Finally have a lift! #3097417
11/26/22 11:40 PM
11/26/22 11:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Only took me 60 years to get one. Quite excited to finally have one. Now I get to take out the race car transmission to fix the darn thing..........
Re: Finally have a lift! [Re: markz528] #3097439
11/27/22 02:31 AM
11/27/22 02:31 AM
New York, USA
Chargerfan68 Offline
New York, USA
Congratulations! That looks like a very nice shop/ garage. Hope it brings years of happy wrenchin to you.
Re: Finally have a lift! [Re: markz528] #3097441
11/27/22 02:50 AM
11/27/22 02:50 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Good looking home (?) shop . Now all you need is a 4 post hoist for those other jobs 😁
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Finally have a lift! [Re: markz528] #3097463
11/27/22 09:15 AM
11/27/22 09:15 AM
NC
440Jim Offline
440Jim  Offline
NC
Bendpak Asymmetric
Nice $,$$$
I would like a tall lift, since I have 14ft headroom.
Quote
XPR-10XLThe taller carriage offers an extra 6" of lift, which means vehicles can be raised a full 75" (about 80" with adapters). Height Overall: 157"
Re: Finally have a lift! [Re: 440Jim] #3097470
11/27/22 09:39 AM
11/27/22 09:39 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m jealous. Very nice!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Finally have a lift! [Re: markz528] #3097472
11/27/22 09:57 AM
11/27/22 09:57 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Finally have a lift! [Re: justinp61] #3097490
11/27/22 11:11 AM
11/27/22 11:11 AM
NC
440Jim Offline
440Jim  Offline
NC
Yes,
After spending the money on the lift, now a need to spend more for the trans jack, etc.
I should have put a lift in my new shop when the building was built in 2019. Lift prices were lower then...
Re: Finally have a lift! [Re: justinp61] #3097493
11/27/22 11:29 AM
11/27/22 11:29 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I just installed a new Atlas BP8000 lift in my 3rd car garage bay area 2 weeks ago. This lift is built very well and designed for home garage ceiling heights, and minimum 4”-5” concrete thickness. I have 10’ ceiling height. When we built the house 22 years ago I had the builder make the entire garage area 5’ deeper than normal and they also made the concrete floors 12” thick. I had an electrician come add 240v before the install. I’m going to install new taller garage door rails which will give me another 26” of lift space putting the door a couple inches below the ceiling when open, and install a new side-jack garage door opener; once both are done it’ll allow total access to the underside of the car with the garage door open or closed. I could get away with just removing the current garage door opener, but the door would always need to be closed when the car is extended up on the lift. Perfect fit, and allows plenty of room around the entire car. This definitely helps make car maintenance easier, and most importantly it helps keep the body off the ground.
ECB9A3AC-DF96-418E-BB83-30581C035C1F.jpegBB725FDA-AC5A-4643-888E-9F91ECD1CBBA.jpeg43EEF289-9FEA-4A8A-9E01-DB1781603928.jpeg
"Any fool can know. The point is to understand"
- A. Einstein
Re: Finally have a lift! [Re: EvilB1Dart] #3097507
11/27/22 11:58 AM
11/27/22 11:58 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sweet!! up
Re: Finally have a lift! [Re: markz528] #3097514
11/27/22 12:32 PM
11/27/22 12:32 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Congratulations on the beautiful addition to your family. up
Re: Finally have a lift! [Re: fast68plymouth] #3097521
11/27/22 12:50 PM
11/27/22 12:50 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I had an old 2 post lift I finally cleaned up and installed this year. Love it, just wish it went a touch higher as im 6’3”. Still makes life so much easier. Congrats, you’re going to love it.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Finally have a lift! [Re: 68 HEMI GTS] #3097541
11/27/22 01:37 PM
11/27/22 01:37 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
In the long process of building my new garage. I went with an in ground scissors lift. It has a 9000 lb capacity, and rises 6’ above the floor height. They can be used as a pair for lifting cars, or singularity for motorcycles/ atv/ lawnmower etc… A lot of extra work in the floor prep, but having full floor space when not in use was worth it for me.
Re: Finally have a lift! [Re: 68 HEMI GTS] #3097542
11/27/22 01:37 PM
11/27/22 01:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Next to heat a hoist is the best tool you can own. I've been spoiled for 18 years.
Doug
Re: Finally have a lift! [Re: dvw] #3097564
11/27/22 03:07 PM
11/27/22 03:07 PM
moparx Offline
moparx  Offline
i'm jealous of you guys !
the older i get, the dumber i realize i was when i replaced my garage roof way back in 1996.
at that time, i thought about raising it some to gain overhead storage and a little more head room.
for some reason, i didn't follow through. a future lift was never even thought of.
well, now my old bones are telling me i need to do something my old man was fond of saying : "get a bag full'a quarters and back up next to the a$$ kickin' machine !" , for not raising the head room when i had the perfect chance to do so.
as it is now, i only have roughly 7ft of clearance, so a mid level lift is my only hope, but the ones i have seen seem to limit the access to the underside somewhat, and i haven't been very impressed with their operation or construction.
beer
Re: Finally have a lift! [Re: markz528] #3097741
11/28/22 11:53 AM
11/28/22 11:53 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Congrats!
The hoist and hydronic/radiant floor heat make it enjoyable to keep doing all this kind of stuff.
Rich H.
Esse Quam Videri
Re: Finally have a lift! [Re: 68 HEMI GTS] #3097880
11/28/22 06:54 PM
11/28/22 06:54 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I'm also 6'3 so I bought an extra height lift for tall people. The ceiling height is 14 foot and the lift is just over 13 foot at the top so it should be decent head room.
Changed the oil in my daughter's car on it Saturday night. What a blessing! I bought a oil drain unit with the lift so I'm good there, and ordered a transmission lift today. Bought what I hope is a good one!
Re: Finally have a lift! [Re: markz528] #3097884
11/28/22 07:04 PM
11/28/22 07:04 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Hay man! Can I come over and borrow your garage. smile
Re: Finally have a lift! [Re: FastmOp] #3097890
11/28/22 07:17 PM
11/28/22 07:17 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Congrats guys, your garages and lift setups look awesome!
How thick is your concrete? I've heard a normal 2 post needs 4.5" of concrete thickness to be safe, and I'm not sure mine meets it.
My garage is barn shaped with a super tall roof but has a little room above it that limits the height. I don't know if I can rip the floor out of the upstairs room to gain roof height without the structure falling down, but I'd love to do that to put a full height 2 post in.
Re: Finally have a lift! [Re: Blusmbl] #3098029
11/29/22 09:56 AM
11/29/22 09:56 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I took a lot into consideration before buying my lift this month. Mainly because I have been waiting for approval from my HOA to allow me to build a 30’Wx30’Dx16’H shop on my property. That’s taking a while so I didn’t want to further delay the purchase because these things keep increasing in price. I decided on this lift because it has nice features and a few upgrades versus others I checked out, and the price was somewhat affordable. It fits the current installed location perfectly and allows total access in a limited amount of space. If the HOA approves my request in the near future I’ll remove it from my garage and reinstall in the shop. Another thing I considered was most times I’ve used other lifts the vehicles are rarely positioned at max height.
My garage ceiling is 10’ and my concrete is 12” thick. You'll need to know your thickness for sure, and if anything else is going on inside the concrete where your holes will be drilled. This lift (Atlas BP8000) I have needs minimum 9’-6" ceiling height and 4-5” concrete thickness. I guess in the end you have to also consider your personal body height, and the size of your vehicle(s) you’ll be putting on it. Mine is good for 8,000#’s and all our vehicles we own will work within the current ceiling height to complete any work needed to be done, which also includes my Ram 2500 Cummins (but not at max lift).
Here’s the dimensions sheet for my lift to give a little more perspective.
- A. Einstein
Re: Finally have a lift! [Re: Blusmbl] #3098066
11/29/22 12:41 PM
11/29/22 12:41 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
My concrete is not what I paid for. I paid for extra thick under the lift but I also missed the location by about a foot. Still should have been thick under it, but it’s not. Minimum requirement is 4.25 inches 3000 psi slab. I bought a 5 inch slab and it’s 4500 psi. Where I broke through drilling the studs it was right around 5 inches so I’m good but not fantastic. I was drilling deeper than recommended. Instructions said drill 4 inches deep I tried to drill 5 inches. Eventually settled on 4.25 inches deep holes.
