Re: Bearing Clearance Aluminum Hemi
[Re: mopar dave]
#3096515
11/23/22 11:28 AM
11/23/22 11:28 AM
Posts: 16,923 NC
440Jim
NC
.0026 on rod and .0038 on main. I will get to it this weekend with a new analog and a digital gauge to get as precise as i can. I am fine with 0.0026" on the rod bearings (2.2 Chevy right?). But if you want more, you can mix HXN and HN bearings to get about 0.0031", just HXN would go loose ~0.0036" What were the journal diameters? For example 2.1992 rod, 2.7492 main
[Re: mopar dave]
#3097152
11/25/22 10:35 PM
11/25/22 10:35 PM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I ended up using the digital gauge on the bore gauge and measured the bearing clearances double checking it with a new anolog gauge. They both gave exact same numbers. Rod 1 .0026 2 .0026 3 .0026 4 .0026 5 .0025 6 .0026 7 .0026 8 .0026 Main 1 .0036 2 .0034 3 .0034 4 .0036 5 .0036
[Re: mopar dave]
#3097421
11/26/22 11:51 PM
11/26/22 11:51 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
[Re: mopar dave]
#3097504
11/27/22 11:47 AM
11/27/22 11:47 AM
Posts: 16,923 NC
440Jim
NC
I like the 0.0026" rod bearing clearance with 2.2" Chevy journal diameters.
Main 1 .0036 2 .0034 3 .0034 4 .0036 5 .0036 Dave, What main bearings are you using? Part number:
[Re: mopar dave]
#3097717
11/28/22 10:46 AM
11/28/22 10:46 AM
Posts: 13,350 Marion, South Carolina [><]
an8sec70cuda
I ended up using the digital gauge on the bore gauge and measured the bearing clearances double checking it with a new anolog gauge. They both gave exact same numbers. Rod 1 .0026 2 .0026 3 .0026 4 .0026 5 .0025 6 .0026 7 .0026 8 .0026 Main 1 .0036 2 .0034 3 .0034 4 .0036 5 .0036 Good to go!
