where does this floor brace go E-body #3097175
11/26/22 01:41 AM
11/26/22 01:41 AM
new york
72restocuda Offline OP
new york
Putting a parts list of body panels to replace when I come across something called a floor brace panel rear seat rocker wheelhouse - Its supposed to go between the seat pan and the inner wheelhouse and rocker panel - I am gonna replace my rear quarter panels - I haven't seen behind them in almost 20 years but I don't remember every seeing any sheet metal that looks like that. I guess I could wait to order stuff when I pull off the quarters. Thanks
-Steve
Re: where does this floor brace go E-body [Re: 72restocuda] #3097199
11/26/22 09:21 AM
11/26/22 09:21 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i haven't seen the list of sheetmetal to order for E bodies.
i know there is a thick brace thats under the rocker panel and on top of the inner rocker panel. it starts at about where the 1/4 panel jamb starts and runs to the rear wheelhouse. it's about 2' long and helps reinforce the torque box area. the rear window guide bolts to a bracket on this part. on convertibles this brace runs the length of the rocker panel.
is this the part you are describing?
perception is 90% of reality
Re: where does this floor brace go E-body [Re: Mr T2U] #3097252
11/26/22 01:01 PM
11/26/22 01:01 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Are you talking about the panel that goes between the trunk pan and rear quarter panel like this?
I believe it is called the drop-off panel.
My Monster are real!
Living within your means makes life pretty easy.
Re: where does this floor brace go E-body [Re: 72restocuda] #3097282
11/26/22 02:18 PM
11/26/22 02:18 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I think the OP is referring to this, but I'm not 100% sure
https://www.c2cfabrication.com/prod...loor-brace-side-support-for-rear-seat-rh
Re: where does this floor brace go E-body [Re: EW1BH27] #3097400
11/26/22 10:16 PM
11/26/22 10:16 PM
new york
new york
that's the one, where the heck does that go, I don't seem to remember that last time I did major bodywork on this car, its been >20 years and these repro parts weren't as easily available then
- Steve
Re: where does this floor brace go E-body [Re: 67vertman] #3097428
11/27/22 12:25 AM
11/27/22 12:25 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Those are the trunk extensions.
Re: where does this floor brace go E-body [Re: 72restocuda] #3097461
11/27/22 09:08 AM
11/27/22 09:08 AM
Mr T2U Offline
Mr T2U  Offline
my guess is undr the rear package sgelf and the X brace between the side attach to it.
Re: where does this floor brace go E-body [Re: Mr T2U] #3097630
11/27/22 08:30 PM
11/27/22 08:30 PM
Maryland
MoparMike1974 Offline
Maryland
That may be the brace that attaches to the frame rail under the car. I think it connects to the rocker end and wheel tub as well. Im not positive but I think thats it.
