Older 4 wheel drive trans question #3096764
11/24/22 11:03 AM
11/24/22 11:03 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I have an 88 2x truck and I can get a 4x4 complete frame-rears l just need trans and transfer case (auto) I want a part time type transfer, what years do I look for. Was one made? Just a truck no off road stuff. (318-360 engine) Thanks
Re: Older 4 wheel drive trans question [Re: cudaman1969] #3096840
11/24/22 02:49 PM
11/24/22 02:49 PM
moparx Online content
moparx  Online Content
i am no truck expert.
with that said, i "think" the transfer case was a divorced unit up until around 1976 or so. these also had the shorty transmission tail shaft that used a bolt on yolk for the driveshaft to the transfer case.
so looking at that, what year is your frame ?
if the early transmission and transfer case is available, can it be adapted to your frame by possibly using the early cross members ?
i can't answer about the newer cases being part time units. others will have to answer that question.
beer
Re: Older 4 wheel drive trans question [Re: moparx] #3096902
11/24/22 07:12 PM
11/24/22 07:12 PM
fredericksburg,va
fredericksburg,va
beer
Frame is 88, I think, has big 5 lug pattern
Re: Older 4 wheel drive trans question [Re: cudaman1969] #3096917
11/24/22 09:19 PM
11/24/22 09:19 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
They went back to part time in '80. Most likely '80 thru '93 would work.
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
