How about a Lexus question? #3098484
11/30/22 07:24 PM
11/30/22 07:24 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
Hi all,
My GF's son bought a daily driver 220,000 mile '99 RX300 and it had been hit or slid into something on the passenger side rear. The tire was torn but the wheel was not impacted, the rocker panel and bottom of the back door are mashed in and the lower front control arm on the right rear wheel is arched slightly so the tire toes in a little bit. I'm going to help him with the repair and we can replace the $25 part easy enough but curious if I'm going to have trouble getting that wheel/hub tugged back out so the new control arm lines up. This is a first for me on something with this kind of damage.
Thanks! beer
dstryr, since 1986.
Re: How about a Lexus question? [Re: dstryr] #3098489
11/30/22 07:35 PM
11/30/22 07:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A question about a Lexus...... work
Will it perplex us? shruggy
Re: How about a Lexus question? [Re: dstryr] #3098498
11/30/22 07:48 PM
11/30/22 07:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by dstryr
Hi all,
Thanks! beer
I think that's the question.
Mike
Re: How about a Lexus question? [Re: A12] #3098508
11/30/22 08:35 PM
11/30/22 08:35 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Regardless of make, what is actually bent? I understand what you're saying about the wheel, but is it due to bent frame/mounts or bent suspension components?
John
Re: How about a Lexus question? [Re: A12] #3098510
11/30/22 08:38 PM
11/30/22 08:38 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
lol Mike, yes that's the question.. is that hub going to come back straight (somewhat) willingly or ??
dstryr, since 1986.
Re: How about a Lexus question? [Re: dstryr] #3098512
11/30/22 08:48 PM
11/30/22 08:48 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
The hub attaches to the spindle. Are you asking if you can straighten a bent control arm or spindle or suspension cross member?
Earning every penny of that moderator paycheck.
DBAP
Re: How about a Lexus question? [Re: SattyNoCar] #3098513
11/30/22 08:48 PM
11/30/22 08:48 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
There are 2 lower control arms on each rear wheel. The forward one on the passenger side is slightly bent/arched from the impact. Just curious if that hub is likely to come back straight somewhat easily once I unbolt the control arm or if I'm going to have to figure out a Red Green solution to pull it out.
dstryr, since 1986.
Re: How about a Lexus question? [Re: not_a_charger] #3098514
11/30/22 08:52 PM
11/30/22 08:52 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
No sir, the lower front control arm is slightly bent, toeing the wheel in. What I'm not sure of is if that hub/spindle is going to come back straight easily once the bent control arm is off. Just want to put a new control arm on but if that spindle doesn't want to come back straight easily I'm going to have to put some thought into how I'll pull it straight with the tools i have.
dstryr, since 1986.
Re: How about a Lexus question? [Re: dstryr] #3098515
11/30/22 08:56 PM
11/30/22 08:56 PM
Assuming the spindle isn't damaged, you shouldn't have to do anything to it or to the hub. confused The radius rod, the strut, and the 2 lower control arms determine the position of the spindle. If nothing else is bent other than the front lower control arm, what are you concerned with regarding the spindle not being able to be moved to it's proper position?
DBAP
Re: How about a Lexus question? [Re: not_a_charger] #3098521
11/30/22 09:11 PM
11/30/22 09:11 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Probably going to require a hot pull.
Re: How about a Lexus question? [Re: Sunroofcuda] #3098522
11/30/22 09:17 PM
11/30/22 09:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You can actually buy parts for a Lexus? I tried to get a new battery once and took the old one to the Lexus dealer. They had no parts department and no place to even put the old battery on a counter! Finally two guys in white lab coats and gloves came out and take the battery, come back after a while with a new one. Apparently if a battery goes bad in a Lexus you call the dealer and a truck comes out and replaces it for you... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: How about a Lexus question? [Re: not_a_charger] #3098525
11/30/22 09:26 PM
11/30/22 09:26 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
About all you can do is replace the known bent parts and see where you are. If everything is OK, your good. If not, you have to find out what else is bent, and repeat the process. Bent parts are easy, you unbolt the bent stuff and put on new straight stuff. The problem occurs when the stuff the parts bolt onto is bent or twisted out of shape. Sometimes that shows up when the new parts don't fit right, but sometimes it won't show up until everything has been replaced, and you still can't get the wheel alignment correct. Then you may be required to have the "frame" pulled back straight.
This problem is universal among modern vehicles of all brands. Most of the time, replacing the bent parts solves the problems, but sometimes it doesn't. Sometimes rust and high mileage have an effect on this stuff as well. Some vehicles have known, or expected issues to look into before you start buying parts. For instance, a mid 2000s Chrysler mini van had issues with the upper strut tower sheet metal rusting out. If one came into my shop that was in a minor fender bender and the strut got bent (which is pretty expected), I would be looking at the condition of that upper strut tower before I bought the replacement struts. That area has a replacement fix available, but its something I would want to know beforehand.
Re: How about a Lexus question? [Re: not_a_charger] #3098526
11/30/22 09:27 PM
11/30/22 09:27 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
It is part # 24 that is bent. Once removed, I'm just asking if the spindle/hub should somewhat freely come back into line or if I might have to rig something to help pull the wheel/hub straight so that the new arm will line up on the bolt holes. Pretty straight forward question I thought.
dstryr, since 1986.
Re: How about a Lexus question? [Re: dstryr] #3098528
11/30/22 09:47 PM
11/30/22 09:47 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Since you are the only one with eyes on the issue it will be virtually impossible to answer your question. Without know what, if anything, is bent we cannot give you any ideas on how to deal with.
So no, the question is not pretty straightforward other than replace #24 and see.
Re: How about a Lexus question? [Re: dstryr] #3098530
11/30/22 09:52 PM
11/30/22 09:52 PM
IMGTX Online content
IMGTX  Online Content
If the only damage is the bent arm then it will all go back into place.
The big fear is if the mounting points of the suspension are moved out of place then you will still have problems.
Luckily for you those arms bend easy. Helped replace 4 this year.
If the mounting points are moved you will have to either replace the rear carriage (if it has one) or put the car on a frame machine.
Lots of modern cars use a carriage like our old K frames to hold all the rear suspension. They bolt it in as an assembly. If yours is that type and the carriage is bent you can probably replace it.
The big problem would be a bent frame or chassis.
Re: How about a Lexus question? [Re: dstryr] #3098539
11/30/22 10:23 PM
11/30/22 10:23 PM
Freeport IL USA
Freeport IL USA
If part 24 is bent, isn't part 25 a matching part on the other side of the spindle? I'd replace both 24 and 25 if both are attached to either side of the spindle. I would also expect to be replacing the mounting hardware. I can't see one side bending with out damaging the other side. Once everything is apart, that spindle can move a lot. If it doesn't sit back in place properly, something else is probably bent, but the mounting brackets may still also be bent. I can't see that from here.
Re: How about a Lexus question? [Re: poorboy] #3098590
12/01/22 08:46 AM
12/01/22 08:46 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I suspect it'll be fine...those lower arms are made of tin foil so likely the weak spot. I'd be more worried about getting the bolts out in one piece. Live in the rust belt?
Re: How about a Lexus question? [Re: Sunroofcuda] #3098592
12/01/22 08:53 AM
12/01/22 08:53 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
from your description and looking at not a charger parts image.
my 30+ years of autobody experience says #24 or #25 arm, whichever is the foreword one, is bent.
this is easy to diagnose by placing a straight edge against the rod. it should be perfectly straight against the straight edge. measure at vertical and 90*.
the center hub rarely bends, the knuckle itself usually bends before the hub.. the bearings will go bad and howl but the hub flanges rarely bend. if it's bent it will be easy to see by spinning when the wheel is off.
perception is 90% of reality
Re: How about a Lexus question? [Re: Dcuda69] #3098595
12/01/22 09:44 AM
12/01/22 09:44 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
This iagree The only issue you may have is the bolt that goes through the bushings. Yes you will need to pry and wiggle the new parts into place and even "sharpen" a point on the bolts to drive them back home. i have used a ratchet strap to the shipping anchors to pull suspension parts into place.
Shoot me a PM if you need any other help on this car as I am a master Toyota tech with 35 years experience.
Gus beer
64 Plymouth Savoy
Dana 60
Re: How about a Lexus question? [Re: IMGTX] #3098599
12/01/22 10:01 AM
12/01/22 10:01 AM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
Thank you. From underneath and the tire off it looks like only the rocker got mashed and the one arm bent. I'm hoping that because the tire was ripped open but the wheel was not hit that there's no frame or mounting point distortion. Sounds like it should move back into line barring unforeseen damage. beer
dstryr, since 1986.
