Re: Radiator Electric Fan Set Ups, whatcha running?
[Re: Mopar.70]
#3096298
11/22/22 12:45 PM
11/22/22 12:45 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
What you have may work fine if you can keep the temp consistent....For the drags, not a lot of radiator & fan is required....Its the street that really tests a system....So for drag only, any universal 2 row 1" -1.25" tubes, typically a 31x19 will fit with a little work, and a set of cheap 12" dual electric fans....I ran that style setup for the last 20 years, until I put a Calais Hemi cast iron block in, and that damn thing is tough to cool on a 90* day....Switched to a 1.25" tube & spall 14" fans and a 50gph water pump...did the trick.... For me, I would find a wide tube universal rad that will fit, with a sheet metal shroud and 1-fan, and go with that...I like the Griffin ones best with the 1.25" tubes. Had Becool, and the Griffin way out does it. I had a shroud made for mine by Wizard cooling to gain the over sized fans, but for racing, one is all you need. https://proshop.summitracing.com/parts/gri-1-56272-xhttps://proshop.summitracing.com/parts/gri-cu-56272-xNew and then the old one....
[Re: Dragula]
#3096301
11/22/22 12:58 PM
11/22/22 12:58 PM
Posts: 2,515 PA
moparacer
PA
I have always had the best luck with SPAL. For track use only with an electric pump you could probably get away with just using a single 16 inch.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Mopar.70]
#3096302
11/22/22 01:02 PM
11/22/22 01:02 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Griffin radiator, direct bolt in replacement, but w/ 2 rows of 1.25" tubes. Meziere 42 gpm electric water pump. Electric fan and shroud combo from a 2003 Dodge Viper. It does pretty good, but tends to heat up on extended highway driving...65 mph at 3k rpm. Needs more water pump IMO.
[Re: Dragula]
#3096317
11/22/22 01:55 PM
11/22/22 01:55 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
I had my aluminum rad custom made to still look somewhat Mopar style with two huge 1800 cfm Derale electric fans and -20 AN weld bungs. Keeps this car with more than double the horsepower of my other cars even cooler than they all run on the street.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Mopar.70]
#3096439
11/22/22 11:20 PM
11/22/22 11:20 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Big believer in Derale fans. US made, they move a lot of air, and they last. Sales guy at Motorstate( Lane Automotive) went to a seminar at Derale few years back. When I went in looking for a good fan to replace the fan that came in my current car when I bought it, he was emphatic not to use anything else they stocked except Derale. They had Spal and many other brands to choose from.. Installed it, night and day difference, couldn’t be happier.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: INTMD8]
#3096526
11/23/22 11:55 AM
11/23/22 11:55 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I use a $200 triple pass aluminum radiator and a $135 spal 16 inch radistor and it keeps my blown hemi around 185*
[Re: dvw]
#3096592
11/23/22 03:27 PM
11/23/22 03:27 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I use a Delta Pag 18" 4000CFM Brushless.
68 Barracuda Formula S 340
[Re: dvw]
#3096593
11/23/22 03:38 PM
11/23/22 03:38 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
This is a good thread...
I'm considering installing one or two electric fans. I run lots of pylon autocross and HPDE/HSAX events... and after a while of long running time on the tracks, the temp rises... so I run with the heater on full-blast to help reduce some engine heat.
I have a recent new US Radiator Triple-Flow aluminum radiator, two 1.25" rows, 22" width (properly fitting my core support opening), factory fan shroud and 7-blade aluminum clutch fan, have tried different thermostats.. 160-180-195, etc... runs great while normal driving... but when racing, especially lengthy sessions, the temp rises and gets pretty hot... changed the cap to a 21#... temp still moves up to around 220+... only under lengthy racing conditions.
I also added a foam filler (2" round) between the upper radiator tank and the core support... so to prevent air from traveling away from the radiator.
So, I'm considering adding an electric fan... behind the radiator as I have a large automatic trans cooler in the front. I'm also planning to add an upper flat shroud from the grille-to-core support... as I see that many road racers have that added.
Since the radiator is only 22", I may add two electric fans and they would then likely over-extend the radiator width a little.. and that's OK with me. I would further have to remove the 7-blade clutch fan.
Comments, suggestions for electric fans on a 22" width radiator? My thoughts are that while idling after the runs (example: HOLLEY Bowling Green MOPARTY with lots of runs!), the electric fans would help much more, but... on hot lengthy HPDE lapping sessions, the temp has still run increasingly high during those typical 20-30-minute track sessions... really hot on warm summer days!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar.70]
#3096595
11/23/22 03:45 PM
11/23/22 03:45 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Twin spal pushers and an old Be Cool replacement rad, originally for a 528 motor. I guess it works OK on the 572, generally keeping the temp around 185 degree after a pass, back to the pits and pootling around on the street. I think it's marginal, I'm considering going to a dual or triple pass rad, I just don't have the room for big fans. That having been said, last time out we had a faulty fan controller, I've just upgraded to another digital controller. It uses a screw in NPT temp sensor rather than a thermocouple that pushes into the rad fins. We'll have to wait a while see if it improves cooling though.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Mopar Mitch]
#3096604
11/23/22 04:48 PM
11/23/22 04:48 PM
Bad340fish
Tulsa OK
Comments, suggestions for electric fans on a 22" width radiator? My thoughts are that while idling after the runs (example: HOLLEY Bowling Green MOPARTY with lots of runs!), the electric fans would help much more, but... on hot lengthy HPDE lapping sessions, the temp has still run increasingly high during those typical 20-30-minute track sessions... really hot on warm summer days! If you have a small block they are a little tougher to fit because the engine is longer than a BB from what I understand. I use an electric pump and the thinnest fan I could find and its a super tight fit. This is a 4000CFM Delta Pag fan and Meziere 35GPM pump with a speedway dual pass radiator.
[Re: rickraw]
#3096778
11/24/22 11:32 AM
11/24/22 11:32 AM
Bad340fish
Tulsa OK
Any concern with the lower rad hose not being near the bottom of the rad?
