How about a Lexus question?
#3098484
11/30/22 07:24 PM
11/30/22 07:24 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
Hi all, My GF's son bought a daily driver 220,000 mile '99 RX300 and it had been hit or slid into something on the passenger side rear. The tire was torn but the wheel was not impacted, the rocker panel and bottom of the back door are mashed in and the lower front control arm on the right rear wheel is arched slightly so the tire toes in a little bit. I'm going to help him with the repair and we can replace the $25 part easy enough but curious if I'm going to have trouble getting that wheel/hub tugged back out so the new control arm lines up. This is a first for me on something with this kind of damage. Thanks!
dstryr, since 1986.
Re: How about a Lexus question?
[Re: dstryr]
#3098498
11/30/22 07:48 PM
11/30/22 07:48 PM
Posts: 21,497 N.E. OHIO, USA
A12
N.E. OHIO, USA
Hi all, My GF's son bought a daily driver 220,000 mile '99 RX300 and it had been hit or slid into something on the passenger side rear. The tire was torn but the wheel was not impacted, the rocker panel and bottom of the back door are mashed in and the lower front control arm on the right rear wheel is arched slightly so the tire toes in a little bit. I'm going to help him with the repair and we can replace the $25 part easy enough but curious if I'm going to have trouble getting that wheel/hub tugged back out so the new control arm lines up. This is a first for me on something with this kind of damage. Thanks! I think that's the question. Mike
[Re: A12]
#3098508
11/30/22 08:35 PM
11/30/22 08:35 PM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
Regardless of make, what is actually bent? I understand what you're saying about the wheel, but is it due to bent frame/mounts or bent suspension components?
John
[Re: A12]
#3098510
11/30/22 08:38 PM
11/30/22 08:38 PM
dstryr
Wendy, I'm home.
lol Mike, yes that's the question.. is that hub going to come back straight (somewhat) willingly or ??
dstryr, since 1986.
[Re: SattyNoCar]
#3098513
11/30/22 08:48 PM
11/30/22 08:48 PM
dstryr
Wendy, I'm home.
There are 2 lower control arms on each rear wheel. The forward one on the passenger side is slightly bent/arched from the impact. Just curious if that hub is likely to come back straight somewhat easily once I unbolt the control arm or if I'm going to have to figure out a Red Green solution to pull it out.
dstryr, since 1986.
[Re: not_a_charger]
#3098514
11/30/22 08:52 PM
11/30/22 08:52 PM
dstryr
Wendy, I'm home.
The hub attaches to the spindle. Are you asking if you can straighten a bent control arm or spindle or suspension cross member? No sir, the lower front control arm is slightly bent, toeing the wheel in. What I'm not sure of is if that hub/spindle is going to come back straight easily once the bent control arm is off. Just want to put a new control arm on but if that spindle doesn't want to come back straight easily I'm going to have to put some thought into how I'll pull it straight with the tools i have.
dstryr, since 1986.
[Re: dstryr]
#3098515
11/30/22 08:56 PM
11/30/22 08:56 PM
Posts: 19,856 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Assuming the spindle isn't damaged, you shouldn't have to do anything to it or to the hub. The radius rod, the strut, and the 2 lower control arms determine the position of the spindle. If nothing else is bent other than the front lower control arm, what are you concerned with regarding the spindle not being able to be moved to it's proper position?
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#3098525
11/30/22 09:26 PM
11/30/22 09:26 PM
Posts: 10,537 Freeport IL USA
poorboy
Freeport IL USA
About all you can do is replace the known bent parts and see where you are. If everything is OK, your good. If not, you have to find out what else is bent, and repeat the process. Bent parts are easy, you unbolt the bent stuff and put on new straight stuff. The problem occurs when the stuff the parts bolt onto is bent or twisted out of shape. Sometimes that shows up when the new parts don't fit right, but sometimes it won't show up until everything has been replaced, and you still can't get the wheel alignment correct. Then you may be required to have the "frame" pulled back straight.
This problem is universal among modern vehicles of all brands. Most of the time, replacing the bent parts solves the problems, but sometimes it doesn't. Sometimes rust and high mileage have an effect on this stuff as well. Some vehicles have known, or expected issues to look into before you start buying parts. For instance, a mid 2000s Chrysler mini van had issues with the upper strut tower sheet metal rusting out. If one came into my shop that was in a minor fender bender and the strut got bent (which is pretty expected), I would be looking at the condition of that upper strut tower before I bought the replacement struts. That area has a replacement fix available, but its something I would want to know beforehand.
[Re: not_a_charger]
#3098526
11/30/22 09:27 PM
11/30/22 09:27 PM
dstryr
Wendy, I'm home.
Assuming the spindle isn't damaged, you shouldn't have to do anything to it or to the hub. The radius rod, the strut, and the 2 lower control arms determine the position of the spindle. If nothing else is bent other than the front lower control arm, what are you concerned with regarding the spindle not being able to be moved to it's proper position? It is part # 24 that is bent. Once removed, I'm just asking if the spindle/hub should somewhat freely come back into line or if I might have to rig something to help pull the wheel/hub straight so that the new arm will line up on the bolt holes. Pretty straight forward question I thought.
dstryr, since 1986.
[Re: dstryr]
#3098528
11/30/22 09:47 PM
11/30/22 09:47 PM
Posts: 6,221 nowhere
Sniper
nowhere
Since you are the only one with eyes on the issue it will be virtually impossible to answer your question. Without know what, if anything, is bent we cannot give you any ideas on how to deal with. So no, the question is not pretty straightforward other than replace #24 and see.
[Re: dstryr]
#3098539
11/30/22 10:23 PM
11/30/22 10:23 PM
poorboy
Freeport IL USA
Assuming the spindle isn't damaged, you shouldn't have to do anything to it or to the hub. The radius rod, the strut, and the 2 lower control arms determine the position of the spindle. If nothing else is bent other than the front lower control arm, what are you concerned with regarding the spindle not being able to be moved to it's proper position? It is part # 24 that is bent. Once removed, I'm just asking if the spindle/hub should somewhat freely come back into line or if I might have to rig something to help pull the wheel/hub straight so that the new arm will line up on the bolt holes. Pretty straight forward question I thought. If part 24 is bent, isn't part 25 a matching part on the other side of the spindle? I'd replace both 24 and 25 if both are attached to either side of the spindle. I would also expect to be replacing the mounting hardware. I can't see one side bending with out damaging the other side. Once everything is apart, that spindle can move a lot. If it doesn't sit back in place properly, something else is probably bent, but the mounting brackets may still also be bent. I can't see that from here.
[Re: Sunroofcuda]
#3098592
12/01/22 08:53 AM
12/01/22 08:53 AM
Posts: 4,914 new berlin wisconsin
Mr T2U
from your description and looking at not a charger parts image. my 30+ years of autobody experience says #24 or #25 arm, whichever is the foreword one, is bent. this is easy to diagnose by placing a straight edge against the rod. it should be perfectly straight against the straight edge. measure at vertical and 90*. the center hub rarely bends, the knuckle itself usually bends before the hub.. the bearings will go bad and howl but the hub flanges rarely bend. if it's bent it will be easy to see by spinning when the wheel is off.
perception is 90% of reality
[Re: Dcuda69]
#3098595
12/01/22 09:44 AM
12/01/22 09:44 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I suspect it'll be fine...those lower arms are made of tin foil so likely the weak spot. I'd be more worried about getting the bolts out in one piece. Live in the rust belt? This The only issue you may have is the bolt that goes through the bushings. Yes you will need to pry and wiggle the new parts into place and even "sharpen" a point on the bolts to drive them back home. i have used a ratchet strap to the shipping anchors to pull suspension parts into place. Shoot me a PM if you need any other help on this car as I am a master Toyota tech with 35 years experience. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: IMGTX]
#3098599
12/01/22 10:01 AM
12/01/22 10:01 AM
dstryr
Wendy, I'm home.
If the only damage is the bent arm then it will all go back into place.
The big fear is if the mounting points of the suspension are moved out of place then you will still have problems.
Luckily for you those arms bend easy. Helped replace 4 this year.
If the mounting points are moved you will have to either replace the rear carriage (if it has one) or put the car on a frame machine.
Lots of modern cars use a carriage like our old K frames to hold all the rear suspension. They bolt it in as an assembly. If yours is that type and the carriage is bent you can probably replace it.
The big problem would be a bent frame or chassis. Thank you. From underneath and the tire off it looks like only the rocker got mashed and the one arm bent. I'm hoping that because the tire was ripped open but the wheel was not hit that there's no frame or mounting point distortion. Sounds like it should move back into line barring unforeseen damage.
dstryr, since 1986.
