CHEAP power steering cooler #3097125
11/25/22 08:14 PM
11/25/22 08:14 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have a power steering cooler in the return line of the Charger. It is steel and came from a mid 80s M body Police car. It has served me well but I thought I should find a spare in case this one ever cracks and can't be fixed. These M body cars are not so common anymore so I started looking at late model cars. Many have some type of inline cooler but I recall hearing that they can be found on Dodge/Plymouth Neon and PT Cruiser models.
I did find that to be the case. They are mounted to a front crossmember forward of the steering rack.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097126
11/25/22 08:16 PM
11/25/22 08:16 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
They are not real hard to remove. The bolts go in from above so you'd need a box end 9 mm wrench. These coolers are aluminum and have weird lines that can be cut down.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097127
11/25/22 08:17 PM
11/25/22 08:17 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
A much better option can be found in these:
Re: CHEAP power steering cooler [Re: Kern Dog] #3097128
11/25/22 08:18 PM
11/25/22 08:18 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Their coolers are also aluminum but are much easier to remove and they have short nipples....this makes them much easier to retrofit into our cars.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097130
11/25/22 08:21 PM
11/25/22 08:21 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Two 9 mm bolts accessed from underneath, two lines to cut with a blade and it is out.
The brackets are steel, the cooler is aluminum. Simple brackets can be made to mount it anywhere you get a little bit of air flow.
Check out the Minivan version next to the Neon version. Both will work but the Minivan one seems like it would be a simpler choice.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097187
11/26/22 07:33 AM
11/26/22 07:33 AM
BDW Offline
BDW  Offline
Nice find, what did they charge for those.
I was shocked at the prices last time I went, my JY now adds a core and warranty fee.........
Sometimes it's not much more to buy new, crazy.
Re: CHEAP power steering cooler [Re: BDW] #3097283
11/26/22 02:21 PM
11/26/22 02:21 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Nine bucks each!
New is over $100.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097649
11/27/22 09:39 PM
11/27/22 09:39 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
HAYDEN 1009 under @19 brand new from rockauto.
Those JY ones look beat to heck.
Re: CHEAP power steering cooler [Re: Sniper] #3097684
11/28/22 01:51 AM
11/28/22 01:51 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
[quote=Sniper]HAYDEN 1009 under @19 brand new from rockauto.
Those JY ones look beat to heck. [/quote
They will clean up.
Your option has no brackets. Sticking it to the radiator? No thanks....
https://www.summitracing.com/parts/hda-1009?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+H&utm_term=4582077271684170&utm_content=GSAPI+5ba283b27cfaf
No matter where you buy the Hayden unit, you're paying shipping and maybe sales tax. By then you're at three times the cost and limited to the same crappy mounting design.
Re: CHEAP power steering cooler [Re: Kern Dog] #3097726
11/28/22 11:02 AM
11/28/22 11:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They will clean up.
You obviously did not read the info tab. Comes with mounting hardware. And it's not the dirt that I am talking about when I say they are beat up. It's the bent fins and who knows what rock/debris damage there is.
Three options, mostly based on hose size, all come with mounting hardware. The Hayden 1012 first pic shows the mounts on the tubes.
https://www.rockauto.com/en/tools/steering,power+steering,power+steering+cooler,11350
Re: CHEAP power steering cooler [Re: Sniper] #3097992
11/29/22 05:44 AM
11/29/22 05:44 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
New stuff is nice, I'll admit.
I often prefer to repurpose used stuff that still has life left in it. The ones I got for $9.00 each can be cleaned up and after a minute straightening the fins, it will be fine. These aren't correct for an OEM restored car anyway. Function matters to some more than others.
I'm still dollars ahead and the function will be the same.
Re: CHEAP power steering cooler [Re: Kern Dog] #3100528
12/07/22 09:39 PM
12/07/22 09:39 PM
San Diego
JP8 Offline
JP8  Offline
San Diego
Round here they charge you $10 to get in the yard so a $10 part becomes $20. I would rather pay for a new one because I wouldn't have to make the drive, pay for entry, and pay for the part + it's a new part in a box that could get stocked easily on my parts rack till I need it.
Instagram : @5_points_racing
Re: CHEAP power steering cooler [Re: JP8] #3100560
12/08/22 04:29 AM
12/08/22 04:29 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
TEN bucks to get into a self serve yard ???
Yeah....At that price, I fully understand.
Re: CHEAP power steering cooler [Re: Sniper] #3122649
02/18/23 09:06 PM
02/18/23 09:06 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Here's one on Feebay with the perfect container to be shipped in grin
https://www.ebay.com/itm/185778338547?
Facts are stubborn things.
Re: CHEAP power steering cooler [Re: Kern Dog] #3122735
02/19/23 08:19 AM
02/19/23 08:19 AM
BDW Offline
BDW  Offline
Did you ever mount 1 of these, would like to pics of the install
Thx
Re: CHEAP power steering cooler [Re: BDW] #3122800
02/19/23 12:56 PM
02/19/23 12:56 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I have not.
I noticed that when the weather gets hot, driving will often reveal the need for these coolers if you're sawing the wheel back and forth a lot.
I have an inline cooler in my finished car. I bought these for my other projects that have yet to see extensive street time.
One car of mine was just recently registered so now I'll be able to put some real street time on it.
Re: CHEAP power steering cooler [Re: Kern Dog] #3122801
02/19/23 12:58 PM
02/19/23 12:58 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
For the record.....I wasn't really doing 130 when I took that picture.
The speedo worked fine at first but then got stuck at 60 mph even while I was stopped. I was doing around 70 when that picture was taken.
Re: CHEAP power steering cooler [Re: JP8] #3123151
02/20/23 08:12 PM
02/20/23 08:12 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Around here, in addition to this, they'll hit you with core charge, environmental fees, AND force a warranty on 'ya. So, that $10 part has a too real chance of ending up being $35 or more.
Still, I like seeing info regarding 'yard parts. If you can get them cheap, they're still a viable option. beer
John
Re: CHEAP power steering cooler [Re: SattyNoCar] #3123510
02/21/23 08:28 PM
02/21/23 08:28 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I've used junkyard fluid coolers before and it never ended well. Probably has more to do with living in the rust belt than anything else though.
Re: CHEAP power steering cooler [Re: Kern Dog] #3123531
02/21/23 10:18 PM
02/21/23 10:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just google power steering coolers under 40 bucks on e-bay.
