Re: Anyone use lightweight batteries?
[Re: ValiantRich]
#3099146
12/03/22 09:18 AM
12/03/22 09:18 AM
Posts: 1,166 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Just measured my Optima Red Top... 39.8 lbs. There's an easy 20+ lbs without even going to one of the super small options.
I like Andy's idea of the clamp-on ammeter to do spot-checks on charging characteristics.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Leigh]
#3099700
12/05/22 05:22 AM
12/05/22 05:22 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I need ballast, however, I appreciate new, viable technology. Not sure if i agree about your needing ballast. I have a Dakota lithium 60 ah battery that weighs 16 lbs. It delivers the same reserve as a 100ah due to the difference in how the voltage stays up during discharge. It is also 60 amp alternater compatible. With that battery up front, you can dump the long cables to the trunk, saving another 10+ lbs. That would be a minimum reduction of 34 lbs in most cases, more in some. I haven't run it yet, but will in the spring.
[Re: gregsdart]
#3099814
12/05/22 02:01 PM
12/05/22 02:01 PM
Posts: 19,591 north of coder
moparx
as the inner fender below the battery box in my charger is slightly eaten up by acid leaking/gassing, i'm tempted to modify that area to mount a small, lightweight battery, and get rid of the factory mounting tray. as already said, it would save a bunch of work by not moving the battery into the trunk. however, what would one do for a cutoff switch at the rear ? a morse cable would work, but what size cable [not the outer sheath] would be appropriate ? if there was enough room, could the cable possibly be routed along the interior sill plate and pass through the firewall to the front frame rail, and still operate smoothly ?
[Re: moparx]
#3099838
12/05/22 03:17 PM
12/05/22 03:17 PM
gregsdart
as the inner fender below the battery box in my charger is slightly eaten up by acid leaking/gassing, i'm tempted to modify that area to mount a small, lightweight battery, and get rid of the factory mounting tray. as already said, it would save a bunch of work by not moving the battery into the trunk. however, what would one do for a cutoff switch at the rear ? a morse cable would work, but what size cable [not the outer sheath] would be appropriate ? if there was enough room, could the cable possibly be routed along the interior sill plate and pass through the firewall to the front frame rail, and still operate smoothly ? i have a rear cutoff using a morse cable to the switch up front. Nhra doesn't require a cutoff with a stock battery location up front. No sure on hood requirements
[Re: gregsdart]
#3100203
12/06/22 07:02 PM
12/06/22 07:02 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Originally Posted by moparx as the inner fender below the battery box in my charger is slightly eaten up by acid leaking/gassing, i'm tempted to modify that area to mount a small, lightweight battery, and get rid of the factory mounting tray. as already said, it would save a bunch of work by not moving the battery into the trunk. however, what would one do for a cutoff switch at the rear ? a morse cable would work, but what size cable [not the outer sheath] would be appropriate ? if there was enough room, could the cable possibly be routed along the interior sill plate and pass through the firewall to the front frame rail, and still operate smoothly ? beer
Exactly what I did. I cut down a repop battery tray, leaving enough room for a cut off switch. Although not required, it is piece of mind to shut off the car's electrical system as needed. Bad pic, but I will post an updates pic later.
[Re: moparx]
#3100209
12/06/22 07:35 PM
12/06/22 07:35 PM
gregsdart
what size cable are you using Greg ? Can't remember exactly, maybe 0? About 3/8 fine stranded welding cable. Since everything is up front, a size smaller is ok versus a rear mount cable.
