Re: Transmission ID
[Re: 426lloyd]
#3097704
11/28/22 09:58 AM
11/28/22 09:58 AM
Posts: 74,969 U.S.S.A.
JohnRR
U.S.S.A.
Would a slant 6 , 727 have the same numbers No the bellhousing, which is part of the maincase casting, is totally different between the /6 and the small block .
Re: Transmission ID
[Re: JohnRR]
#3097777
11/28/22 01:28 PM
11/28/22 01:28 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The high-mounted starter makes the /6 easy to spot.
Re: Transmission ID
[Re: John_Kunkel]
#3097792
11/28/22 02:16 PM
11/28/22 02:16 PM
Posts: 19,336 north of coder
moparx
note the starter location in the other two pictures JK supplied. small block has starter at roughly the 4 o'clock position, while the big block starter is at 3 o'clock. my easy way to tell them apart at a glance.
