Re: header gaskets that actually LAST?
[Re: volaredon]
#309628
05/06/09 09:36 AM
05/06/09 09:36 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Flatout Gaskets http://www.flatoutgroup.com/gaskets/2007OnlineCatalogPriceGuide.asp7026 CHRYS SB 273-360CI GRAPHITE Header Gaskets Port 1.27"x1.80".(2) $28.40 7026C CHRYS SB 273-360CI RCC COPPER Header Gaskets Port 1.27"x1.80".(2) $53.28 7026S CHRYS SB 273-360CI STEELCLAD/GRAPHITE Header Gaskets Port 1.27"x1.80".(2) $42.04 pricey but these should last
[Re: RylisPro]
#309630
05/06/09 10:09 AM
05/06/09 10:09 AM
Posts: 15,487 Florida
scratchnfotraction
I use a little permatex copper on my header gaskets let it cure over night,have not had a leak in 2 yrs now welds at the collector is another story though! right out the box I got the headers with the new ball and cone to get rid of the collector gasket also it helps to have the exhast hung correctly to allowing for engine torque,IMO had to re-hang mine cause it was to solid and the 2 pipes were welded together at the muffs with cross braces and hung on the stock ridged muff hanger that cam on the single exhast,( both pipes down one side) would not let it move and was blowing gaskets and riping the thin lip of the collector flange off the ends now the header hangs on the engine and the pipes muffs and tail pipes hang from 2 swivel mount just past the rear axle to let it twist some whith out pulling it apart at the gaskets (removed the saddle gas tank from one side and run them down both side straight back) I also moved the muffs as close to the header as I could to help hang more weight toward the headers instead of the tail pipes fixed the probs I had with it blowing the header gasket at the head so headers and 2 hangers past the rear axle is all I have hanging it now
[Re: 68CoronetRT]
#309633
05/06/09 10:40 AM
05/06/09 10:40 AM
Posts: 7,506 Az
Crizila
Az
You are using LA exhaust gaskets on Magnum heads. "Gibson" # 9245 is the correct exhaust header gasket for magnum heads. Great fit - no leaks. Ether Summit or Jegs sells them.
Fastest 300
[Re: Crizila]
#309634
05/06/09 10:51 AM
05/06/09 10:51 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
[Re: DJVCuda]
#309635
05/06/09 11:11 AM
05/06/09 11:11 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Remflex is the only way to go. www.remflex.comI just put a set on a slant six with headers, fit perfectly NO LEAKS. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#309638
05/06/09 01:04 PM
05/06/09 01:04 PM
Posts: 2,279 ILLINOIS
volaredon
ILLINOIS
www.remflex.com
Scott
I guess I'll call them; are they reuseable? What about the copper ones I hear about? (other brands) Yeah; these MrGasket ones on there now didn't leak at first, either. These were brand new headers 1500 miles ago. (and I 'thought" Hooker Super Comps were a decent brand of header) Ive had the cheap-o Blackjacks and Flowtech before, that I could never get to seal, to save my life. My last set were Dynomax, sealed good but were "universal" B-E-A-F-J body smallblock ones, that hung down too low and scraped the ground with the slightest dip/rise in the road! and I had the torsion bars set to factory height spec and 1 size over stock tires. These Hookers tuck up better (though this is a 3/4 ton truck with some ground clearance anyway)
[Re: Rollin Hand]
#309641
05/06/09 03:13 PM
05/06/09 03:13 PM
finadk
East Brunswick, NJ
I believe that they can be reused, I seem to recall someone on the slant six board saying he reused thme many times. They are at least 1/8 inch thick and made of a graphite material. I used them at the manifold and the collector.
Believe it or not, take a look on amazon.com occassionally they come up on sale there with free shipping. scott
Scott
1976 Corvette
[Re: Rollin Hand]
#309643
05/06/09 07:32 PM
05/06/09 07:32 PM
volaredon
ILLINOIS
The Car Shop in East Moline IL carries Remflex and will ship.
Hmmm; I called Remflex today and they gave me no indication that anyone sold them, BUT them. Got a set coming; I guess that if I'm gonna go thru that, I guess I'll throw the mini starter on; even though my original from 83 never been touched, 1.8 HP mopar "whiner" is working flawlessly; only complaint there is that since this is the "longer" starter, one of the primary tubes rest against the end cap. But since I have 2 freshly redone, old style starters here as spares, I wasnt too worried about it; as long as the drivers side header is not yet leaking, I may "not fix what is not yet broke".
