Aluminum master cylinder upgrade #3100257
12/06/22 10:37 PM
12/06/22 10:37 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys, I seen a lot of guys running these type of master cylinders on their early mopars I was told there was some type of part number or you order it through your local parts store and can buy them a lot cheaper than the aftermarket has them. Does anybody have any part numbers on them or what vehicle I should tell them I have
thank you guys, Mopar, or no car and I do have the adapter plate
I have a 69 dart with 73 disc brakes upfront and 11 inch drums in the rear
Re: Aluminum master cylinder upgrade [Re: RAY1969CARS] #3100265
12/06/22 11:01 PM
12/06/22 11:01 PM
5thAve Offline
5thAve  Offline
Any M body 1979 to 1989. Fifth avenue, Diplomat etc. Trucks had them too and some FWD cars but they're different part number and I don't know if bore sizes or anything else would make a difference in how they work.
Re: Aluminum master cylinder upgrade [Re: 5thAve] #3100272
12/06/22 11:32 PM
12/06/22 11:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Rockauto. 1-1/32" bore
Re: Aluminum master cylinder upgrade [Re: Stanton] #3100336
12/07/22 09:54 AM
12/07/22 09:54 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I saved this chart when it was posted earlier.
Re: Aluminum master cylinder upgrade [Re: burdar] #3100337
12/07/22 09:58 AM
12/07/22 09:58 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's a nice chart !!
The thing that needs defining is "caliper piston size" - What's large and what's small ?
Re: Aluminum master cylinder upgrade [Re: RAY1969CARS] #3100342
12/07/22 10:17 AM
12/07/22 10:17 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The 1 1/8" master listed above will work very well with this but will give a very firm pedal and short throw. I love it!
'63 Dodge 330
11.19 @ 121 mph
Re: Aluminum master cylinder upgrade [Re: GY3] #3100348
12/07/22 10:34 AM
12/07/22 10:34 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The 1-1/8 master needs a booster IMO. I'm pretty sure that's the master that was in my 82 Cordoba. I removed the booster for valve cover clearance and made a spacer to take up the space that the booster once filled. The pedal was rock hard and the car was a handful to stop. I didn't know any better at the time but a master with a smaller bore was needed. Does the OP have a booster or do you have manual brakes?
Replacement boosters on Rockauto are inexpensive. Might have to experiment with a couple different sizes.
Re: Aluminum master cylinder upgrade [Re: burdar] #3100350
12/07/22 10:44 AM
12/07/22 10:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
My experience as well. 65 Cuda, manual brakes, 11.75" discs, 11" drums, M cop car combination vavle.. the 1 1/8" MC is the wrong choice there.
Re: Aluminum master cylinder upgrade [Re: Sniper] #3100351
12/07/22 10:45 AM
12/07/22 10:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
go to Dr Diffs page, he has a fair price and you can get the adapter there as well.
68 Barracuda Formula S 340
Re: Aluminum master cylinder upgrade [Re: Bad340fish] #3100365
12/07/22 11:47 AM
12/07/22 11:47 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The adapters piss me off. Would it have broke the bank to have added another 1/8" of material to adequately cover the hole in the stock M/C firewall plate ?!? And the recess around the bore is smaller than the m/c dust boot.
Re: Aluminum master cylinder upgrade [Re: burdar] #3100368
12/07/22 11:56 AM
12/07/22 11:56 AM
Alberta
rustbuckett68 Offline
Alberta
A body boosters seem to be unavailable. Needed on for my 74 Dart last year, no go. I could have sent the booster to Cardone ( from Canada), pay $160.00US for them to rebuild. Would have had to pay shipping etc. both ways. Went manual.
Re: Aluminum master cylinder upgrade [Re: Stanton] #3100394
12/07/22 12:59 PM
12/07/22 12:59 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No hard to make your own, did that in the 90's.
Re: Aluminum master cylinder upgrade [Re: Sniper] #3100412
12/07/22 01:43 PM
12/07/22 01:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I wouldn't recommend anything over 15/16' for anything without power brakes. I put either a 1 1/32" or a 1 1/8" on my Dart with manual disk front and back and it scared me in the driveway. Both hands on the wheel and both feet on the brake pedal to make it stop. The 15/16" I got from Dr Diff is much better, but when the time comes to replace it, I'll use a 7/8" bore.
Re: Aluminum master cylinder upgrade [Re: RAY1969CARS] #3100445
12/07/22 03:24 PM
12/07/22 03:24 PM
The smaller the bore the less leg pressure is needed to stop the car with no power assisted brakes up scope
I found that out the hard way when a master cylinder went south at Pomona one year and I didn't know the correct size of the master cylinder bore and replaced it with one that had a 5/16 bigger bore when I had to replace it because it wouldn't stop that car worth a hoot down shock whiney
Re: Aluminum master cylinder upgrade [Re: Cab_Burge] #3100469
12/07/22 04:54 PM
12/07/22 04:54 PM
Ormond Beach, FL
71STROKERFISH Offline
Ormond Beach, FL
DOCTORDIFF.COM Email him your question and he'll get ya figured out.
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: Aluminum master cylinder upgrade [Re: rustbuckett68] #3100474
12/07/22 04:59 PM
12/07/22 04:59 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I have an all original brake booster set up out of a 72 Dart. A friend had said he should have more parts as well...
Re: Aluminum master cylinder upgrade [Re: Stanton] #3100488
12/07/22 06:14 PM
12/07/22 06:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Most drag race calipers use 1.75" bores. Use number of bores in the system to determine piston area. Basic rule is 1-1/32" MC for 2 piston front/4 piston rear system. 1-1/8" MC for 4 piston front and rear.
Using anything else, you have to do the math. Total area = πr2 x number of pistons
Pedal ratios make a difference too.
Some of these kits use calipers with small (1-3/8") bores. I got caught (once) trying to figure out why the brakes wouldn't work on a car that had Wilwoods with these goofy bore sizes.
Plumb the brakes into the correct port on the MC, according to your configuration.
Spend some money, ditch the torn up rubber ring, and put one of these on the car. If I had a dollar for every car I've seen torn up...
Re: Aluminum master cylinder upgrade [Re: CMcAllister] #3100526
12/07/22 09:23 PM
12/07/22 09:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I pulled one of these aluminum bodied mast cyl off the car . Car needed an anchor out the window to stop ( dont know size as I didnt measure it before it went in the trash can )
Put a 15/16 master for a 1975 Duster on it ( manual front disc and rear drums on a 1966 B body )
car actually stops now without much efffort
Re: Aluminum master cylinder upgrade [Re: gtx6970] #3101017
12/10/22 03:02 AM
12/10/22 03:02 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
There are stock looking four bolt aluminum masters out there, too.
https://www.force10brakes.com/home/...um-and-disc-disc-applications-p235514315
Re: Aluminum master cylinder upgrade [Re: 375inStroke] #3102504
12/15/22 11:12 AM
12/15/22 11:12 AM
GA
roadrunninMark Offline
GA
Looking up the 15/16" from a Dakota on RockAuto, the reservoir is "angled", where the front is low - back high. I don't know if this reduces the amount of fluid the front holds vs. the 1 1/32" diplomat unit, which has a level reservoir. Also, there is an option to get the Dakota m/c without the reservoir. Does this mean you could a separate reservoir from the Diplomat (level) so you can use on the Dakota m/c? This would give you a level reservoir on the smaller 15/16" m/c.
The reason I ask is because I bought a 1 1/8" that is way too big for a car and I would like either the 15/16" or 1 1/32". This would be for an e body manual brake 11.75 disc / 10" drum set up. Can get local for less w/o reservoir.
**For manual brakes: bore that back of the piston on the 15/16",** Can someone explain exactly how to do this?
