Long story short, have a couple buddies wanting to make a drift car from a mopar and looking for a REAR wheel drive automatic car from the 1980's to present model. I know some guys want the slant six up front, but that's boring and limits the platform for engine swapping to different bodies, weighs alot and limits upgrades. Thinking if there was something good from Jeep, PT Cruiser, etc. that could be built up and run good would be a start. Any suggestions?
Re: Mopar 4/6-cylinder RWD auto,which is good donor for racing?
[Re: migsBIG]
#3097522 11/27/2211:51 AM11/27/2211:51 AM
Jeep Cherokee. Millions of them have been made and some even come in 2wd. Of course if you are highly motivated, swap in a different front stub to avoid the straight axle. 3.7, 4.0, 4.7, 5.7 engines have the ability to be fitted to it.
Stealth/3000 could also fit the bill but aren't as easily found, need to be converted from FWD/AWD and will require fab to get differing engines in them. But they do have the architecture to allow RWD.
Of course there are also the old M body police sedans and pick-up trucks. Maybe even a van if you really want to dare to be different.
[Re: TC@HP2]
#3097535 11/27/2212:27 PM11/27/2212:27 PM
So if it was made by Mitsubishi with a Dodge emblem on it it's not a "mopar" in my book. What about a Daytona? There are several of them on you tube(V8 rear wheel drive).
[Re: migsBIG]
#3097589 11/27/2204:11 PM11/27/2204:11 PM
Basic architecture for drift stuff seems to be front-engine, RWD, and it seems a wheelbase somewhere around 100"-110" . Ft wheels need a lot of steering angle, which would require some fab work. I would think a stiff chassis makes the slip angles more predictable and controllable. Seating that holds your happy butt & torso in place would be nice, too. Best would be some kind of tire deal !
[Re: stumpy]
#3097686 11/28/2202:13 AM11/28/2202:13 AM
Just spoke with my buddies again and they needed ‘just’ a drivetrain choice as they already have a car in mind.
They would love a 4 banger, but would work with a 6 cylinder. They are trying to keep it a simple swap as they have limited room to work with and don’t want over complicated engine electronics. Thanks for the help soo far. If they decide on a jeep 4.0, do you think it would work?
[Re: migsBIG]
#3097976 11/28/2211:34 PM11/28/2211:34 PM
Only drawback I can see to the 4.0 is length. Other than that it's easy to set one up with very little electronics and transmissions choices are pretty wide open.
[Re: slantzilla]
#3097999 11/29/2206:50 AM11/29/2206:50 AM
2.4 turbo from the neon/pt. They put 2.4s in many, many vehicles in the early to mid 2000s. My neighbor had a 2006 wrangler with a 6 speed he put neon sourced turbo bits on, and daily drove it. Its a light engine that makes tons of power and is not complicated. Lots of aftermarket support.
[Re: Fat_Mike]
#3098256 11/29/2211:56 PM11/29/2211:56 PM
A 2.4 turbo could be a fun toy in a light vehicle, but I don't know if Chrysler ever put one in a rear wheel drive configuration. Making a transmission work might take all the fun out of it.
A V6 option might be a high output 3.6 for the early modern Chargers. A lot of kick out of a light weight package. I do hear they are not a small sized package, never messed with one.
A "B" or an "F" body could be GM. The other Mopar bodies wouldn't be considered as being off topic.
[Re: poorboy]
#3098674 12/01/2201:19 PM12/01/2201:19 PM
no. they have a yard of nothing but mopars so it's not GM stuff. they just need an idea what car is good for the drivetrain so they can use it for a donor.
[Re: poorboy]
#3100032 12/06/2206:59 AM12/06/2206:59 AM
Did you read my entire post? Take a minute and search YouTube for the dart that was engine swapped to an srt4 setup. Its a bad machine.
