528 ci Hemi cam specs
#3096393
11/22/22 07:44 PM
11/22/22 07:44 PM
Posts: 5,618 long island NY
Ari440
long island NY
I’m putting together a 528 Hemi
It will be 10-1 comp
426 legend 1 heads
Ray Barton intake with a 1050 carb
What size cam would you run in this combo
Mostly street motor
1.39 9.85 - 137 mph
Re: 528 ci Hemi cam specs
[Re: Ari440]
#3096408
11/22/22 09:05 PM
11/22/22 09:05 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You mention Ray Barton. Why not ask him for a recommendation? I turned to him for the cam in my 540 and have been very happy.
Master, again and still
[Re: DaveRS23]
#3096602
11/23/22 04:19 PM
11/23/22 04:19 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
You mention Ray Barton. Why not ask him for a recommendation? I turned to him for the cam in my 540 and have been very happy. Know someone that went to Ray for cam (and rotating kit) on a 528 4-speed 10:1 with OE crossram/carb setup. He’s got standard E-Brock heads. He’s happy. Cam from Bullet. Why legend heads on a mostly street motor?
[Re: autoxcuda]
#3096657
11/23/22 09:46 PM
11/23/22 09:46 PM
Ari440
long island NY
You mention Ray Barton. Why not ask him for a recommendation? I turned to him for the cam in my 540 and have been very happy. Know someone that went to Ray for cam (and rotating kit) on a 528 4-speed 10:1 with OE crossram/carb setup. He’s got standard E-Brock heads. He’s happy. Cam from Bullet. Why legend heads on a mostly street motor? I bought a Hemi block ,heads and valve covers from a friend This is what he had
1.39 9.85 - 137 mph
[Re: turbobitt]
#3096757
11/24/22 10:23 AM
11/24/22 10:23 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
"I would not even consider a flat tappet cam considering the issues with rounding the lobes and oil compatibility and just the quality inconsistencies out there with the success rate being hit or miss at best."
And you sure never hear of any problems with the "new flavor of the month" rollers, do you? I have had the tool steel FTSs in my street Hemi for 6 years now which I bought used and had refaced. No special oil, just Valvoline. The only precaution I do is to pre-lube the engine at every cold start with the Accusump.
There is a lot of junk out there today. Cams, lifters, springs, etc. Choose wisely and either flat or roller can do good street duty. There are at least as many successful street Hemi engine builds using flat tappets as there are using rollers.
[Re: Ari440]
#3097709
11/28/22 10:17 AM
11/28/22 10:17 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Just get a cam spec'd by Dwayne Porter and be done. I'd go solid roller...just my preference. I don't like worrying about losing lobes. Just had Dwayne spec a solid roller for my BB chevy street truck, lol. Go big and make it run. Nobody likes a show poodle.
[Re: turbobitt]
#3097714
11/28/22 10:26 AM
11/28/22 10:26 AM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
With all that being said I recently converted over to Sequential port fuel injection and this cam works OK but does not generate enough vacuum to run in Speed density mode where I really want it to run.
I'm surprised you're having troubles. I run a 262/262 112lsa cam in my 438" Hemi and no problems with running in SD or power brakes.
[Re: INTMD8]
#3097732
11/28/22 11:12 AM
11/28/22 11:12 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I'm surprised you're having troubles. I run a 262/262 112lsa cam in my 438" Hemi and no problems with running in SD or power brakes. My Big cam is on a tighter LSA, more overlap, less vacuum. I have it tuned in Alpha-N, runs great but would prefer speed density. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: an8sec70cuda]
#3097927
11/28/22 08:54 PM
11/28/22 08:54 PM
Ari440
long island NY
Just get a cam spec'd by Dwayne Porter and be done. I'd go solid roller...just my preference. I don't like worrying about losing lobes. Just had Dwayne spec a solid roller for my BB chevy street truck, lol. Go big and make it run. Nobody likes a show poodle. How big is your cam and motor Chip I was thinking 660/260 or 680/270 10-1 comp 474 -528 ci motor Need to get rotating assembly
1.39 9.85 - 137 mph
[Re: Ari440]
#3098020
11/29/22 09:22 AM
11/29/22 09:22 AM
an8sec70cuda
Mine was a 572, now 575. Had to go .010" bigger last time. Cam is a solid roller...276/284 at .050". .672"/.651" lift. It's a mild lobe, but makes good power. Mid 9s at a buck forty on motor at 3800 lbs. Well into the 8s on a little nitrous. I like em rowdy. To me, a weekend fun car isn't supposed to sound like a station wagon. The cam in my truck is bigger than one posted above and in an engine about 100 cubes smaller. Lifter selection is where a lot of people cheap out and then complain about reliability. My hemi has a good set of Isky Red Zone lifters in it. They've been flawless for years. My Chevy has a cheaper set of Comp Cams lifters, but I don't expect them to live forever. I'll change em out after a while and keep going. Weak springs and/or real aggressive lobes will also kill lifters. All compromises and things to pay attention to. All the more reason to call Dwayne. He's a wealth of knowledge on every aspect of cam selection. Making power is just part of it...having something that doesn't eat itself every 50 runs is another.
[Re: Ari440]
#3098811
12/01/22 11:11 PM
12/01/22 11:11 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: Ari440]
#3099241
12/03/22 04:06 PM
12/03/22 04:06 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
426 legend 1 heads
Mostly street motor Solid roller, around .650 lift net, around 268-264@ .050 on a 112lca would be what I think you'd want for a mostly street driven build...
Brian Hafliger
[Re: Brian Hafliger]
#3099284
12/03/22 06:18 PM
12/03/22 06:18 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
426 legend 1 heads
Mostly street motor Solid roller, around .650 lift net, around 268-264@ .050 on a 112lca would be what I think you'd want for a mostly street driven build... This will work nicely.....Very nice choice....
[Re: Dragula]
#3099303
12/03/22 07:42 PM
12/03/22 07:42 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
426 legend 1 heads
Mostly street motor Solid roller, around .650 lift net, around 268-264@ .050 on a 112lca would be what I think you'd want for a mostly street driven build... This will work nicely.....Very nice choice.... This is very similar to what Crower recommended to me for the 528 that I'm putting together.
[Re: blowndart]
#3099386
12/04/22 03:44 AM
12/04/22 03:44 AM
Posts: 707 California
BigDaddy440
California
I called Dwayne Porter and ordered a solid roller camshaft for my 540 hemi that I'm building for mostly street, and some drag racing too. I had a very positive experience with Dwayne and he also helped me spec out the supporting valvetrain components for the camshaft which is just as important as choosing the right cam profile.
I did NOT want a tame camshaft that sounded stock, but I also didn't want an engine that only comes alive from 4500-7000rpm which is what you get when you have a ton of duration. Big duration cams make power at higher rpm and need a loose converter to take advantage of the rpm range. Those cams are best suited for a drag car, and they'll undoubtedly make more power than a cam like mine. When you're driving on the street, especially cruising, you're usually in the 2000-3000 rpm range. A big duration cam isn't making efficient power at that low of an rpm, and so things like throttle response and fuel economy will suffer in comparison to a smaller duration profile. The last thing you want is a big nasty expensive engine that makes a bunch of noise but doesn't move like it sounds when you punch the throttle. I went with a cam that has 260 degrees of duration at .050" lift which Dwayne suggested would be acceptable, but pushing it a bit for a true street engine of this configuration. Another consideration in all of this is cubic inches. The larger the engine the more duration it needs to achieve the desired power-band. A well built 440ci with a 252 duration at .050 cam may pull hard to 6800 or so, but you'd need a lot more duration in a 540ci to achieve the same rpm characteristics. There are other factors here, like timing, gearing, compression etc, but I'm speaking in general terms.
Before I choose a converter or gearing for my E body, I'm going to dyno the engine and look at the power-band. I'm hoping my 540 begins making good power by 3000rpm and pulls to 6200+ rpm. That would be a fairly wide power-band, that with a low enough gear should be very responsive on the street and at the track too. The dyno sheet will help me decide which components will work best with the engine and allow me to get the most enjoyment and performance out of my engine. That's my goal.
If you're unsure, call Dwayne and let him help you choose a good profile, he'll get it ordered up for you.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: Ari440]
#3101572
12/12/22 01:24 PM
12/12/22 01:24 PM
an8sec70cuda
Do you think 680/270 to big for 10.1 comp on a street motor No.
[Re: an8sec70cuda]
#3101605
12/12/22 02:21 PM
12/12/22 02:21 PM
Dragula
Do you think 680/270 to big for 10.1 comp on a street motor No. No.....But its no subtle either....What's beautiful about a Hemi, is its resistance to detonation....I would turn the compression up to 12:1 or 13:1 if I was building it as a pro-street or a little raced street car. If you keep the timing in check, you will never have an issue.
