For Sale - Elephant Hemi Engines - 4th Quarter #3083025
10/03/22 07:38 PM
10/03/22 07:38 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3083280
10/04/22 03:06 PM
10/04/22 03:06 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NORS MADE IN THE USA 2 NEW STARTER SOLENOIDS, 2 NEW STARTER SOLENOID REPAIR KITS(WITH SMALL PARTS ). FIT 1966-1969 DODGE&PLYMOUTH B-BODIES 426 b-body HEMI direct drive starter for 4-speed.$125 MAILED PRIORITY MAIL FLAT RATE BOX
cowgerwilliam035@gmail.com
STARTER SOLENOI9DS 005.JPG (1487 downloads)
STARTER SOLENOI9DS 003.JPG (1487 downloads)
STARTER SOLENOI9DS 004.JPG (1485 downloads)
258 001.JPG (1485 downloads)
Maxwedge Hemi 3705 3861 AFB [Re: moparts] #3083478
10/05/22 07:38 AM
10/05/22 07:38 AM
VA
dragon slayer Offline
VA
Carter Maxwedge/Hemi 3861 SOLD
I also have a 3705 AFB and selection of Hemi Carter 4024 Fuel pumps. Send private message. Thank you,
Moran built 472 crate hemi [Re: moparts] #3084243
10/08/22 08:45 AM
10/08/22 08:45 AM
Out of the State of Confusion
blue_stocker Offline
Moran Race Engines built 472 (crate) stroker gen 2 hemi. Ported iron heads, completely remachined block, small Comp Cams, Indy intake with BIG 3 EFI and Bosch injectors set up for E85, not run since the dyno, 579hp, etc, etc.. I bought this engine 3-1/2 years ago for a project that ended up being sold due to my move from Calif to Tennessee. Currently located in the Savannah Tenn area, $23K. PM me here if interested, thanks for viewing and thanks for the ad space Tom/moparts, much appreciate...
Note, the alternator, pullies and air filter are not included with the engine.
hemi MT.jpg (1282 downloads)
Hemi MT-1.jpg (1279 downloads)
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3084623
10/09/22 06:04 PM
10/09/22 06:04 PM
Dover,Pa
Slap Shot Offline
Slap Shot  Offline
Dover,Pa
Hemi and trans specs
484 Street Hemi
Pre-"World' iron block (2008)
4.15 stroke Eagle crank
4.310 (+.060")
10.25 to 1 Icon forged pistons
RPM rods
Edelbrock Hemi heads
.620 Comp roller cam & lifters
Barton 4150 single plane intake
1050 Proform Carb
12qt Aluminum oil pan
Milodon oiling system
will run on pump gas
727 automatic trans
J convertor,
full manual valve body
deep trans pan
Cheetah shifter
10.20's at 132mph in a 3000lb Barracuda
4 runs on fresh setup
$25,000 picked up in York,Pa 17408 (717) 577-0270
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3085497
10/12/22 02:21 PM
10/12/22 02:21 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1966 & 1967 426 HEMI choke thermostatic housing for the rear carb, nice used condition $250.00 (708) 288-2879
parts 10-12-2022 010.JPG (1085 downloads)
parts 10-12-2022 014.JPG (1084 downloads)
parts 10-12-2022 015.JPG (1086 downloads)
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: dsd70bee] #3085503
10/12/22 02:30 PM
10/12/22 02:30 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1969, 1970 & 1971 426 HEMI double grove crank pulley for cars with power steering, original not reproduction, excellent used condition $375.00 (708) 288-2879
parts 10-06-2022 017.JPG (1084 downloads)
parts 10-06-2022 018.JPG (1083 downloads)
parts 10-06-2022 019.JPG (1082 downloads)
parts 10-06-2022 020.JPG (1082 downloads)
426 Hemi Cylinder heads [Re: moparts] #3085865
10/13/22 10:53 PM
10/13/22 10:53 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Pair of 426 street hemi cylinder heads. Less than 500 miles on valve job. Valve job performed by Hemi super stock racer, Tony DePillo. One head is excellent and completely useable. Other head has a crack at a previous weld repair. Crack creates a coolant leak. I'm pricing both heads for what I think one complete good condition head would be worth. If you can fix the other head, it is a bonus for you. $1400 for both heads.
I also have 4 solid lifter hemi camshafts available for sale. Two are new and two are used.
heads are located in the Phoenix, Az. area. Price does not include shipping. Payment by money order, postal money order or personal check.
Thanks. SOLD!!!!!![size:20pt][/size]
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3085936
10/14/22 09:48 AM
10/14/22 09:48 AM
WI
mopar873 Offline
mopar873  Offline
WI
This is not a discussion forum! Thank you!
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3086095
10/14/22 07:24 PM
10/14/22 07:24 PM
Dover,Pa
Slap Shot Offline
Slap Shot  Offline
Dover,Pa
A-990 Race Hemi factory cast 9 25 1964 for a 1965 Super Stock A-990 Dodge Coronet or Plymouth Belvedere 426 Hemi this is for the guys needing a factory real deal numbers block for their real A-990 Super Stock Hemi car they only made around 100 of each Race Hemi car I will get more pictures but will come with Hemi crank,rods,pistons,harmonic balancer,timing cover,oil pan. this is the correct short block engine original for a 1965 A-990 Super Stock light weight Hemi Plymouth Belvedere or Dodge Coronet. I have the receipts I had Ray Barton do all the machine work and assembly on it. it did have some past repairs on the block but was ran for years in that condition
9-25-64 cast date
11-17-64 assembly date stamped on pan rail
AH 426 HC 2-10 stamped on pad
standard bore
$15,500 buyer to pay and handle all shipping costs from York,Pa 17408 (717) 577-0270
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3086099
10/14/22 07:29 PM
10/14/22 07:29 PM
Dover,Pa
Slap Shot Offline
Slap Shot  Offline
Dover,Pa
426 Hemi, Dual Plug Heads, Auto Trans. Turn Key Setup
Can hear run still in a J code 1969 Plymouth Road Runner. yeah I know why did the previous owner put this setup in a factory J code Hemi Road Runner who knows but that's why its for sale. I don't know every spec or detail.
604 cubic inch 426 Hemi
4.5 bore
4.75 stroke
Heads are 1971 Pro Stock dual plug
Block is MOPAR perf with raised cam
10.5-1 compression
Stage 5 roller rockers
740 lift roller cam
Milodon oil pan
727 trans with reverse shift pattern
$30,000 (717) 577-0270 picked up in York,Pa 17408
New HEMI Block [Re: moparts] #3086705
10/16/22 11:50 PM
10/16/22 11:50 PM
X
xx29 Offline
xx29  Offline
X
New Mopar Performance 426 Hemi block, bought around year 2000 from Bob Mazzolini Racing in Riverside, CA.
Located in Los Angeles area. $7500
Phone: 818-426-8685, email: ebodycab@msn.com
Re: New HEMI Block [Re: xx29] #3086911
10/17/22 03:46 PM
10/17/22 03:46 PM
MarkMcDonald Offline
Indy single 4 like new never ported includes a small carb adapter. $325 plus shipping
NOS Rocker arm shafts [Re: MarkMcDonald] #3086941
10/17/22 05:57 PM
10/17/22 05:57 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
NOS Mopar Performance Hemi rocker are shafts w/ mopar end plugs for the shafts .$300 set. Plus shp New Price
526 KB with SSI 14-71 [Re: JRepucci] #3088775
10/24/22 08:38 AM
10/24/22 08:38 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
$35000. Keith Black 526 hemi. SSI 14-71 Supercharger, AJPE Heads out of Don SNAKE Purdhomme's garage. (Stamped with SNAKE and Serial Numbers)
Engine was previously ran in a pulling tractor for 3 seasons after repairs (Windowed) by previous owner. He was running it at 42% Overdrive on Alcohol. Engine had just come back from Freshening up for next season of pulling when I bought it. Camshaft is a Crane R296-500. Price is firm unless you're also interested in the Dodge Dakota posted in the race Car page. NOT: Will be available 1-Nov-2022 as I am out of the country for work at them moment.
DSC_0793 - Copy (12).JPG (907 downloads)
426 Hemi [Re: moparts] #3090543
10/30/22 06:47 PM
10/30/22 06:47 PM
X
xx29 Offline
xx29  Offline
X
For sale: 426 Hemi engine, Mopar Performance block, Ross pistons, 10.5:1, Keith Black knife edge crank, cast iron heads, approximately 800 miles in a 70 Challenger convertible, customer wanted a 440six pack in convertible. $30K.
E-mail: ebodycab@msn.com
Phone: 818-426-8685
TTI Headers [Re: moparts] #3091189
11/02/22 02:27 PM
11/02/22 02:27 PM
Wisconsin
71duster414 Offline
71duster414  Offline
Wisconsin
New take offs never ran
TTI polished ceramic coated.
I removed these from a 69 hemi roadrunner
$925
hoffmanhhr@gmail.com
NOS Mopar 426 Hemi Ray Barton Valve Covers New [Re: 71duster414] #3095306
11/18/22 04:59 PM
11/18/22 04:59 PM
MI
hemiviper588 Offline
MI
New Ray Barton 426 Street Hemi valve covers, new in the box. $550.00
Re: Hemi solid roller cam [Re: hemiviper588] #3096520
11/23/22 10:42 AM
11/23/22 10:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
xr292r-10 cam
292/298@ .015
254/26 @.050
110 LSA
This is a street roller,$300 obo
Contact me here on the board
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: For Sale - Elephant Hemi Engines - 4th Quarter [Re: moparts] #3097450
11/27/22 06:23 AM
11/27/22 06:23 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
One Pr. 1970 & 1971 426 HEMI valve covers, original not reproduction $2000.00 for the pair (708) 288-2879
parts 9-2-2022 081.JPG (94 downloads)
parts 9-2-2022 083.JPG (95 downloads)
parts 9-2-2022 085.JPG (94 downloads)
parts 9-2-2022 087.JPG (94 downloads)
