Re: Holley Retrofit Headlights LED
[Re: 65pacecar]
#3099088
12/02/22 10:05 PM
12/02/22 10:05 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
I don’t have the Holley LED’s, I couldn’t stomach the price. I ended up using a set from Oracle that I think were less than $200 for all four.
I’d do it again in a second, they made an incredible difference at night compared to the sealed beams.
If you don’t like bright white be sure to find a warmer hue though, they typically are sold with different options of warm vs. cool.
This doesn’t do the difference justice.
[Re: Blusmbl]
#3099138
12/03/22 06:37 AM
12/03/22 06:37 AM
Posts: 5,644 Port Huron, Michigan
MI_Custumz
This doesn’t do the difference justice. Got a link to those? I like the stock look and am considering going LED if they are plug and play and look stock.
[Re: RJS]
#3099164
12/03/22 11:13 AM
12/03/22 11:13 AM
Posts: 6,710 KY
65pacecar
KY
I didn't go with the Holley's due to the price and the Holley logo across the front of the bulb. I just ordered from "Headlight Experts".
They are lifetime guarantee and are made of glass and metal. They don't have that aftermarket look to them which was important to me. Ron I just checked their website, looks like a better option. I’ve never heard of them before, thanks. Any issue with installation?
[Re: MI_Custumz]
#3099187
12/03/22 01:05 PM
12/03/22 01:05 PM
Blusmbl
Plymouth, MI
Got a link to those? I like the stock look and am considering going LED if they are plug and play and look stock. I take it back, they were Octane, not Oracle, 220, 221… whatever it takes. Lol Octane Lighting 5-3/4 Crystal Clear Metal Glass Headlight Led 4000Lm H4 Light Bulb Headlamp Set https://a.co/d/ayN4PD5Edit: right side up
[Re: 65pacecar]
#3099191
12/03/22 01:15 PM
12/03/22 01:15 PM
Posts: 6,224 JERSEY
RJS
JERSEY
They are lifetime guarantee and are made of glass and metal. They don't have that aftermarket look to them which was important to me. Ron I just checked their website, looks like a better option. I’ve never heard of them before, thanks. Any issue with installation? They are supposed to be here Monday. Certain lights they build as ordered so it took about 1 1/2 to 2 weeks. Ron https://www.headlightexperts.com/carfinder?sid=uldhADxHA8
[Re: Blusmbl]
#3099192
12/03/22 01:17 PM
12/03/22 01:17 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Got a link to those? I like the stock look and am considering going LED if they are plug and play and look stock. I take it back, they were Octane, not Oracle, 220, 221… whatever it takes. Lol Octane Lighting 5-3/4 Crystal Clear Metal Glass Headlight Led 4000Lm H4 Light Bulb Headlamp Set https://a.co/d/ayN4PD5 No offense to your lights but that was also a look I wanted to avoid, I want them to look as stock as possible. Ron https://www.headlightexperts.com/carfinder?sid=uldhADxHA8
[Re: RJS]
#3099204
12/03/22 01:48 PM
12/03/22 01:48 PM
Blusmbl
Plymouth, MI
Yeah, it's not for everyone. I didn't want the halos around the lights but didn't mind the bulb reflector being visible in the middle.
Edit: will also say the best part is the light output doesn't vary with voltage like the original sealed beams did, it's constant regardless of engine speed or battery state of charge.
[Re: RJS]
#3099223
12/03/22 02:58 PM
12/03/22 02:58 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
[quote=RJS]I didn't go with the Holley's due to the price and the Holley logo across the front of the bulb. I just ordered from "Headlight Experts".
They are lifetime guarantee and are made of glass and metal. They don't have that aftermarket look to them which was important to me. Ron I just checked their website, looks like a better option. I’ve never heard of them before, thanks. Any issue with installation? They are supposed to be here Monday. Certain lights they build as ordered so it took about 1 1/2 to 2 weeks. Ron https://www.headlightexperts.com/carfinder?sid=uldhADxHA8 [/quote I looked up my 1966 Dodge Coronet, they want $100.00 each
[Re: Cab_Burge]
#3099258
12/03/22 05:00 PM
12/03/22 05:00 PM
Posts: 19,336 north of coder
moparx
as my charger has hideaway lights, all i want is something that will light up the road. as of now, in the high beams, i have aircraft landing lights. [relays DEFINITELY required] those things really light up the road, but put off some heat i don't particularly like, unless i'm moving. [blowing the heat away.] i have halogens in the low beam spots, but i still would like [need] something brighter for my eyeballs, without blinding oncoming drivers. lots of the new stuff have lights that are almost too bright, so there has to be something out there i can use. the brightness "may" be caused [or the perception thereof] by the different headlight "designs" now used, instead of the old style round headlights.
[Re: 65pacecar]
#3099280
12/03/22 06:08 PM
12/03/22 06:08 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Here U go... I installed (4) 5.75" Holley Retro-Brites(classic white) in my 70 RoadRunner. Also I fabricated my own Y wiring harness so each pair is wired in parallel, so I have (4) low or (4) high beams. The lites are bright and have a wide dispersion far superior to the OE incandescent bulbs, but no problem for oncoming traffic. The other major point is they have a nice rear aluminum heat sink and go into the OE mounting buckets without any cutting. For more info check out the latest Hemmings Muscle Machines for a positive review... Just my $0.02...
[Re: Sinitro]
#3100095
12/06/22 12:59 PM
12/06/22 12:59 PM
Posts: 6,710 KY
65pacecar
KY
Here U go... I installed (4) 5.75" Holley Retro-Brites(classic white) in my 70 RoadRunner. Also I fabricated my own Y wiring harness so each pair is wired in parallel, so I have (4) low or (4) high beams. The lites are bright and have a wide dispersion far superior to the OE incandescent bulbs, but no problem for oncoming traffic. The other major point is they have a nice rear aluminum heat sink and go into the OE mounting buckets without any cutting. For more info check out the latest Hemmings Muscle Machines for a positive review... Just my $0.02... Looks nice, thanks for the information.
[Re: gtx6970]
#3100224
12/06/22 08:36 PM
12/06/22 08:36 PM
Posts: 5,439 So Cal
Sinitro
So Cal
I converted one of mine to relays. That way the head light switch is not in the power loop. All it does it control relays HUGE difference without spending a ton of money And I still use the stock bulb Using relays for the headlites helps a lot for brightness but... In my case I wanted wider lite dispersion and brightness, and the Holley LEDs provide this, plus they draw less current than the OE bulbs.. Just my $0.02...
