Best 4 speed swap setup #3092671
11/08/22 07:55 PM
11/08/22 07:55 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm going to swap my 85 w150 from an automatic over to a 4 speed. I would love to find one of the close ratio np435s, but from what I've read, they are pretty much nonexistent. Is there a certain year transmission and transfer case setup that is better than others? I only use the truck for work and light hauling, no off roading. I want part time 4 wheel drive and not full time, as I know some 70s units were full time. Also the engine that I'm planning on using is a 1973 340 that I have, but the 73s had an external balance crankshaft, so I'm not sure if the flywheel and clutch setup (23 spline) would work with the np435.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Best 4 speed swap setup [Re: 73cuda340] #3092687
11/08/22 08:50 PM
11/08/22 08:50 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a complete set-up off a late 70's Power Wagon, not sure what trans it is but has an attached transfer case. Clutch, bellhousing, flywheel, shifter basically everything but driveshaft. This is a stock picture of what it looks like, but I can take a picture tomorrow of exactly what is with it.
JB Rhinehart, Realist
A-Body's RULE!
Re: Best 4 speed swap setup [Re: Rhinodart] #3093902
11/13/22 11:10 AM
11/13/22 11:10 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
The 340 car flywheel would be 130 tooth. A truck np435 would be 143 tooth. Dodge started making the np445(np4530) in 1970. it is close ratio with a 4.56 syncro first gear. I don't know if they continued to offer the np435 in close ratio after this. The case is 13 inches long on the np445 vs 11on a np435. There may also be a blue tag on the right side that gives info. One line will read model 4530.
Re: Best 4 speed swap setup [Re: 58pwrwgn] #3093904
11/13/22 11:14 AM
11/13/22 11:14 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Top view np445/ np4530
Re: Best 4 speed swap setup [Re: 58pwrwgn] #3094256
11/14/22 11:38 PM
11/14/22 11:38 PM
clarks summit pa
clarks summit pa
Would it be possible to use the 130 tooth flywheel with the truck 4 speed? I know it's going to be tough to find another flywheel for that engine being that it's external balance.
Re: Best 4 speed swap setup [Re: 73cuda340] #3094312
11/15/22 11:00 AM
11/15/22 11:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just buy a neutral balance flywheel and have the machine shop drill it out for the proper imbalance. The drawings are in the Moparts tech archive
FLYWHEEL
Template
[Linked Image].
Re: Best 4 speed swap setup [Re: Sniper] #3094320
11/15/22 11:24 AM
11/15/22 11:24 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
FLYWHEEL
Template
[Linked Image].
That drawing is for 10.5" 130 tooth flywheel. Chrysler never used 11.0" 143 tooth wheel on the 340 cast crank engines. Will it work? I don't know.
I do know the location of the drilled balance holes on a 360 cast crank flywheel are different between the 130/143 tooth flywheels.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Best 4 speed swap setup [Re: Dan Brewer] #3094341
11/15/22 12:41 PM
11/15/22 12:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Well, everything is referenced to the center of the flywheel. Not sure it would be an issue and the amount of needed imbalance will still be the same.
Now the Magnum 360 and the LA 360 have different imbalance. So if the 143 tooth flywheel were a Magnum one it would not look like 130 tooth pass car one either.
Re: Best 4 speed swap setup [Re: Sniper] #3096656
11/23/22 09:45 PM
11/23/22 09:45 PM
clarks summit pa
clarks summit pa
Ok thanks, but just out of curiosity, is it possible to use the 130 tooth flywheel setup instead of the 143?
Re: Best 4 speed swap setup [Re: 73cuda340] #3096666
11/23/22 10:26 PM
11/23/22 10:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Bellhousings are different as far as I know. But I am not a truck guy, MIght ask this in the truck forum.
Re: Best 4 speed swap setup [Re: 73cuda340] #3097701
11/28/22 09:47 AM
11/28/22 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the bellhousing calls for a 143 tooth flywheel then no you can not use a 130 tooth as the diameter of it is smaller and the starter will not engage withthe flywheel. If you want to use a 130 tooth wheel you need a bellhousing that is speced for one .
Re: Best 4 speed swap setup [Re: Sniper] #3097769
11/28/22 01:16 PM
11/28/22 01:16 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Car bell (130) vs. truck bell (143) twocents
Re: Best 4 speed swap setup [Re: Hugh Jorgan] #3099124
12/03/22 01:06 AM
12/03/22 01:06 AM
clarks summit pa
clarks summit pa
Ok thanks, now back to solving my external balance flywheel issue then. I don't trust any of the machine shops around me to handle rebalancing an internal one to external
Re: Best 4 speed swap setup [Re: Hugh Jorgan] #3099369
12/04/22 12:46 AM
12/04/22 12:46 AM
Cab_Burge Online work
Cab_Burge  Online Work
B and E body cars have had both 130 and 143 tooth flywheels depending on which year and motor size, IE 1967 Dodge with 383 gets 130 tooth flywheel and bellhouisng, 440 get the 143 tooth bel and flywheel,
But the 1969 B bodies got 143 tooth on both BB, B motors and some 426 hemi motors confused
hopefully someone more knowledgeable on this will chime in and offer better information on this luck
