Inside Home Heating Options ? Advice ? #3099351
12/03/22 11:14 PM
12/03/22 11:14 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Hello All & Merry Christmas !
My girlfriend has a small 880 sq. ft. modular home in southern Sierra Mountains , California
She has a small natural gas heater that the blower is no longer working ..... She has been looking for a replacement with very little luck.
We have been looking at portable propane heaters ? and small electric heaters and are just not certain which way to go ? shruggy
Any advice on a solution ? bow greatly appreciated ! I just don't totally trust her home electric system as it's 60 + years old eek
The temp can get into teens overnight shock ...... Thank you ! Santa3
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3099354
12/03/22 11:33 PM
12/03/22 11:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Depends on the type of "Portable propane" heaters you're referring to. Some can be very dangerous in an enclosed area. Any chance of having the electrical system inspected and or Upgraded with a new line and possibly going to a heat pump ?
I heat my 1200 Sq ft shop with 2-4 1500W oil filled radiant heaters but it is extremely well insulated. Normally only get up to 4 in jan- - feb.
each heater pulls 12.5A full bore but they do cycle on & off. popcorn
Electric blankets for sleeping are another option for o/nite wink
Re: Inside Home Heating Options ? Advice ? [Re: TJP] #3099364
12/04/22 12:29 AM
12/04/22 12:29 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
880 square feet is about a decent sized garage. Even in ND that size garage only takes about 25,000 BTU/hr. That would mean a unit like this.
Space Heater
Of course, if you wanted more heat, just get a larger one.
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3099368
12/04/22 12:41 AM
12/04/22 12:41 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Two plug in radiator heaters and a couple ceiling fans to dissipate the heat will probably do the job. Cheap, easy and she likely already has the ceiling fans (any fan, really)...
Re: Inside Home Heating Options ? Advice ? [Re: Fat_Mike] #3099428
12/04/22 11:01 AM
12/04/22 11:01 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Small mini+Split may work. Easy to install and safer than a portable. But that goes n
Back to your trust of the electrical system.
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3099432
12/04/22 11:08 AM
12/04/22 11:08 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Look into a Toyo Laser 531.
I have a larger one in my shop, love it!
I also installed a Laser 531 in my home about a month ago. ( the aging boiler in the basement gave up the ghost last season)
Toyos are VERY efficient.
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3099448
12/04/22 12:06 PM
12/04/22 12:06 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
How dependable do you see your electric grid to be in the future? In most cases, electric space heaters are much more expensive to operate than gas. There are calculators on line where you can estimate your costs each way. Dependability and operating costs would seem to be at the top of the list.
We have a geothermal system and a couple of propane space heaters. We LOVE the propane space heaters. They really warm our old bones and do it quickly.
Master, again and still
Re: Inside Home Heating Options ? Advice ? [Re: DaveRS23] #3099463
12/04/22 12:39 PM
12/04/22 12:39 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Look up the Mr Heater line of propane heaters - I've used one indoors without problems.
I'm disposed against electric heat due to operating cost and power failure in stormy times.
A proper gas furnace would be best, I think - sounds like she'd have to run propane if there's no NG service.
Wood heat is dead-reliable, but that means installing a wood stove & maintaining a supply of dry wood.
Whatever you do, have proper ventilation.
Re: Inside Home Heating Options ? Advice ? [Re: topside] #3099520
12/04/22 03:04 PM
12/04/22 03:04 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would look into a high efficiency mini split for configured for low temps.
It would probably be wired directly to the panel and lower the risk of electrical issues.
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3099781
12/05/22 12:22 PM
12/05/22 12:22 PM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
Have someone look at the current heater. There is a a small heat switch/thermal switch that is usually the issue. the switches are inexpensive and I bought mine by the dozen because they are known to go bad.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Inside Home Heating Options ? Advice ? [Re: topside] #3099873
12/05/22 04:47 PM
12/05/22 04:47 PM
IMGTX Offline
IMGTX  Offline
Like topside said. Mr Heater are indoor capable.
I just used a Mr Heater Heater in a friends greenhouse while I got the electrical squared away.
I bought the one that uses Two 1 lb canisters then added a filter and long hose kit. The long hose lets you hook it to a 20lb or larger tank (the tank should be placed outside) and the filter keeps the oil that is present in refillable propane tanks from messing up the heater. Has a low oxygen shut off and did a bang up job. No electric required but electric can be used to power a fan to boost it's efficiency.
Just an FYI hope it helps.
Re: Inside Home Heating Options ? Advice ? [Re: IMGTX] #3100156
12/06/22 03:07 PM
12/06/22 03:07 PM
5thAve Offline
5thAve  Offline
How have heating fuel prices been going up there? Here it's being priced out of the market so I'd guess California is the same.
How often is the heat needed? I'd be tempted to go electric. Did you check if you could replace the blower? Usually that's a pretty cheap option if you can find the part or find a place to fix the motor.
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3100174
12/06/22 04:46 PM
12/06/22 04:46 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
For Christmas among other presents you can get her a CO detector.
Trying to enjoy life!
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3100215
12/06/22 08:05 PM
12/06/22 08:05 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
What is the altitude there? Some gas heaters don't work well above a certain altitude.
Re: Inside Home Heating Options ? Advice ? [Re: GomangoCuda] #3100221
12/06/22 08:21 PM
12/06/22 08:21 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Originally Posted by GomangoCuda
Quote
7000 Ft. whiney ........ she's aware of this problem and has decided to go with couple electric heaters and get someone to check out
the fan for replacement / repair ........... THANK YOU ! bow to everyone contributing their knowledge on her problem up thumbs
Re: Inside Home Heating Options ? Advice ? [Re: kidmopar] #3100261
12/06/22 10:49 PM
12/06/22 10:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Electric base board heater might be another option once the electricals' checked out wink
