The cnc porting is just icing on the cake. It makes the Stealths come alive! No effect on streetability.
As far as fuel injection, we have run a Demon 850 carb on the street for over 7 years now and it starts instantly and runs great! Very little finessing to get it right.
We did a Howards hydraulic roller and it's a great cam. No noisy valvetrain, sounds like a mild cam in a stock engine. Maintenance free as you can set the pre-load and never mess with it again.
I'm a fan of good headers as we run Hedman 78030's. No denting necessary and they are 1 3/4. More than enough flow as we have run in the low 10's at 133 mph with them. Lots of plug/wire clearance and easy install.
