Re: Holley Retrofit Headlights LED [Re: Sinitro] #3103318
12/18/22 01:28 PM
12/18/22 01:28 PM
KY
65pacecar Offline OP
KY
Originally Posted by Sinitro
Originally Posted by gtx6970
I converted one of mine to relays.
That way the head light switch is not in the power loop. All it does it control relays
HUGE difference without spending a ton of money And I still use the stock bulb
Using relays for the headlites helps a lot for brightness but...
In my case I wanted wider lite dispersion and brightness, and the Holley LEDs provide this, plus they draw less current than the OE bulbs..
Just my $0.02... wink
Thanks, went with the Holley lights for one of the cars, the main driver. Looking forward to see how they perform compared to original. I appreciate all the responses.
Re: Holley Retrofit Headlights LED [Re: 65pacecar] #3103379
12/18/22 05:37 PM
12/18/22 05:37 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I used sealed beam to H4 housings and H4 LED retrofit lamps on mine. Spent $40 on the housings (set of 4) and $80 on the lamps (set of 2). Haven't ordered another set yet to finish it. Lamps came from superbrightled.com. More than happy with the results for the money.
