Re: Air compressor check valve question(s) [Re: 6PakBee] #3101896
12/13/22 12:23 PM
12/13/22 12:23 PM
moparx Online content
moparx  Online Content
Originally Posted by 6PakBee
Lay the compressor on its side and take a hacksaw blade and make two cuts 180 degrees apart in the brass fitting just down to the threads. Then take a small chisel and peel the remains of the fitting out of the tank. Removed a number of large brass fittings like this. Just don't get carried away with the cuts or you'll have another problem.
i have done this as well.
if you have an air saw, that will make the job easier.
as to the brass becoming brittle, causing it to break, the actual cause of the break was that the brass had galled to the steel threads.
repaired many fittings because of this in my 45 year machinist career. the cause was always galled threads due to dissimilar materials. even using teflon tape or paste will not rule out this possibility, although it does reduce the chance of breakage somewhat.
beer
Re: Air compressor check valve question(s) [Re: moparx] #3101906
12/13/22 12:53 PM
12/13/22 12:53 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Teflon Tape on stainless steel thread being screwed into aluminum can be a real headache saver.
Re: Air compressor check valve question(s) [Re: 360view] #3102072
12/13/22 08:55 PM
12/13/22 08:55 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Yes, it would but I only have one compressor......... work laugh2
(just struck me funny, not upset)
John
Re: Air compressor check valve question(s) [Re: SattyNoCar] #3102259
12/14/22 01:54 PM
12/14/22 01:54 PM
that was kind of a stupid thing for me to say, since your problem involves your compressor. my bad. spank
i was just thinking off the top of my hairless head.
next best thing would be to take a hacksaw blade and grind down the top side of the blade so it would fit inside the fitting, then use that to slice a couple of slots into the broken part of the brass. the slots do not really need to be 180 apart, just enough so when you can get the first chunk of the fitting out, there is enough room for the rest of the fitting to collapse and be small enough to exit the tank threads.
you could also use a jig saw with a fine tooth metal blade to make the cuts. use the low speed if it has that feature, or if the variable speed kind, be "gentle" on the trigger.
use some grease while cutting regardless of the method, to keep the most particles of the cut you can out of the tank.
whatever method you use, please let us know how you make out.
beer
