16/22 06:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Quote
Owning a 51 Plymouth, you are wrong.
Quote
Right, comprehension issues for you, once again. All I did was lay put why the NP465 is a bad choice.
A bad idea is a bad idea, only a fool encourages it and a friend points out the issues. Take from that what you will.
Re: Ever put an NP435 in a car? [Re: 73DAD] #3102966
12/16/22 08:12 PM
12/16/22 08:12 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Originally Posted by 73DAD
Yikes
No. The 435 has a yoke on the tail end requiring a carrier bearing between the 2 driveshafts. Might be a trick in a car. twocents
Re: Ever put an NP435 in a car? [Re: Sniper] #3102985
12/16/22 09:43 PM
12/16/22 09:43 PM
A Red State
A Red State
Quote
Quote
A fool is someone who thinks only his way is the right and only way to do things.
A friend??? Someone who acts like a d*ck in most of his posts isn't a actually friend to anyone.
You just think that your opinion is more important than anyone elses.
You're to blinded by yourself and your opinions to see that people can build cars with parts that aren't necessarily the best choice but are doing it because of cost or that they simply already have the parts.
The OP was looking for a use for the drivetrain and everyone agrees that it's not the choice for a 60's and newer Mopar but it will work in a truck and could work but not be ideal in older stuff.
Just because YOU think that you're right doesn't actually make it so.
I ask again, What put that giant chip on your shoulder???? laugh2
You should actually read and comprehend your posts with the eye and perspective of someone other than yourself.
Are you sure you're not a BMW driver?
They all seem to be d*cks all of the time. whistling
Re: Ever put an NP435 in a car? [Re: Hugh Jorgan] #3103005
12/16/22 11:03 PM
12/16/22 11:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yikes
He could use a 4wd truck driveshaft that has a slip yoke.
Re: Ever put an NP435 in a car? [Re: SNK-EYZ] #3103053
12/17/22 10:38 AM
12/17/22 10:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Quote
Quote
You are the only one saying to do it.
The fool looks back at you from your mirror and frankly I don't care what a fool thinks.
Re: Ever put an NP435 in a car? [Re: Sniper] #3103142
12/17/22 04:37 PM
12/17/22 04:37 PM
A Red State
A Red State
You obviously have serious reading comprehension problems.
I NEVER said that he should do it.
I said it was possible, but you're so much of a self center "I'm always right D*CK" that you see only what you want to see.
A d*ck that has problems with reading comprehension describes you perfectly.
I don't expect that you'll answer that, especially since you think that the problem is always with everyone else.
Maybe you should do some self reflection, but I don't see that happening either.
Re: Ever put an NP435 in a car? [Re: SNK-EYZ] #3103209
12/17/22 11:23 PM
12/17/22 11:23 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Doable yes. The things going against it are. 1) it shape. The top is wide and square. A lot of tunnel fabrication and on a torsion bar car, cross member fabrication. Its deep. You may find yourself dragging it on the ground. 2) Gears. First isn't synchronized on a 435. Most seem to be granny gear. (6.68). Good launch for the first 30 feet. 3.34, 1.66, 1 might work. It would be better if you have the close ratio version with the 4.56 first. Starting in 1969 dodge started making the np445. Close ratio with synchronized first. But the case is bigger. 3) 68 and older used a much larger truck bellhousing vs the car like 69 and later. 4) It does have a yoke on the rear, but may be able the modify your truck one.
Doable yes. If it's a big block truck and you want to go thought the work. ????. If it's a small block. The pick a part places by me, would sell you a 5sp, clutch and flywheel out of a Dakota for $200.
Re: Ever put an NP435 in a car? [Re: 58pwrwgn] #3103419
12/18/22 08:13 PM
12/18/22 08:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It's just over 19 inches tall. Maybe OK in an E-body mounted on a Ramcharger frame...
Kevin
