Adding a sump to a factory gas tank #3099123
12/03/22 01:03 AM
12/03/22 01:03 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Are the factory tanks galvanized inside and out ? If they are then I don't think you can weld on them, correct ?
So then, to add a sump, or attach anything to the tank, is brazing your only option ?
Re: Adding a sump to a factory gas tank [Re: hemienvy] #3099131
12/03/22 03:09 AM
12/03/22 03:09 AM
New York, USA
Chargerfan68 Offline
New York, USA
I have installed sumps on new galvenized tanks by welding them after grinding/sanding the coating off. It works fine for me for over 15 yrs of service….street and track. I just clean the i side of tank out very thoroughly.
Exterior and interior view
Re: Adding a sump to a factory gas tank [Re: Chargerfan68] #3099166
12/03/22 11:16 AM
12/03/22 11:16 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I did the same thing, but tig brazes with silicon bronze instead of welding.
Re: Adding a sump to a factory gas tank [Re: hemienvy] #3099202
12/03/22 01:46 PM
12/03/22 01:46 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
For what its worth,there are more ways to get uninterrupted fuel flow from a stock tank without welding on a sump. I used an in-tank pump that feeds a remote mounted surge tank to feed my EFI'd motor. Simple plumbing including adding an upsized return line provides me with airless continuous fuel flow even when the tank is down to the last gallon or two.
Modified a factor style fuel sending unit, added a narrow piece of Holley Hydromat to it (not pictured) and bolted in a surge tank. Easy and much more effective than using just a sumped tank.
Re: Adding a sump to a factory gas tank [Re: jbc426] #3099215
12/03/22 02:28 PM
12/03/22 02:28 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hmm. JBC, that is very interesting !
Re: Adding a sump to a factory gas tank [Re: hemienvy] #3099226
12/03/22 03:05 PM
12/03/22 03:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I also have an external sump setup for the EFI system I am putting on the flathead six in my 51.
It is essentially a remote oil filter setup using a spin on fuel filter as the sump. Stock mechanical pump feeds the setup, external high pressure pump draws from the filtered side of the setup, return from the fuel rail feeds back into the setup and a return line fromt he sump goes back to the tank.
Re: Adding a sump to a factory gas tank [Re: Sniper] #3099260
12/03/22 05:03 PM
12/03/22 05:03 PM
moparx Offline
moparx  Offline
Sniper, i would like to see a picture of that if you have one. up
beer
Re: Adding a sump to a factory gas tank [Re: moparx] #3099307
12/03/22 07:48 PM
12/03/22 07:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No pics, but here is a link to the guy I got the idea from
http://madscientistmatt.blogspot.com/2005_12_01_archive.html
Re: Adding a sump to a factory gas tank [Re: hemienvy] #3099320
12/03/22 09:04 PM
12/03/22 09:04 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I thought so too when I saw it. The pump in the fuel tank circulates fuel from the tank to the surge tank and back at high volume at nearly 0 psi. The in-tank pump free flows the fuel from tank to surge tank in a continuous loop, which keeps the surge tank full even when the fuel tank level is very low.
The surge tank pump circulates the high pressure fuel through the fuel rails, to the injectors, then to the pressure regulator and back into the surge tank.
These two circuits keep the high pressure surge tank full, while purging any air induced into the surge tank by the low pressure side when the fuel level is very low.
When you add the Holley Hyromat to the main tank, induced air is virtually eliminated at the source.
I'm about to double the horsepower and consequently the required fuel flow the system can provide. All I need to do to increase the fuel flow is to upsize the fuel pumps in both tanks.
Re: Adding a sump to a factory gas tank [Re: hemienvy] #3099321
12/03/22 09:06 PM
12/03/22 09:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is another idea. Fuel surge and pump tank.
Re: Adding a sump to a factory gas tank [Re: NITROUSN] #3099502
12/04/22 02:06 PM
12/04/22 02:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes, I liked the video. While he retained the stock fuel system to show the ease, simplicity and quickness of installing his upgraded components, I opted to upsize my feed and return lines to allow for higher flow rates to the surge tank I installed. Another reason was that I am running a 5.9 Magnum based motor with no stock fuel pump on the motor.
I used a Radium Engineering surge tank, which was available several years before McRob put his set-up out. He makes nice stuff.
Re: Adding a sump to a factory gas tank [Re: jbc426] #3102551
12/15/22 01:21 PM
12/15/22 01:21 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Look into Holly hydra mat. I can run 2-3 gallons in a stock tank and not have supply issues.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
