Re: Aluminum master cylinder upgrade
[Re: RAY1969CARS]
#3100342
12/07/22 10:17 AM
12/07/22 10:17 AM
Posts: 4,684 Wichita
GY3
Wichita
Hi guys, I seen a lot of guys running these type of master cylinders on their early mopars I was told there was some type of part number or you order it through your local parts store and can buy them a lot cheaper than the aftermarket has them. Does anybody have any part numbers on them or what vehicle I should tell them I have thank you guys, Mopar, or no car and I do have the adapter plate
I have a 69 dart with 73 disc brakes upfront and 11 inch drums in the rear The 1 1/8" master listed above will work very well with this but will give a very firm pedal and short throw. I love it!
[Re: burdar]
#3100350
12/07/22 10:44 AM
12/07/22 10:44 AM
Posts: 6,281 nowhere
Sniper
nowhere
The 1-1/8 master needs a booster IMO. I'm pretty sure that's the master that was in my 82 Cordoba. I removed the booster for valve cover clearance and made a spacer to take up the space that the booster once filled. The pedal was rock hard and the car was a handful to stop. I didn't know any better at the time but a master with a smaller bore was needed. Does the OP have a booster or do you have manual brakes?
Replacement boosters on Rockauto are inexpensive. Might have to experiment with a couple different sizes. My experience as well. 65 Cuda, manual brakes, 11.75" discs, 11" drums, M cop car combination vavle.. the 1 1/8" MC is the wrong choice there.
[Re: Sniper]
#3100351
12/07/22 10:45 AM
12/07/22 10:45 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
go to Dr Diffs page, he has a fair price and you can get the adapter there as well.
68 Barracuda Formula S 340
[Re: Stanton]
#3100394
12/07/22 12:59 PM
12/07/22 12:59 PM
Sniper
nowhere
The adapters piss me off. Would it have broke the bank to have added another 1/8" of material to adequately cover the hole in the stock M/C firewall plate ?!? And the recess around the bore is smaller than the m/c dust boot. No hard to make your own, did that in the 90's.
[Re: Cab_Burge]
#3100469
12/07/22 04:54 PM
12/07/22 04:54 PM
Posts: 568 Ormond Beach, FL
71STROKERFISH
Ormond Beach, FL
DOCTORDIFF.COM Email him your question and he'll get ya figured out.
-dc SOUTHERNPLAINSMOPAARFEST.COM 2018 Jeep Trackhawk 1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997 1971 Barracuda, 414ci, 6bbl Fitech, 727 1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
[Re: rustbuckett68]
#3100474
12/07/22 04:59 PM
12/07/22 04:59 PM
Posts: 8,143 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
A body boosters seem to be unavailable. Needed on for my 74 Dart last year, no go. I could have sent the booster to Cardone ( from Canada), pay $160.00US for them to rebuild. Would have had to pay shipping etc. both ways. Went manual. I have an all original brake booster set up out of a 72 Dart. A friend had said he should have more parts as well...
[Re: Stanton]
#3100488
12/07/22 06:14 PM
12/07/22 06:14 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's a nice chart !!
The thing that needs defining is "caliper piston size" - What's large and what's small ? Most drag race calipers use 1.75" bores. Use number of bores in the system to determine piston area. Basic rule is 1-1/32" MC for 2 piston front/4 piston rear system. 1-1/8" MC for 4 piston front and rear. Using anything else, you have to do the math. Total area = πr2 x number of pistons Pedal ratios make a difference too. Some of these kits use calipers with small (1-3/8") bores. I got caught (once) trying to figure out why the brakes wouldn't work on a car that had Wilwoods with these goofy bore sizes. Plumb the brakes into the correct port on the MC, according to your configuration. Spend some money, ditch the torn up rubber ring, and put one of these on the car. If I had a dollar for every car I've seen torn up...
[Re: 375inStroke]
#3102504
12/15/22 11:12 AM
12/15/22 11:12 AM
Posts: 2,943 GA
roadrunninMark
GA
Looking up the 15/16" from a Dakota on RockAuto, the reservoir is "angled", where the front is low - back high. I don't know if this reduces the amount of fluid the front holds vs. the 1 1/32" diplomat unit, which has a level reservoir. Also, there is an option to get the Dakota m/c without the reservoir. Does this mean you could a separate reservoir from the Diplomat (level) so you can use on the Dakota m/c? This would give you a level reservoir on the smaller 15/16" m/c.
The reason I ask is because I bought a 1 1/8" that is way too big for a car and I would like either the 15/16" or 1 1/32". This would be for an e body manual brake 11.75 disc / 10" drum set up. Can get local for less w/o reservoir.
**For manual brakes: bore that back of the piston on the 15/16",** Can someone explain exactly how to do this?
