Re: My Ongoing 67 Belvedere II Projects [Re: Fox-5] #3093652
11/12/22 08:29 AM
11/12/22 08:29 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Do the 383 blocks require a notch to work with the TF heads. Because of the bore size
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: My Ongoing 67 Belvedere II Projects [Re: 67mprfan] #3093669
11/12/22 09:50 AM
11/12/22 09:50 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Just curious....What is the difference in the block between a run of the mill 383, and an HP?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: My Ongoing 67 Belvedere II Projects [Re: 67mprfan] #3093784
11/12/22 05:02 PM
11/12/22 05:02 PM
NH
Fox-5 Offline OP
Fox-5  Offline OP
NH
They shouldn’t TF had heads specific for the 383/440. Definitely have the clay the pistons.
Re: My Ongoing 67 Belvedere II Projects [Re: DynoDave] #3093785
11/12/22 05:05 PM
11/12/22 05:05 PM
NH
Fox-5 Offline OP
Fox-5  Offline OP
NH
I don’t think a whole ton of difference..the HP’s are 10:1 compression ratio, I believe the pistons protrude from the bore as well, in stock from the 69 383 Roadrunner motor is 335hp/425tq.
Re: My Ongoing 67 Belvedere II Projects [Re: Fox-5] #3094029
11/13/22 08:34 PM
11/13/22 08:34 PM
NH
Fox-5 Offline OP
Fox-5  Offline OP
NH
Block degreased and ready for paint
Re: My Ongoing 67 Belvedere II Projects [Re: Fox-5] #3095100
11/17/22 09:31 PM
11/17/22 09:31 PM
NH
Fox-5 Offline OP
Fox-5  Offline OP
NH
Got the VHT turquoise sprayed…color looks good.
Re: My Ongoing 67 Belvedere II Projects [Re: Fox-5] #3096682
11/23/22 10:18 PM
11/23/22 10:18 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Engine color looks good.
DynoDave
Member # 12304
