1966 B body front spring hangers
#3098382
11/30/22 01:32 PM
11/30/22 01:32 PM
Posts: 21,399 It's a dry heat
gtx6970
It's a dry heat
I can find the front spring hangers for stock location and to lower the car. Yet none to raise the rear of the car ? https://www.ebay.com/itm/123949839653?Any options avail to lift one. Maybe 1.5 is what Im looking for The car has new Mopar perf leaf springs and it just sits to low. The tires rub up inside the tub area on bumps
Re: 1966 B body front spring hangers
[Re: gtx6970]
#3098386
11/30/22 01:55 PM
11/30/22 01:55 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I'm not sure about 66 but some spring hangers are Dodge or Plymouth specific as it changes the wheelbase between models... The ones I bought for my 65 I think have both sets of holes with a set to also lower the front spring attachment... I don't ever remember seeing ones with lower holes that raise the rear ride height... However they could be easily made from a stock set and some 3/16" flat plate...
...FAFO...
[Re: gtx6970]
#3098392
11/30/22 02:41 PM
11/30/22 02:41 PM
Posts: 12,231 Looking for a way out of Middl...
IMGTX
I am pretty sure that the 4 mounting studs are wider apart at the bottom instead of the top but could you possibly modify and invert the hangers? Maybe sandwich the modified hanger between a 1/4" steel plate and the car body for extra strength if you feel the modifications need reinforcement? On a side note since the spring pivots on the rear hanger you will have to lower the front bolt a lot more than 1" to get 1" body lift. Getting 1.5" might require lowering the front mount and the rear hanger 1.5" at the same time. I'm thinking re-arching the spring would be the way to go. Possibly some helper springs/air bags might work too. Dare I say it Air Shocks, not pumped too much but just for the little lift. (Let the mud slinging start for me offering the suggestion of air shocks begin) IF you do go the air shock route I suggest putting separate fill points for each shock to prevent air from migrating shock to shock.
[Re: IMGTX]
#3098409
11/30/22 03:39 PM
11/30/22 03:39 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Go to a narrower tire or get a wheel with more positive offset. 7.75 X 14 were the stock tires on a '66-'67 Hemi car, not a lot of rubber in anyone's book.
[Re: 6PakBee]
#3098429
11/30/22 04:27 PM
11/30/22 04:27 PM
gtx6970
It's a dry heat
Go to a narrower tire or get a wheel with more positive offset. 7.75 X 14 were the stock tires on a '66-'67 Hemi car, not a lot of rubber in anyone's book. Its not the hemi car I need to raise. Its my other 66, 383 auto. Im looking for the least expensive option to lift the ars up. Tires are like new so thats a last resort. Air shocks are my option. The leaf springs are / were new Mopar Performance " hemi " springs. And the car sits a good 3 inches lower than my black car and its on stock original hemi springs Its sitting on 15x7 torque thrusts with 245-60-15s and the outer sidewall rub up in the wheel house NOT on the lip. So its at least not cutting the tire up,,,just leaving ugly rub marks on the sidewall
[Re: gtx6970]
#3098625
12/01/22 10:58 AM
12/01/22 10:58 AM
6PakBee
North Dakota
Go to a narrower tire or get a wheel with more positive offset. 7.75 X 14 were the stock tires on a '66-'67 Hemi car, not a lot of rubber in anyone's book. Its not the hemi car I need to raise. Its my other 66, 383 auto. Im looking for the least expensive option to lift the ars up. Tires are like new so thats a last resort. Air shocks are my option. The leaf springs are / were new Mopar Performance " hemi " springs. And the car sits a good 3 inches lower than my black car and its on stock original hemi springs Its sitting on 15x7 torque thrusts with 245-60-15s and the outer sidewall rub up in the wheel house NOT on the lip. So its at least not cutting the tire up,,,just leaving ugly rub marks on the sidewall I understand fully. I just use the Hemi reference as it illustrates how little room is in the '66-'67 rear wheel tubs. And I know exactly what you are hitting, the outer wheel house goes vertical off the wheel opening and then narrows toward the center of the car with a "bump". After this narrowing is where they always rub. As to what to do, maybe this would work rather than air shocks Coilover ShocksAdvantage: Install them and forget them Disadvantages: Can't be adjusted (unless you get the really high dollar units. Just a question, do the springs have a negative arch, positive arch, or flat? IIRC, the stock springs should be flat to slightly negative.
[Re: gtx6970]
#3098692
12/01/22 03:04 PM
12/01/22 03:04 PM
Posts: 19,342 north of coder
moparx
another thing popped out at me when you posted a picture of the label. "made in mexico".............. almost everyone i have talked to, listened to, and had experience with, those springs [and others, especially the super stock springs] made there had bad comments. espo springs have always had good comments to my knowledge, so if you are considering them, a +1 or +2 might be a thing to consider. however, all springs will settle a small amount after the install, so keep that in mind. as i said before, you could always add a leaf [or two] to the spring package you now have from the springs you removed, and all it would cost is a couple of dollars for new center bolts.
[Re: moparx]
#3098699
12/01/22 03:24 PM
12/01/22 03:24 PM
gtx6970
It's a dry heat
another thing popped out at me when you posted a picture of the label. "made in mexico".............. almost everyone i have talked to, listened to, and had experience with, those springs [and others, especially the super stock springs] made there had bad comments. espo springs have always had good comments to my knowledge, so if you are considering them, a +1 or +2 might be a thing to consider. however, all springs will settle a small amount after the install, so keep that in mind. as i said before, you could always add a leaf [or two] to the spring package you now have from the springs you removed, and all it would cost is a couple of dollars for new center bolts. I dont have the old springs. I bought the car like it is this past Aug. Or I would be switching back to the stock springs I think I will order some air shocks today. That way I control how much lift I put in it . Wrong time of year to be spending $400 on springs especially on a car Im not 100% sure I will keep ( the bug for a convertible is getting strong )
[Re: gtx6970]
#3098712
12/01/22 04:38 PM
12/01/22 04:38 PM
6PakBee
North Dakota
Springs in this car are flat as it sits ,,,,notice the rear shackle . And the label was still on them Ive thought about the coil overs. Just concerned is getting it to high.
If you were at the 'stock' ride height, I would share your concern. But as much as it's sagging, I don't think you'd have a problem. The NAPA units are rated for only 1,100 lbs of additional support so I can't believe that you'd be in the air. The saving grace is that with either the coilovers or the air shocks, the upper shock mount on the '66-'67 is substantial so I doubt that the upper mount would be coming through the floor.
