Page 3 of 3 1 2 3
Re: 8 3/4 rear vs trans brake ???? [Re: justinp61] #3100946
12/09/22 07:26 PM
12/09/22 07:26 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I hate to read these threads because it makes me rethink my decision to go with a Randy’s Ring and Pinion aluminum rear with a Detroit Locker 4.56 and narrowed back braced housing set up. Granted, I’m not running a trans brake, but I am turning 1.30 60’ times. work
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 8 3/4 rear vs trans brake ???? [Re: J_BODY] #3100970
12/09/22 09:07 PM
12/09/22 09:07 PM
Originally Posted by J_BODY
Originally Posted by MR_P_BODY
If the car is light a good 8 3/4 can live with a trans break.. I still run a alum center 8 3/4 in my car.. running 1.19
sixty.. thats leaving at 5900 rpm every pass 8.94 was my best pass... BUT 99% of the time I wouldnt ... I have
a 9" in all my other cars
wave
At least when they do go….. they can in fine fashion.
That sir is sickening puke whiney
I remember one of the first rear end that I saw fail at the races was a Ford nodular nine inch rear end in one of the factory 1966 or 1967 (CRS blush) SS/E 427 medium riser 425 HP lightweight factory race cars that belong to Ted Wells, it pitch the pinion out on the starting after he let the clutch out around 8200 RPM, wreck the driveshaft, floor boards, tranny output shaft and tail shaft housing and probably a lot more than I know about shruggy
Re: 8 3/4 rear vs trans brake ???? [Re: B3422W5] #3101010
12/10/22 01:03 AM
12/10/22 01:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
wave
Except you havent raced it in 20 years Mr P, and seldom when you did.
That car is ULTRA light. A typical bracket car making any power at all has zero business using a brake with an 8.75
My 8.75 experience….. as soon as we went transbrake in the Mirada it got a D60. In the Duster as soon as we saw axle spline twist we went S60. In the time it was like hitting the easy button….. now with parts availability I’d go 9” all day long.
Re: 8 3/4 rear vs trans brake ???? [Re: J_BODY] #3101043
12/10/22 10:40 AM
12/10/22 10:40 AM
Mo.
racerx Offline
racerx  Offline
Mo.
wave
iagree.....if i had to do it all over again it will be a 9"
Re: 8 3/4 rear vs trans brake ???? [Re: racerx] #3101568
12/12/22 01:17 PM
12/12/22 01:17 PM
an8sec70cuda Offline
wave
iagree After my first ring and pinion broke in the 8.75 I went to a Dana. The only thing I've hurt in it since then has been twisted splines on a set of 35 spline axles. Could go 40 spline, but that means new housing ends and brakes.
Wish I'd gone to a 9" back then. Parts for them are everywhere and every ratio imaginable is available.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 rear vs trans brake ???? [Re: an8sec70cuda] #3101869
12/13/22 11:01 AM
12/13/22 11:01 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Random question on the 9” vs. Dana discussion- I remember when going from 8 3/4 to Dana requires a ~1” shorter driveshaft.
Is the 9” the same way, the driveshaft needs to be shortened compared to the 8 3/4?
Re: 8 3/4 rear vs trans brake ???? [Re: Blusmbl] #3101949
12/13/22 02:32 PM
12/13/22 02:32 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
And if you upgrade the Dana 60 yoke to a Strange billet one later, your D/S will need shortening another 3/4" DAMHIK grin
Re: 8 3/4 rear vs trans brake ???? [Re: Tig] #3101976
12/13/22 03:47 PM
12/13/22 03:47 PM
moparx Offline OP
moparx  Offline OP
going to the dana will be the perfect time to replace my driveshaft.
for my goal with this car, a dana and 3.73 or 4.10 gears [the 8 3/4 has 3.91's] should work out ok. i'm leaning toward the 3.73's, but thinking about going to 29.5 tires instead of the 28.5's that are on it now, so maybe the 4.10's. shruggy
beer
Re: 8 3/4 rear vs trans brake ???? [Re: Tig] #3102164
12/14/22 08:52 AM
12/14/22 08:52 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Oof! I didn't know the yokes had that much variance in them!
I found a chart that showed the axle centerline to yoke distance for the 8 3/4 and Dana, it confirmed the ~1" difference stock vs. stock. I can't find that dimensions for a 9", but looking at pics a 9" centersection it appears because of the hypoid distance if anything the driveshaft might need to be longer for a 9", or you'd have to experiment with different yokes to get it to the 8 3/4" length.
Re: 8 3/4 rear vs trans brake ???? [Re: Blusmbl] #3102168
12/14/22 09:19 AM
12/14/22 09:19 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
The new yoke had a shoulder machined in for an 8 magnet collar, since we now use a racepak. I should have compared it to the stock one when apart, the D/S was too long when I got round to putting it all back together. Never assume etc etc grin
Re: 8 3/4 rear vs trans brake ???? [Re: Tig] #3102318
12/14/22 04:17 PM
12/14/22 04:17 PM
moparx Offline OP
moparx  Offline OP
speaking of yokes, as i was perusing billet and other high performance yokes, it seemed that the ones offered had less spline engagement [sometimes by quite a bit] than the factory ones.
is that still the case ?
beer
Re: 8 3/4 rear vs trans brake ???? [Re: moparx] #3102319
12/14/22 04:20 PM
12/14/22 04:20 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Not that I noticed, but I wasn't looking for it shruggy
Page 3 of 3 1 2 3
