Re: Almost 2 year in the making... [Re: Kern Dog] #3116633
01/26/23 04:11 AM
01/26/23 04:11 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
That might be an idea.
I know I just don't want it to corrode/oxidize like aluminum usually does.
It's not a show car, but I want to try to keep the car cleaning duties to a minimum if possible.
You know, wash it down and dry it with an air hose type of thing. laugh2
I'm not into car detailing after every wash.
Re: Almost 2 year in the making... [Re: SNK-EYZ] #3117298
01/28/23 03:34 PM
01/28/23 03:34 PM
south louisiana
lowell66dart Offline
south louisiana
Tell us about the stroker kit and cam specs when you have time.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Almost 2 year in the making... [Re: SNK-EYZ] #3117324
01/28/23 06:34 PM
01/28/23 06:34 PM
Australia
aus370 Offline
aus370  Offline
Australia
I Recommend Vapor Blasting your intake. Gives a fresh aluminum look but not dull like regular bead blasting, and it stays clean.
Here's a current pic of mine done 2 1/2 years ago.
Re: Almost 2 year in the making... [Re: SNK-EYZ] #3122732
02/19/23 07:59 AM
02/19/23 07:59 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
I've been making some progress on this project (along with some others).
I've been working on getting this engine ready to install in her Charger and working on my dune buggy.
Some of the time has been spent waiting on parts.
Luckily I did a test fit on the headers while it was still on the engine stand.
I found out that the header flanges wouldn't sit flat to the heads until after I trimmed the excess cometic head gaskets from hanging out past the heads in a few spots and a little grinding for clearance on the header flanges.
They were holding the headers out from sitting flush and I'm sure that would have been a header leak.
After that was done I installed and torqued the flexplate and then I got the engine set down in the engine compartment, it still has to be hooked up to the transmission.
Little by little it's getting done, the main thing is to hopefully have it ready for her by spring. laugh2
Re: Almost 2 year in the making... [Re: SNK-EYZ] #3122942
02/19/23 09:46 PM
02/19/23 09:46 PM
BDW Offline
BDW  Offline
Nice progress, it will be awesome when finished.
I just got my 5.7 and 518 swap finished after 18 months and that 1st drive was sweet!
Re: Almost 2 year in the making... [Re: SNK-EYZ] #3123068
02/20/23 01:22 PM
02/20/23 01:22 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Do you cut that GoMango with anything or just spray it right out of the gun? Also, what did you do to prep the engine prior to paint? My 6.4 is still wearing the factory black, wasn't sure how I planned to prep it.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Almost 2 year in the making... [Re: A39Coronet] #3123084
02/20/23 02:43 PM
02/20/23 02:43 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Mines sprayed with PPG Deltron Hemi Orange without metalic in it, reducer and catalyst/hardner mixed in it.
Cleaned the engine with brakekleen and sprayed with self etching primer.
