Re: 8 3/4 rear vs trans brake ????
[Re: J_BODY]
#3100970
12/09/22 09:07 PM
12/09/22 09:07 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
If the car is light a good 8 3/4 can live with a trans break.. I still run a alum center 8 3/4 in my car.. running 1.19 sixty.. thats leaving at 5900 rpm every pass 8.94 was my best pass... BUT 99% of the time I wouldnt ... I have a 9" in all my other cars At least when they do go….. they can in fine fashion. That sir is sickening I remember one of the first rear end that I saw fail at the races was a Ford nodular nine inch rear end in one of the factory 1966 or 1967 (CRS ) SS/E 427 medium riser 425 HP lightweight factory race cars that belong to Ted Wells, it pitch the pinion out on the starting after he let the clutch out around 8200 RPM, wreck the driveshaft, floor boards, tranny output shaft and tail shaft housing and probably a lot more than I know about
[Re: B3422W5]
#3101010
12/10/22 01:03 AM
12/10/22 01:03 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
If the car is light a good 8 3/4 can live with a trans break.. I still run a alum center 8 3/4 in my car.. running 1.19 sixty.. thats leaving at 5900 rpm every pass 8.94 was my best pass... BUT 99% of the time I wouldnt ... I have a 9" in all my other cars Except you havent raced it in 20 years Mr P, and seldom when you did. That car is ULTRA light. A typical bracket car making any power at all has zero business using a brake with an 8.75 My 8.75 experience….. as soon as we went transbrake in the Mirada it got a D60. In the Duster as soon as we saw axle spline twist we went S60. In the time it was like hitting the easy button….. now with parts availability I’d go 9” all day long.
[Re: J_BODY]
#3101043
12/10/22 10:40 AM
12/10/22 10:40 AM
Posts: 4,071 Mo.
racerx
Mo.
If the car is light a good 8 3/4 can live with a trans break.. I still run a alum center 8 3/4 in my car.. running 1.19 sixty.. thats leaving at 5900 rpm every pass 8.94 was my best pass... BUT 99% of the time I wouldnt ... I have a 9" in all my other cars Except you havent raced it in 20 years Mr P, and seldom when you did. That car is ULTRA light. A typical bracket car making any power at all has zero business using a brake with an 8.75 My 8.75 experience….. as soon as we went transbrake in the Mirada it got a D60. In the Duster as soon as we saw axle spline twist we went S60. In the time it was like hitting the easy button….. now with parts availability I’d go 9” all day long. .....if i had to do it all over again it will be a 9"
[Re: racerx]
#3101568
12/12/22 01:17 PM
12/12/22 01:17 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
If the car is light a good 8 3/4 can live with a trans break.. I still run a alum center 8 3/4 in my car.. running 1.19 sixty.. thats leaving at 5900 rpm every pass 8.94 was my best pass... BUT 99% of the time I wouldnt ... I have a 9" in all my other cars Except you havent raced it in 20 years Mr P, and seldom when you did. That car is ULTRA light. A typical bracket car making any power at all has zero business using a brake with an 8.75 My 8.75 experience….. as soon as we went transbrake in the Mirada it got a D60. In the Duster as soon as we saw axle spline twist we went S60. In the time it was like hitting the easy button….. now with parts availability I’d go 9” all day long. .....if i had to do it all over again it will be a 9" After my first ring and pinion broke in the 8.75 I went to a Dana. The only thing I've hurt in it since then has been twisted splines on a set of 35 spline axles. Could go 40 spline, but that means new housing ends and brakes. Wish I'd gone to a 9" back then. Parts for them are everywhere and every ratio imaginable is available.
[Re: an8sec70cuda]
#3101869
12/13/22 11:01 AM
12/13/22 11:01 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Random question on the 9” vs. Dana discussion- I remember when going from 8 3/4 to Dana requires a ~1” shorter driveshaft.
Is the 9” the same way, the driveshaft needs to be shortened compared to the 8 3/4?
[Re: Blusmbl]
#3101949
12/13/22 02:32 PM
12/13/22 02:32 PM
Posts: 2,924 A shed in England
Tig
A shed in England
Is the 9” the same way, the driveshaft needs to be shortened compared to the 8 3/4? And if you upgrade the Dana 60 yoke to a Strange billet one later, your D/S will need shortening another 3/4" DAMHIK
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3102164
12/14/22 08:52 AM
12/14/22 08:52 AM
Blusmbl
Plymouth, MI
Is the 9” the same way, the driveshaft needs to be shortened compared to the 8 3/4? And if you upgrade the Dana 60 yoke to a Strange billet one later, your D/S will need shortening another 3/4" DAMHIK Oof! I didn't know the yokes had that much variance in them! I found a chart that showed the axle centerline to yoke distance for the 8 3/4 and Dana, it confirmed the ~1" difference stock vs. stock. I can't find that dimensions for a 9", but looking at pics a 9" centersection it appears because of the hypoid distance if anything the driveshaft might need to be longer for a 9", or you'd have to experiment with different yokes to get it to the 8 3/4" length.
[Re: Blusmbl]
#3102168
12/14/22 09:19 AM
12/14/22 09:19 AM
Tig
A shed in England
The new yoke had a shoulder machined in for an 8 magnet collar, since we now use a racepak. I should have compared it to the stock one when apart, the D/S was too long when I got round to putting it all back together. Never assume etc etc
[Re: moparx]
#3102319
12/14/22 04:20 PM
12/14/22 04:20 PM
Tig
A shed in England
Not that I noticed, but I wasn't looking for it
