Re: Good wheel/tire size for 70 Challenger?
[Re: Kern Dog]
#3100038
12/06/22 08:56 AM
12/06/22 08:56 AM
Posts: 6,175 nowhere
Sniper
nowhere
Here's how I sorted out how ti fit 17" rims and fatter tires on my 51. http://www.yourolddad.com/tiresEwen if you just hare a 15" rim for test purposes you can still use this method. All you need is over all height and width of the tore in question and you can mimic it.
[Re: JF_Moparts]
#3100164
12/06/22 03:50 PM
12/06/22 03:50 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Depends on what you want.. styling? function/purpose? comfort/handling????
The YearOne 17x9 have a perfect backspacing and will easily accommodate tires 275-40-17 front and rear... no fender problems at all.... but they are a rather small diameter... but good for upgraded appearance and functioning.
RylissPro runs 315-30-18... but with special offset/backspacing rims.. AND he has aftermarket non-stock front and rear suspensions... another ball game.
Your 71-B-body rims should easily swap with the E-body.
Short sidewall tires are stiffer; offer better transient handling response, but also welcome damaged rims when low tire PSI vs pot-holes eventually come into the mix.
Taller sidewalls offer softer rides, but with less handling transitions.
For my street/hwy driving, I run 15x8 minilites (Superlite brand, 4.3/8: backspace); BFG T/A 255-60-15 front. 275-60-15 rear... nice ride, good cruising tires. No problems with fender clearance.
For track events, I run 18x11 minilites (ET brand, 5.5" backspace), Yokohama AO52 200TW 295-30-18, F/R... lips flushed as needed (done many years ago).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: JF_Moparts]
#3100168
12/06/22 04:14 PM
12/06/22 04:14 PM
Posts: 2,463 Answering the call of the wild
ThermoQuad
Just go ahead and put the biggest tire/wheel you can “squeeze” in there that looks cool without looking at the car’s total suspension set up. That is what everyone does…even when told that the tire size is not proper for the car. Then come back and complain that it rides like a dump truck and does not handle well. Want real advice? try a pm
[Re: Kern Dog]
#3100179
12/06/22 05:03 PM
12/06/22 05:03 PM
ThermoQuad
Come on Kern Dog, put up or shut up...bring it on! I know what works well, i have 22 years or more of results and lap times - with multiple vehicles....5 or 6 or 7 maybe 8... i lost count.....you have an opinion. One size does not fit all, it's custom fit due to the combination of parts. Show me a better tire rim combination that will knock another 3 or more seconds off the proper measurement of the car’s performance – that is called lap times - that does not compromise it’s street manners. You can’t. kma I will put the Charger R/T up against your thing on Watkins Glen International Racetrack any time...come on - let's go!!!!! You have no clue how much fun it would to be behind you on the Glenn with my faster car and you would have to let me pass....yeeehaaa...track rules ...and btw Black n Blue is way more badass than your thing....ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
[Re: Kern Dog]
#3100248
12/06/22 10:16 PM
12/06/22 10:16 PM
Posts: 1,161 Los Angeles, CA
JF_Moparts
Los Angeles, CA
Thanks all so far.
For additional context - I have been racing my 71 Satellite Sebring for over 30 years. SCCA Solo II, Willow Springs, etc. I'm very familiar with what a 71 Satellite/RR can accommodate because I've been under those fender wells since 1987. The Challenger is new for me and while the back wheel wells look roomy, the fronts don't. I just picked up a set of the Year One 17x9 Rallyes for my RR, which so far I like very much. I am sticking with 17's for now.
I'm just not sure if the Challenger has the same offset, etc, that my 71 B body has. Based on the above responses it sounds like it does, which is great because then I can swap wheels among all my cars.
[Re: Kern Dog]
#3193079
11/24/23 06:11 PM
11/24/23 06:11 PM
Posts: 5,385 Pikes Peak Country
TC@HP2
Pikes Peak Country
Rylis-Pro has a '70 Barracuda and used to post here. He had 315-35-18s on his car. Where has that post gone to? Maybe I've got a brain cramp, but trying to search his name and the site tells me he doesn't exist.
[Re: TC@HP2]
#3193140
11/25/23 12:46 AM
11/25/23 12:46 AM
Posts: 22,695 Bitopia
jcc
Bitopia
Rylis-Pro has a '70 Barracuda and used to post here. He had 315-35-18s on his car. Where has that post gone to? Maybe I've got a brain cramp, but trying to search his name and the site tells me he doesn't exist. Its RylisPro, Last posted here 4/23/23?, last "seen" 9/1/23 whatever that means. last time he mentioned his 315's, I believe he was trying to "squeeze" in bigger? A couple of other notes, the abrasiveness is indeed predictable, and for me easy to overlook, while I will always try to squeeze in the largest/widest set of tires, with one caveat, in a track/handling application, I always try to seek a '"square" set-up, for those unfamiliar with the term, get used to being passed. In my world, everything else on a car non engine wise is there to help the tires do their task.
[Re: jcc]
#3193212
11/25/23 01:40 PM
11/25/23 01:40 PM
TC@HP2
Pikes Peak Country
Thank you, that found him no problem.
I'd imagine the "last seen" is a log in without a posting. Since he sells the AAR/TA spoilers, he may need to communicate with buyers without needing to post.
Back in the days when a broad range of varying performance tires were available in 15" sizes, it was easy to find a very grippy tire in a narrow width that would perform better than a wider, harder, pure street tire. I think we would all agree that a narrower racing slick will grab better than a significantly wider street tire. Sadly, the even limited number of speed rated 15" tires that were available a couple of years ago has slimmed down even further. I think we are opening the door of it will either be hard cruiser tires and racing slicks only, unless you use a smaller sport compact size and those guys aren't too interested in sticking with 15".
It is amusing in revisiting Rylispro's 315 thread from 2017 that the range of available performance tires in 17" diameters has significantly changed and 18s are now a better diameter for a broader choice as the OEMS have moved up to 20s. I've long advocated using OEM sizes in a car to ensure tire availability. Viper, Vette and Cobra sizes in 17" always seemed to yield a good selection. These days, you get maybe a single UHP summer tire around 350 wear rate and all out race tires. My idea of sticking to those sizes has now become a limitation. We seem to be an such a rapidly advancing tire tech place now, that it can become prohibitively expensive with wheel purchases (especially if you use a high quality forged or spun form wheel) chasing whatever less expensive OEM boutique tire size is the latest go fast goody with a broad range of tread, wear choices and potentially (at least for a short time) lower prices.
Various sanctioning bodies with their 200 treadwear requirement is starting to create a nitch of wider, better performing handling tires in a small range of select sizes that can be applied to vintage wheel well sizes with some carful work. As is often the first question we see here, what are you intending to do with the car must still be the first question asked when seeking to understand options.
[Re: TC@HP2]
#3193247
11/25/23 04:19 PM
11/25/23 04:19 PM
jcc
Bitopia
BTW, the "last seen" comment is a tongue and cheek reference to a thread months back about members thought to be deceased years ago being "last seen" only months ago, and attributed likely to another person surfing on the decease's computer.
And to the rest of your spot-on reply, it is rather difficult to solve any problem if one can't define it first.
[Re: jcc]
#3197175
12/13/23 12:43 PM
12/13/23 12:43 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
I do love road racing, but have never built any of my muscle cars for road racing. Depends what you (the o.p.) has planned for the car. I have always built mine for street/strip cruisers. I have 315/60/15's on the back of my 70 Challenger with -1" lowering Springs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: gtx6970]
#3197486
12/14/23 03:28 PM
12/14/23 03:28 PM
Posts: 20,645 So Near, Yet So Far
topside
So Near, Yet So Far
Years ago, I had a dead-stock, low-mileage 318 '70 Barracuda and put 15" Rallyes on it. Ran 275/60s on 15x8s in back - the standard 4.5" BS from I think Wheel Vintiques. With a couple people in the car, the rears would rub in the wheelhouses over bumps. That was a surprise, since the same sizes have plenty of clearance on my '68-up B bodies. IIRC, it was the 4.5 BS, and 4.25 would have prevented it.
As for 50 vs 60 profile, I've run both on B-bodies, and the 60s look more "proper" to me. Ride quality 50 vs 60 wasn't different enough that I noticed it.
[Re: AndyF]
#3198108
12/17/23 11:51 AM
12/17/23 11:51 AM
Posts: 4,741 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I already had the tires I planned on running but I purchased this tool to determine near exact back spacing.
https://www.speedwaymotors.com/Wheel-Fitment-Tool-for-Tire-Fit-Testing-Size-Measuring-Mockup,485869.html?utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gad_source=1&gclid=EAIaIQobChMIz_vSmumWgwMVDjmtBh0eTQnSEAQYASABEgKNBvD_BwE
Keep old mopars alive.
